    issues updating MMM-calendar EXT3
    19 Posts 4 Posters 6.6k Views 4 Watching
      sdetweil @BKeyport
      @BKeyport and it gets updated by npm install
      You can do npm ci
      Which will ONLY install the EXACT versions listed in the lock file, even if it’s wrong for your system
      • N
        nschertz @sdetweil
        @sdetweil Correct. After executing “git reset package-lock.json”, I get the message “Unstaged changes after reset:
        M package-lock.json”
        I then run git pull and get
        pi@MagicMirror:~/MagicMirror/modules/MMM-CalendarExt3 $ git pull
        Updating e93534d…5f276d4
        error: Your local changes to the following files would be overwritten by merge:
        package-lock.json
        Please commit your changes or stash them before you merge.
        Aborting
          sdetweil @nschertz
          @nschertz sorry, oops… wrong command!
          git checkout package-lock.json
          fixed the prior posts with note edited
          • N
            nschertz
            to clarify… execute “git checkout package.json” instead of " git reset package.json" or execute “git checkout package.json” and " git reset package.json"?
              sdetweil @nschertz
              @nschertz git checkout
              restores it from the local source repo
              git reset
              removes it from the staged to be submitted as a change
              I posted the checkout first, then a user posted reset and I blindly followed it…
              my mistake
              • N
                nschertz
                oops meant to type
                to clarify… execute “git checkout package-lock.json” instead of " git reset package-lock.json" or execute “git checkout package-lock.json” and " git reset package-lock.json"?
                • N
                  nschertz
                  Got it ! git checkout… worked! Thanks for the clarification on what git reset does verses git checkout.
                    sdetweil @nschertz
                    @nschertz awesome… sorry for the misdirection
                      in the git model
                      the files you see are called the working directory
                      and the repo is hidden in the .git folder
                      that is where the actual ‘state’/contents of each file exists
                      so checkout copies the contents from the repo to the working directory
                      if you were developing and had a change
                      git status would show changed files in the working directory
                      git diff will show WHAT changed on each file
                      to lock it down in the local copy of the repo
                      you git add it to a potential ‘commit’,
                      then git status shows it as ‘staged’
                      to REMOVE it from staged, use the git reset command
                      git commit puts it into the local repo as a change
                      then you ‘push’ your entire local repo to the parent (git remote -v)
                      and the changes (if accepted) are merged and that change is in the master for
                      all new ‘pulls’
                      N 1 Reply Last reply
                      • N
                        nschertz @sdetweil
                        @sdetweil thank you ! This explanation is very helpful. I’m still a little new to the git environment.
