    Cannot find module 'undici' - 'npm install' doesn't work
    17 Posts 3 Posters 10.9k Views 3 Watching
    • K
      Klinge
      since today my MMM don´t start.
      When I start it, I got the following error message
      pi@raspberrypi:~/MagicMirror $ display=:0 npm start
      > magicmirror@2.30.0 start
      > npm run start:x11
      > magicmirror@2.30.0 start:x11
      [2025-01-02 09:01:37.931] [ERROR] App threw an error during load
      [2025-01-02 09:01:37.938] [ERROR] Error: Cannot find module 'undici'
      Require stack:
          at Module._resolveFilename (node:internal/modules/cjs/loader:1055:15)
          at s._resolveFilename (node:electron/js2c/browser_init:2:115476)
          at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:908:27)
          at c._load (node:electron/js2c/node_init:2:13672)
          at Module.require (node:internal/modules/cjs/loader:1122:19)
          at require (node:internal/modules/helpers:130:18)
          at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:15:40)
          at Module._compile (node:internal/modules/cjs/loader:1256:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1311:10)
          at Module.load (node:internal/modules/cjs/loader:1098:32)
          at Module._load (node:internal/modules/cjs/loader:945:12)
          at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
      A JavaScript error occurred in the main process
      When I try “npm install” I got the following
      pi@raspberrypi:~/MagicMirror $ npm install
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: magicmirror@2.30.0
      npm error notsup Not compatible with your version of node/npm: magicmirror@2.30.0
      npm error notsup Required: {"node":">=20.18.1 <21 || >=22"}
      npm error notsup Actual:   {"npm":"10.8.2","node":"v18.20.5"}
      npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-01-02T08_02_32_005Z-debug-0.log
      So I tried to update my npm with
      sudo apt update
      sudo apt full-upgrade
      sudo apt remove node
      sudo apt remove nodejs
      sudo apt install nodejs
      but npm has still the version 10.8.2
      So, what have I done wrong?
      It would be really nice, if you have some advice for me.
      Thank you in advance.
      Kind regards
      Klinge
        sdetweil @Klinge
        @Klinge yes it says we need node 20.18.1 or above
        https://forum.magicmirror.builders/topic/19271/version-2-30-0-requires-updated-nodejs-warning-for-pi0w-installations
        anyhow quickest way
        install tool to allow changing node versions
        sudo npm install n -g
        sudo n 20.18.1
        now do the MagicMirror install
        npm run install-mm
          sdetweil @Klinge
          @Klinge also, next time use my upgrade script
          • K
            Klinge @sdetweil
            @sdetweil Thank you for your help.
            After updating to 20.18.1 unfortunately I get the following error
            pi@raspberrypi:~/MagicMirror $ pwd
            pi@raspberrypi:~/MagicMirror $ npm run install-mm
            node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
            And yes, the next time I will use your upgrade script ;-)
              sdetweil @Klinge
              @Klinge you are on buster os… you need to upgrade to a later version, as that library is not available on buster… my script would have told you that…
              use my backup/restore scripts
              https://github.com/sdetweil/MagicMirror-backup-restore
              to be able to quickly move to new OS
              use install script to install MM on new os
              and then restore to put back MM config and modules
              (and upgrade script next time)
              • K
                Klinge @sdetweil
                @sdetweil Shit, that’s the same problem I had with my second mirror a few weeks ago. Well, it’s been running fine since 2016.
                Many thanks for your tips. With your scripts I’ll quickly install the new one.
                  sdetweil @Klinge
                  @Klinge if you had started w my script it would have told you so you didn’t have to upgrade NOW . sorry
                  the whole objective of my scripts is to prevent this exact scenario. broke system.
                  • K
                    Klinge @sdetweil
                    @sdetweil Yes, you’re absolutely right, of course. Sometimes you have to learn from your own mistakes ;-) so we just call it a Layer8 problem ;-) Thanks anyway for your effort
                    • K Klinge has marked this topic as solved on
                    • K Klinge has marked this topic as unsolved on
                    • K
                      Klinge
                      @sdetweil some minutes ago I updated my MMM with your script
                      kling@raspi-mm-gaeste:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                      update log will be in /home/kling/MagicMirror/installers/upgrade.log
                      doing test run = false
                      Minimum Node version: v20.18.1
                      Installed Node version: v20.9.0
                      installing correct version of node and npm, please wait
                      Installed Node version: v20.18.1
                      No Node.js upgrade necessary.
