    New module installer
    51 Posts 7 Posters 25.5k Views 6 Watching
      @sdetweil said in New module installer:
      just posted another update for better handling of the repo readme (in most cases)
      and handles readme’s for repo ADDs to the 3rd party list list, deletes worked ok before
      and for the readme during config, use the file in the installed module folder, instead of trying to get the github repo version
      same process
      git pull
      git checkout better_repo_url  # if already there not needed
      npm install     # <--- required.. added another library and copies a template file
      the copy fixes a bug in the readme list file
      and if this is first time using, make sure to add
      MMM-Config to your config.js
            module:"MMM-Config"
             position:"...", // only for qrcode if you use that
              config:{
      • H
        hadal
        Hi All
        I don’t know where I made a mistake, can you help me?
          sdetweil @hadal
          @hadal did you do the npm install? and add MMM-Config to your config.js
          can you show
          in the MMM-Config folder
          do
          git branch
          ls module_url_hash.json
          in the module_installer folder
          ls module_selector_schema.json
            sdetweil
            added new url for launching the config side
            http://mm_address:mm_port/configure
            both main and better_repo_url branches
              sdetweil
              updated for missing calendar url… properties, and missing module header…
                i am considering merging the extra branches back w the base
                but its been quiet, so i am not sure if there are other changes, or if ive got the functionality right
                any feedback welcomed
                  now merged w base branch, main
                  • F
                    furqanhamid @sdetweil
                    This is awesome! Having a streamlined, end-to-end solution for modules will make setting up MM so much easier. Appreciate the effort. BTW, I am still confused that whether it is still working or not!
                      sdetweil @furqanhamid
                      @furqanhamid which says you didnt try it.
                        Anybody try this and have any feedback?
                          Just added search in the installer
                          • 3 / 3
