    issues updating MMM-calendar EXT3
    19 Posts 4 Posters 6.0k Views 4 Watching
      sdetweil @JMac
      @JMac the package-lock.json was updated by the last npm install
      so do this, in the module folder
      git checkout package-lock.json
      then the
      npm install
        JMac @sdetweil
        @sdetweil used both of those then tried to up date the rest of the module and still get the same issue when running git pull in the module folder, this is what it says;
        hint: Pulling without specifying how to reconcile divergent branches is
        hint: discouraged. You can squelch this message by running one of the following
        hint: commands sometime before your next pull:
        hint:
        hint: git config pull.rebase false # merge (the default strategy)
        hint: git config pull.rebase true # rebase
        hint: git config pull.ff only # fast-forward only
        hint:
        hint: You can replace “git config” with “git config --global” to set a default
        hint: preference for all repositories. You can also pass --rebase, --no-rebase,
        hint: or --ff-only on the command line to override the configured default per
        hint: invocation.
        Updating 3ca76d9…dfe2425
        error: Your local changes to the following files would be overwritten by merge:
        package-lock.json
        Please commit your changes or stash them before you merge.
        Aborting
          sdetweil @JMac
          @JMac said in issues updating MMM-calendar EXT3:
          sorry, brain fart…
          you need the git pull
          after the git reset , before the npm install
            JMac @sdetweil
            @sdetweil so just to be clear its,
            git reset
            git pull
            npm install
            within the calendar ext3 module folder?
              sdetweil @JMac
              @JMac no
              edited
              # put package-lock.json back to last git clone state
              # update the module
              git pull
              # rerun npm install  with new code
              npm install
              all in the module folder
              # lines are comments and will be ignored if you copy paste that whole thing
              • N Offline
                nschertz
                @sdetweil I just encountered the same problem and followed your instructions in your last post. This did not fix the problem. I continue to get the same error
                “your local changes to the following files would be overwritten by the merge: package-lock.json
                please commit them or stash them before you merge.
                Aborting.”
                Thoughts on what to do next?
                Norb
                  sdetweil @nschertz
                  @nschertz you ARE in the module folder, right?
                  edited
                  cd ~/MagicMirror/modules/MMM-CalendarExt3
                  git pull
                  npm install
                  right?
                  BKeyportB N 2 Replies Last reply Reply Quote 0
                  • BKeyportB Offline
                    just for information, the real issue is the the lock file is included in the package, right?
                      sdetweil @BKeyport
                      @BKeyport and it gets updated by npm install
                      You can do npm ci
                      Which will ONLY install the EXACT versions listed in the lock file, even if it’s wrong for your system
                      • N Offline
                        nschertz @sdetweil
                        @sdetweil Correct. After executing “git reset package-lock.json”, I get the message “Unstaged changes after reset:
                        M package-lock.json”
                        I then run git pull and get
                        pi@MagicMirror:~/MagicMirror/modules/MMM-CalendarExt3 $ git pull
                        Updating e93534d…5f276d4
                        package-lock.json
                        Aborting
                          sdetweil @nschertz
                          @nschertz sorry, oops… wrong command!
                          fixed the prior posts with note edited
                          • N Offline
                            nschertz
                            to clarify… execute “git checkout package.json” instead of " git reset package.json" or execute “git checkout package.json” and " git reset package.json"?
                              sdetweil @nschertz
                              @nschertz git checkout
                              restores it from the local source repo
                              git reset
                              removes it from the staged to be submitted as a change
                              I posted the checkout first, then a user posted reset and I blindly followed it…
                              my mistake
                              • N Offline
                                nschertz
                                oops meant to type
                                to clarify… execute “git checkout package-lock.json” instead of " git reset package-lock.json" or execute “git checkout package-lock.json” and " git reset package-lock.json"?
                                • N Offline
                                  nschertz
                                  Got it ! git checkout… worked! Thanks for the clarification on what git reset does verses git checkout.
                                    sdetweil @nschertz
                                    @nschertz awesome… sorry for the misdirection
                                      in the git model
                                      the files you see are called the working directory
                                      and the repo is hidden in the .git folder
                                      that is where the actual ‘state’/contents of each file exists
                                      so checkout copies the contents from the repo to the working directory
                                      if you were developing and had a change
                                      git status would show changed files in the working directory
                                      git diff will show WHAT changed on each file
                                      to lock it down in the local copy of the repo
                                      you git add it to a potential ‘commit’,
                                      then git status shows it as ‘staged’
                                      to REMOVE it from staged, use the git reset command
                                      git commit puts it into the local repo as a change
                                      then you ‘push’ your entire local repo to the parent (git remote -v)
                                      and the changes (if accepted) are merged and that change is in the master for
                                      all new ‘pulls’
                                      • N Offline
                                        nschertz @sdetweil
                                        @sdetweil thank you ! This explanation is very helpful. I’m still a little new to the git environment.
