    Cannot find module 'undici' - 'npm install' doesn't work
    17 Posts 3 Posters 6.0k Views 3 Watching
    • K Offline
      Klinge @sdetweil
      @sdetweil Great, now it works.
      Thank you for your help again
      • K Klinge has marked this topic as solved on
      • T Offline
        tleo32
        Hello - I am receiving a similar error and struggling to resolve. Does anyone have suggestions?
        npm error code EBADENGINE
        npm error engine Unsupported engine
        npm error engine Not compatible with your version of node/npm: magicmirror@2.30.0
        npm error notsup Not compatible with your version of node/npm: magicmirror@2.30.0
        npm error notsup Required: {“node”:“>=20.18.1 <21 || >=22”}
        npm error notsup Actual: {“npm”:“10.8.1”,“node”:“v20.16.0”}
        npm error A complete log of this run can be found in: /home/tleonetti/.npm/_logs/2025-02-17T00_47_21_325Z-debug-0.log
          sdetweil @tleo32
          @tleo32 yes, you didnt read the release notes. we need node 20.18.1 or above, not 21
          because you started manually, use my upgrade script w force as the parm instead of apply
          see https://github.com/sdetweil/MagicMirror_scripts
          also https://forum.magicmirror.builders/post/123993
          • T Offline
            tleo32 @sdetweil
            thank you for responding @sdetweil, for some reason not updating the node, please see below:
            update log will be in /home/tleonetti/MagicMirror/installers/upgrade.log
            doing test run = false
            Node currently installed. Checking version number.
            Minimum Node version: v20.18.1
            Installed Node version: v20.16.0
            installing correct version of node and npm, please wait
            Check current Node installation …
            Node should be upgraded.
            Installing Node.js …
            force: line 323: [: too many arguments
            tar (child): /home/tleonetti/node_release-.tar.gz: Cannot open: No such file or directory
            tar (child): Error is not recoverable: exiting now
            tar: Child returned status 2
            tar: Error is not recoverable: exiting now
            node version is
            Node.js installation Done! version=v20.16.0
            Check current NPM installation …
            NPM currently installed. Checking version number.
            Minimum npm version: V10.8.2
            Installed npm version: V10.8.1
            npm should be upgraded.
            Installing npm …
            npm installation Done! version=V10.8.1
            upgrading from version 2.30.0 to 2.30.0
            force: line 611: pm2: command not found
            fetching latest revisions
            updating MagicMirror runtime, please wait
            npm error A complete log of this run can be found in: /home/tleonetti/.npm/_logs/2025-02-17T19_56_02_704Z-debug-0.log
              sdetweil @tleo32
              @tleo32 can you do this
              cd ~/MagicMirror
              curl -sL https://deb.nodesource.com/setup_20.x | sudo -E bash - &>somefile.txt
              and send me somefile.txt via email. same userid at gmail
              and then
              short fix
              sudo npm install n
              sudo n 20.18.1
              hash -r
              npm run install-MagicMirror
              please advise results
                @tleo32 I also pushed a fix, so, rerunning the upgrade with force should work…
                  he had nvm
                  installed too, conflicts with n ( nodejs version of nvm)
