    issues updating MMM-calendar EXT3
    19 Posts 4 Posters 6.4k Views 4 Watching
    • BKeyportB Offline
      just for information, the real issue is the the lock file is included in the package, right?
        sdetweil @BKeyport
        @BKeyport and it gets updated by npm install
        You can do npm ci
        Which will ONLY install the EXACT versions listed in the lock file, even if it’s wrong for your system
        • N Offline
          nschertz @sdetweil
          @sdetweil Correct. After executing “git reset package-lock.json”, I get the message “Unstaged changes after reset:
          M package-lock.json”
          I then run git pull and get
          pi@MagicMirror:~/MagicMirror/modules/MMM-CalendarExt3 $ git pull
          Updating e93534d…5f276d4
          error: Your local changes to the following files would be overwritten by merge:
          package-lock.json
          Please commit your changes or stash them before you merge.
          Aborting
            sdetweil @nschertz
            @nschertz sorry, oops… wrong command!
            git checkout package-lock.json
            fixed the prior posts with note edited
            • N Offline
              nschertz
              to clarify… execute “git checkout package.json” instead of " git reset package.json" or execute “git checkout package.json” and " git reset package.json"?
                sdetweil @nschertz
                @nschertz git checkout
                restores it from the local source repo
                git reset
                removes it from the staged to be submitted as a change
                I posted the checkout first, then a user posted reset and I blindly followed it…
                my mistake
                • N Offline
                  nschertz
                  oops meant to type
                  to clarify… execute “git checkout package-lock.json” instead of " git reset package-lock.json" or execute “git checkout package-lock.json” and " git reset package-lock.json"?
                  • N Offline
                    nschertz
                    Got it ! git checkout… worked! Thanks for the clarification on what git reset does verses git checkout.
                      sdetweil @nschertz
                      @nschertz awesome… sorry for the misdirection
                        in the git model
                        the files you see are called the working directory
                        and the repo is hidden in the .git folder
                        that is where the actual ‘state’/contents of each file exists
                        so checkout copies the contents from the repo to the working directory
                        if you were developing and had a change
                        git status would show changed files in the working directory
                        git diff will show WHAT changed on each file
                        to lock it down in the local copy of the repo
                        you git add it to a potential ‘commit’,
                        then git status shows it as ‘staged’
                        to REMOVE it from staged, use the git reset command
                        git commit puts it into the local repo as a change
                        then you ‘push’ your entire local repo to the parent (git remote -v)
                        and the changes (if accepted) are merged and that change is in the master for
                        all new ‘pulls’
                        • N Offline
                          nschertz @sdetweil
                          @sdetweil thank you ! This explanation is very helpful. I’m still a little new to the git environment.
