weather forecast does not show on screen
 Hello together…all a happy new year. what is my mistake becaus the forecast does not show…here is my config… MM is on update also the adapter. for infos thanks a lot { module: "MMM-OpenmapWeather", position: "top_right", // This can be any of the regions. // Best results in left or right regions. config: { // See 'Configuration options' for more information. location: "xxxxxxxxxx.", locationID: "2xxx4", //Location ID from http://openweathermap.org/help/city_list.txt appid: "xxxxxxxxx8", //openweathermap.org API key colorIcon: true } }, { module: "weather", position: "top_right", header: "Weather Forecast", config: { weatherProvider: "openweathermap", type: "forecast", location: "xxxxxxxxxxxxxx.", locationID: "xxxxxxx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city apiKey: "xxxf9xxx1xxxx" } },
 @kusselin did you get the new API key (v3) which requires credit card backing,
 AND location/locationID are not supported on 3.0, have to use lat/lon
 (and header title needs to be set manually)
 @sdetweil aha…thanks for the info…I didn’t know that…on my old system (not yet v 3.0) the prediction is still running…but o.k. now I know thanks to you. One question: is the forecast module this then here:
 https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecastwhen not…can you send me the link please
 @kusselin on the module, you can use that or the default weather module supports forecast too
 @sdetweil said in weather forecast does not show on screen: @kusselin on the module, you can use that or the default weather module supports forecast too Hi sam, how can i unstand this with standard module an forecast display? what must i do?
 @kusselin did you get forecast to work?
