    Cannot find module 'undici' - 'npm install' doesn't work
    17 Posts 3 Posters 10.9k Views 3 Watching
      sdetweil @Klinge
      @Klinge also, next time use my upgrade script
      • K
        Klinge @sdetweil
        @sdetweil Thank you for your help.
        After updating to 20.18.1 unfortunately I get the following error
        pi@raspberrypi:~/MagicMirror $ pwd
        /home/pi/MagicMirror
        pi@raspberrypi:~/MagicMirror $ npm run install-mm
        node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
        And yes, the next time I will use your upgrade script ;-)
          sdetweil @Klinge
          @Klinge you are on buster os… you need to upgrade to a later version, as that library is not available on buster… my script would have told you that…
          use my backup/restore scripts
          https://github.com/sdetweil/MagicMirror-backup-restore
          to be able to quickly move to new OS
          use install script to install MM on new os
          and then restore to put back MM config and modules
          (and upgrade script next time)
          • K
            Klinge @sdetweil
            @sdetweil Shit, that’s the same problem I had with my second mirror a few weeks ago. Well, it’s been running fine since 2016.
            Many thanks for your tips. With your scripts I’ll quickly install the new one.
              sdetweil @Klinge
              @Klinge if you had started w my script it would have told you so you didn’t have to upgrade NOW . sorry
              the whole objective of my scripts is to prevent this exact scenario. broke system.
              • K
                Klinge @sdetweil
                @sdetweil Yes, you’re absolutely right, of course. Sometimes you have to learn from your own mistakes ;-) so we just call it a Layer8 problem ;-) Thanks anyway for your effort
                • K Klinge has marked this topic as solved on
                • K Klinge has marked this topic as unsolved on
                • K
                  Klinge
                  @sdetweil some minutes ago I updated my MMM with your script
                  kling@raspi-mm-gaeste:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                  update log will be in /home/kling/MagicMirror/installers/upgrade.log
                  doing test run = false
                  Minimum Node version: v20.18.1
                  Installed Node version: v20.9.0
                  installing correct version of node and npm, please wait
                  Installed Node version: v20.18.1
                  No Node.js upgrade necessary.
                  Minimum npm version: V10.8.2
                  Installed npm version: V10.8.2
                  No npm upgrade necessary.
                  want /var/swap=200MByte, checking existing: keeping it
                  saving custom.css
                  local version 2.30.0 already same as master 2.30.0
                  restoring custom.css
                  After that I tried to start my MMM and now I got the same error message "Cannot find module ‘undici’.
                  kling@raspi-mm-gaeste:~/MagicMirror $ display=:0 npm start
                  > magicmirror@2.30.0 start
                  > npm run start:x11
                  > magicmirror@2.30.0 start:x11
                  [2025-02-13 16:04:02.858] [ERROR] App threw an error during load
                  [2025-02-13 16:04:02.863] [ERROR] Error: Cannot find module 'undici'
                  Require stack:
                  - /home/kling/MagicMirror/js/app.js
                  - /home/kling/MagicMirror/js/electron.js
                      at Module._resolveFilename (node:internal/modules/cjs/loader:1232:15)
                      at s._resolveFilename (node:electron/js2c/browser_init:2:121498)
                      at Module._resolveFilename (/home/kling/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at Module._load (node:internal/modules/cjs/loader:1058:27)
                      at c._load (node:electron/js2c/node_init:2:17025)
                      at Module.require (node:internal/modules/cjs/loader:1318:19)
                      at require (node:internal/modules/helpers:179:18)
                      at Object.<anonymous> (/home/kling/MagicMirror/js/app.js:15:40)
                      at Module._compile (node:internal/modules/cjs/loader:1484:14)
                      at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
                      at Module.load (node:internal/modules/cjs/loader:1295:32)
                      at Module._load (node:internal/modules/cjs/loader:1111:12)
                      at Object.<anonymous> (/home/kling/MagicMirror/js/electron.js:4:14)
                  A JavaScript error occurred in the main process
                  Uncaught Exception:
                  Require stack:
                  [5112:0213/160403.943167:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [5112:0213/160403.943531:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  So my question again, what did I wrong? It is necessary to install the MMM completely new?
                  Thank you.
                  Kind regards.
                  Klinge
                    sdetweil @Klinge
                    @Klinge you tried to do it manually , my script will NOT upgrade OVER the same version accidentally
                    so you have to FORCE it
                    change the update command string end from
                    apply
                    to
                    force
                    • K
                      Klinge @sdetweil
                      @sdetweil Great, now it works.
                      Thank you for your help again
                      • T
                        tleo32
                        Hello - I am receiving a similar error and struggling to resolve. Does anyone have suggestions?
                        npm error code EBADENGINE
                        npm error engine Unsupported engine
                        npm error engine Not compatible with your version of node/npm: magicmirror@2.30.0
                        npm error notsup Not compatible with your version of node/npm: magicmirror@2.30.0
                        npm error notsup Required: {“node”:“>=20.18.1 <21 || >=22”}
                        npm error notsup Actual: {“npm”:“10.8.1”,“node”:“v20.16.0”}
                        npm error A complete log of this run can be found in: /home/tleonetti/.npm/_logs/2025-02-17T00_47_21_325Z-debug-0.log
                          sdetweil @tleo32
                          @tleo32 yes, you didnt read the release notes. we need node 20.18.1 or above, not 21
                          because you started manually, use my upgrade script w force as the parm instead of apply
                          see https://github.com/sdetweil/MagicMirror_scripts
                          also https://forum.magicmirror.builders/post/123993
                          • T
                            tleo32 @sdetweil
                            thank you for responding @sdetweil, for some reason not updating the node, please see below:
                            update log will be in /home/tleonetti/MagicMirror/installers/upgrade.log
                            Installed Node version: v20.16.0
                            Check current Node installation …
                            Node should be upgraded.
                            Installing Node.js …
                            force: line 323: [: too many arguments
                            tar (child): /home/tleonetti/node_release-.tar.gz: Cannot open: No such file or directory
                            tar (child): Error is not recoverable: exiting now
                            tar: Child returned status 2
                            tar: Error is not recoverable: exiting now
                            node version is
                            Node.js installation Done! version=v20.16.0
                            Check current NPM installation …
                            Installed npm version: V10.8.1
                            npm should be upgraded.
                            Installing npm …
                            npm installation Done! version=V10.8.1
                            upgrading from version 2.30.0 to 2.30.0
                            force: line 611: pm2: command not found
                            fetching latest revisions
                            npm error A complete log of this run can be found in: /home/tleonetti/.npm/_logs/2025-02-17T19_56_02_704Z-debug-0.log
                              sdetweil @tleo32
                              @tleo32 can you do this
                              curl -sL https://deb.nodesource.com/setup_20.x | sudo -E bash - &>somefile.txt
                              and send me somefile.txt via email. same userid at gmail
                              and then
                              short fix
                              sudo npm install n
                              sudo n 20.18.1
                              hash -r
                              npm run install-MagicMirror
                              please advise results
                                @tleo32 I also pushed a fix, so, rerunning the upgrade with force should work…
                                  he had nvm
                                  installed too, conflicts with n ( nodejs version of nvm)
