    Cannot find module 'undici' - 'npm install' doesn't work
    17 Posts 3 Posters 7.6k Views 3 Watching
      sdetweil @Klinge
      @Klinge you are on buster os… you need to upgrade to a later version, as that library is not available on buster… my script would have told you that…
      use my backup/restore scripts
      https://github.com/sdetweil/MagicMirror-backup-restore
      to be able to quickly move to new OS
      use install script to install MM on new os
      and then restore to put back MM config and modules
      (and upgrade script next time)
      • K Offline
        Klinge @sdetweil
        @sdetweil Shit, that’s the same problem I had with my second mirror a few weeks ago. Well, it’s been running fine since 2016.
        Many thanks for your tips. With your scripts I’ll quickly install the new one.
          sdetweil @Klinge
          @Klinge if you had started w my script it would have told you so you didn’t have to upgrade NOW . sorry
          the whole objective of my scripts is to prevent this exact scenario. broke system.
          • K Offline
            Klinge @sdetweil
            @sdetweil Yes, you’re absolutely right, of course. Sometimes you have to learn from your own mistakes ;-) so we just call it a Layer8 problem ;-) Thanks anyway for your effort
            • K Klinge has marked this topic as solved on
            • K Klinge has marked this topic as unsolved on
            • K Offline
              Klinge
              @sdetweil some minutes ago I updated my MMM with your script
              kling@raspi-mm-gaeste:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
              update log will be in /home/kling/MagicMirror/installers/upgrade.log
              doing test run = false
              Minimum Node version: v20.18.1
              Installed Node version: v20.9.0
              installing correct version of node and npm, please wait
              Installed Node version: v20.18.1
              No Node.js upgrade necessary.
              Minimum npm version: V10.8.2
              Installed npm version: V10.8.2
              No npm upgrade necessary.
              want /var/swap=200MByte, checking existing: keeping it
              saving custom.css
              local version 2.30.0 already same as master 2.30.0
              restoring custom.css
              After that I tried to start my MMM and now I got the same error message "Cannot find module ‘undici’.
              kling@raspi-mm-gaeste:~/MagicMirror $ display=:0 npm start
              > magicmirror@2.30.0 start
              > npm run start:x11
              > magicmirror@2.30.0 start:x11
              [2025-02-13 16:04:02.858] [ERROR] App threw an error during load
              [2025-02-13 16:04:02.863] [ERROR] Error: Cannot find module 'undici'
              Require stack:
              - /home/kling/MagicMirror/js/app.js
              - /home/kling/MagicMirror/js/electron.js
                  at Module._resolveFilename (node:internal/modules/cjs/loader:1232:15)
                  at s._resolveFilename (node:electron/js2c/browser_init:2:121498)
                  at Module._resolveFilename (/home/kling/MagicMirror/node_modules/module-alias/index.js:49:29)
                  at Module._load (node:internal/modules/cjs/loader:1058:27)
                  at c._load (node:electron/js2c/node_init:2:17025)
                  at Module.require (node:internal/modules/cjs/loader:1318:19)
                  at require (node:internal/modules/helpers:179:18)
                  at Object.<anonymous> (/home/kling/MagicMirror/js/app.js:15:40)
                  at Module._compile (node:internal/modules/cjs/loader:1484:14)
                  at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
                  at Module.load (node:internal/modules/cjs/loader:1295:32)
                  at Module._load (node:internal/modules/cjs/loader:1111:12)
                  at Object.<anonymous> (/home/kling/MagicMirror/js/electron.js:4:14)
              A JavaScript error occurred in the main process
              Uncaught Exception:
              Require stack:
              [5112:0213/160403.943167:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [5112:0213/160403.943531:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              So my question again, what did I wrong? It is necessary to install the MMM completely new?
              Thank you.
              Kind regards.
              Klinge
                sdetweil @Klinge
                @Klinge you tried to do it manually , my script will NOT upgrade OVER the same version accidentally
                so you have to FORCE it
                change the update command string end from
                apply
                to
                force
                • K Offline
                  Klinge @sdetweil
                  @sdetweil Great, now it works.
                  Thank you for your help again
                  • T Offline
                    tleo32
                    Hello - I am receiving a similar error and struggling to resolve. Does anyone have suggestions?
                    npm error code EBADENGINE
                    npm error engine Unsupported engine
                    npm error engine Not compatible with your version of node/npm: magicmirror@2.30.0
                    npm error notsup Not compatible with your version of node/npm: magicmirror@2.30.0
                    npm error notsup Required: {“node”:“>=20.18.1 <21 || >=22”}
                    npm error notsup Actual: {“npm”:“10.8.1”,“node”:“v20.16.0”}
                    npm error A complete log of this run can be found in: /home/tleonetti/.npm/_logs/2025-02-17T00_47_21_325Z-debug-0.log
                      sdetweil @tleo32
                      @tleo32 yes, you didnt read the release notes. we need node 20.18.1 or above, not 21
                      because you started manually, use my upgrade script w force as the parm instead of apply
                      see https://github.com/sdetweil/MagicMirror_scripts
                      also https://forum.magicmirror.builders/post/123993
                      • T Offline
                        tleo32 @sdetweil
                        thank you for responding @sdetweil, for some reason not updating the node, please see below:
                        update log will be in /home/tleonetti/MagicMirror/installers/upgrade.log
                        Installed Node version: v20.16.0
                        Check current Node installation …
                        Node should be upgraded.
                        Installing Node.js …
                        force: line 323: [: too many arguments
                        tar (child): /home/tleonetti/node_release-.tar.gz: Cannot open: No such file or directory
                        tar (child): Error is not recoverable: exiting now
                        tar: Child returned status 2
                        tar: Error is not recoverable: exiting now
                        node version is
                        Node.js installation Done! version=v20.16.0
                        Check current NPM installation …
                        Installed npm version: V10.8.1
                        npm should be upgraded.
                        Installing npm …
                        npm installation Done! version=V10.8.1
                        upgrading from version 2.30.0 to 2.30.0
                        force: line 611: pm2: command not found
                        fetching latest revisions
                        npm error A complete log of this run can be found in: /home/tleonetti/.npm/_logs/2025-02-17T19_56_02_704Z-debug-0.log
