    Cannot find module 'undici' - 'npm install' doesn't work
    17 Posts 3 Posters 10.6k Views 3 Watching
    • K Offline
      Klinge @sdetweil
      @sdetweil Shit, that’s the same problem I had with my second mirror a few weeks ago. Well, it’s been running fine since 2016.
      Many thanks for your tips. With your scripts I’ll quickly install the new one.
        sdetweil @Klinge
        @Klinge if you had started w my script it would have told you so you didn’t have to upgrade NOW . sorry
        the whole objective of my scripts is to prevent this exact scenario. broke system.
        • K Offline
          Klinge @sdetweil
          @sdetweil Yes, you’re absolutely right, of course. Sometimes you have to learn from your own mistakes ;-) so we just call it a Layer8 problem ;-) Thanks anyway for your effort
          • K Klinge has marked this topic as solved on
          • K Klinge has marked this topic as unsolved on
          • K Offline
            Klinge
            @sdetweil some minutes ago I updated my MMM with your script
            kling@raspi-mm-gaeste:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            update log will be in /home/kling/MagicMirror/installers/upgrade.log
            doing test run = false
            Minimum Node version: v20.18.1
            Installed Node version: v20.9.0
            installing correct version of node and npm, please wait
            Installed Node version: v20.18.1
            No Node.js upgrade necessary.
            Minimum npm version: V10.8.2
            Installed npm version: V10.8.2
            No npm upgrade necessary.
            want /var/swap=200MByte, checking existing: keeping it
            saving custom.css
            local version 2.30.0 already same as master 2.30.0
            restoring custom.css
            After that I tried to start my MMM and now I got the same error message "Cannot find module ‘undici’.
            kling@raspi-mm-gaeste:~/MagicMirror $ display=:0 npm start
            > magicmirror@2.30.0 start
            > npm run start:x11
            > magicmirror@2.30.0 start:x11
            [2025-02-13 16:04:02.858] [ERROR] App threw an error during load
            [2025-02-13 16:04:02.863] [ERROR] Error: Cannot find module 'undici'
            Require stack:
            - /home/kling/MagicMirror/js/app.js
            - /home/kling/MagicMirror/js/electron.js
                at Module._resolveFilename (node:internal/modules/cjs/loader:1232:15)
                at s._resolveFilename (node:electron/js2c/browser_init:2:121498)
                at Module._resolveFilename (/home/kling/MagicMirror/node_modules/module-alias/index.js:49:29)
                at Module._load (node:internal/modules/cjs/loader:1058:27)
                at c._load (node:electron/js2c/node_init:2:17025)
                at Module.require (node:internal/modules/cjs/loader:1318:19)
                at require (node:internal/modules/helpers:179:18)
                at Object.<anonymous> (/home/kling/MagicMirror/js/app.js:15:40)
                at Module._compile (node:internal/modules/cjs/loader:1484:14)
                at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
                at Module.load (node:internal/modules/cjs/loader:1295:32)
                at Module._load (node:internal/modules/cjs/loader:1111:12)
                at Object.<anonymous> (/home/kling/MagicMirror/js/electron.js:4:14)
            A JavaScript error occurred in the main process
            Uncaught Exception:
            Require stack:
            [5112:0213/160403.943167:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [5112:0213/160403.943531:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            So my question again, what did I wrong? It is necessary to install the MMM completely new?
            Thank you.
            Kind regards.
            Klinge
              sdetweil @Klinge
              @Klinge you tried to do it manually , my script will NOT upgrade OVER the same version accidentally
              so you have to FORCE it
              change the update command string end from
              apply
              to
              force
              • K Offline
                Klinge @sdetweil
                @sdetweil Great, now it works.
                Thank you for your help again
                • T Offline
                  tleo32
                  Hello - I am receiving a similar error and struggling to resolve. Does anyone have suggestions?
                  npm error code EBADENGINE
                  npm error engine Unsupported engine
                  npm error engine Not compatible with your version of node/npm: magicmirror@2.30.0
                  npm error notsup Not compatible with your version of node/npm: magicmirror@2.30.0
                  npm error notsup Required: {“node”:“>=20.18.1 <21 || >=22”}
                  npm error notsup Actual: {“npm”:“10.8.1”,“node”:“v20.16.0”}
                  npm error A complete log of this run can be found in: /home/tleonetti/.npm/_logs/2025-02-17T00_47_21_325Z-debug-0.log
                    sdetweil @tleo32
                    @tleo32 yes, you didnt read the release notes. we need node 20.18.1 or above, not 21
                    because you started manually, use my upgrade script w force as the parm instead of apply
                    see https://github.com/sdetweil/MagicMirror_scripts
                    also https://forum.magicmirror.builders/post/123993
                    • T Offline
                      tleo32 @sdetweil
                      thank you for responding @sdetweil, for some reason not updating the node, please see below:
                      update log will be in /home/tleonetti/MagicMirror/installers/upgrade.log
                      Installed Node version: v20.16.0
                      Check current Node installation …
                      Node should be upgraded.
                      Installing Node.js …
                      force: line 323: [: too many arguments
                      tar (child): /home/tleonetti/node_release-.tar.gz: Cannot open: No such file or directory
                      tar (child): Error is not recoverable: exiting now
                      tar: Child returned status 2
                      tar: Error is not recoverable: exiting now
                      node version is
                      Node.js installation Done! version=v20.16.0
                      Check current NPM installation …
                      Installed npm version: V10.8.1
                      npm should be upgraded.
                      Installing npm …
                      npm installation Done! version=V10.8.1
                      upgrading from version 2.30.0 to 2.30.0
                      force: line 611: pm2: command not found
                      fetching latest revisions
                      npm error A complete log of this run can be found in: /home/tleonetti/.npm/_logs/2025-02-17T19_56_02_704Z-debug-0.log
                        sdetweil @tleo32
                        @tleo32 can you do this
                        curl -sL https://deb.nodesource.com/setup_20.x | sudo -E bash - &>somefile.txt
                        and send me somefile.txt via email. same userid at gmail
                        and then
                        short fix
                        sudo npm install n
                        sudo n 20.18.1
                        hash -r
                        npm run install-MagicMirror
                        please advise results
                          @tleo32 I also pushed a fix, so, rerunning the upgrade with force should work…
                            he had nvm
                            installed too, conflicts with n ( nodejs version of nvm)