                      Minimum npm version: V10.8.2
                      Installed npm version: V10.8.2
                      No npm upgrade necessary.
                      want /var/swap=200MByte, checking existing: keeping it
                      saving custom.css
                      local version 2.30.0 already same as master 2.30.0
                      restoring custom.css
                      After that I tried to start my MMM and now I got the same error message "Cannot find module ‘undici’.
                      kling@raspi-mm-gaeste:~/MagicMirror $ display=:0 npm start
                      > npm run start:x11
                      [2025-02-13 16:04:02.858] [ERROR] App threw an error during load
                      [2025-02-13 16:04:02.863] [ERROR] Error: Cannot find module 'undici'
                      Require stack:
                      - /home/kling/MagicMirror/js/app.js
                      - /home/kling/MagicMirror/js/electron.js
                          at Module._resolveFilename (node:internal/modules/cjs/loader:1232:15)
                          at s._resolveFilename (node:electron/js2c/browser_init:2:121498)
                          at Module._resolveFilename (/home/kling/MagicMirror/node_modules/module-alias/index.js:49:29)
                          at Module._load (node:internal/modules/cjs/loader:1058:27)
                          at c._load (node:electron/js2c/node_init:2:17025)
                          at Module.require (node:internal/modules/cjs/loader:1318:19)
                          at require (node:internal/modules/helpers:179:18)
                          at Object.<anonymous> (/home/kling/MagicMirror/js/app.js:15:40)
                          at Module._compile (node:internal/modules/cjs/loader:1484:14)
                          at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
                          at Module.load (node:internal/modules/cjs/loader:1295:32)
                          at Module._load (node:internal/modules/cjs/loader:1111:12)
                          at Object.<anonymous> (/home/kling/MagicMirror/js/electron.js:4:14)
                      Uncaught Exception:
                      Require stack:
                      [5112:0213/160403.943167:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [5112:0213/160403.943531:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      So my question again, what did I wrong? It is necessary to install the MMM completely new?
                      Thank you.
                      Kind regards.
                      Klinge
                        sdetweil @Klinge
                        @Klinge you tried to do it manually , my script will NOT upgrade OVER the same version accidentally
                        so you have to FORCE it
                        change the update command string end from
                        apply
                        to
                        force
                        • K
                          Klinge @sdetweil
                          @sdetweil Great, now it works.
                          Thank you for your help again
                          • T
                            tleo32
                            Hello - I am receiving a similar error and struggling to resolve. Does anyone have suggestions?
                            npm error notsup Required: {“node”:“>=20.18.1 <21 || >=22”}
                            npm error notsup Actual: {“npm”:“10.8.1”,“node”:“v20.16.0”}
                            npm error A complete log of this run can be found in: /home/tleonetti/.npm/_logs/2025-02-17T00_47_21_325Z-debug-0.log
                              sdetweil @tleo32
                              @tleo32 yes, you didnt read the release notes. we need node 20.18.1 or above, not 21
                              because you started manually, use my upgrade script w force as the parm instead of apply
                              see https://github.com/sdetweil/MagicMirror_scripts
                              also https://forum.magicmirror.builders/post/123993
                              • T
                                tleo32 @sdetweil
                                thank you for responding @sdetweil, for some reason not updating the node, please see below:
                                update log will be in /home/tleonetti/MagicMirror/installers/upgrade.log
                                Installed Node version: v20.16.0
                                Check current Node installation …
                                Node should be upgraded.
                                Installing Node.js …
                                force: line 323: [: too many arguments
                                tar (child): /home/tleonetti/node_release-.tar.gz: Cannot open: No such file or directory
                                tar (child): Error is not recoverable: exiting now
                                tar: Child returned status 2
                                tar: Error is not recoverable: exiting now
                                node version is
                                Node.js installation Done! version=v20.16.0
                                Check current NPM installation …
                                Installed npm version: V10.8.1
                                npm should be upgraded.
                                Installing npm …
                                npm installation Done! version=V10.8.1
                                upgrading from version 2.30.0 to 2.30.0
                                force: line 611: pm2: command not found
                                fetching latest revisions
                                npm error A complete log of this run can be found in: /home/tleonetti/.npm/_logs/2025-02-17T19_56_02_704Z-debug-0.log
                                  sdetweil @tleo32
                                  @tleo32 can you do this
                                  curl -sL https://deb.nodesource.com/setup_20.x | sudo -E bash - &>somefile.txt
                                  and send me somefile.txt via email. same userid at gmail
                                  and then
                                  short fix
                                  sudo npm install n
                                  sudo n 20.18.1
                                  hash -r
                                  npm run install-MagicMirror
                                  please advise results
                                    @tleo32 I also pushed a fix, so, rerunning the upgrade with force should work…
                                      he had nvm
                                      installed too, conflicts with n ( nodejs version of nvm)
