Can´t rotate my display
20 Posts 4 Posters 3.2k Views 4 Watching
    rkorell @robertybob
    @robertybob yes, screen rotation is still possible via CLI/terminal…
    edit “/usr/share/dispsetup.sh”
    eg:
    sudo nano /usr/share/dispsetup.sh
    there you will find an if clause at the beginning:
    if ! raspi-config nonint is_pi || raspi-config nonint is_kms ; then
    if xrandr --output HDMI-1 --primary --mode 2560x1440 --rate 59.951 --pos 0x0 --rotate left --dryrun>
    the word after “rotate” defines the rotation :-)
    NO rotation = “normal”, rest is obvious.
    You must change this in both occurances.
    In same statement you define the resolution for the screen, as well - after “mode”(given example 2560x1440)
    HTH
    Regards,
    Ralf
    R 1 Reply Last reply Mar 10, 2025, 5:30 PM Reply Quote 1
      robertybob @rkorell
      @rkorell
      Mine looks a little different :(
      R 1 Reply Last reply Mar 10, 2025, 6:27 PM Reply Quote 1
        robertybob @sdetweil
        @sdetweil The code has seemingly changed
        That didn’t work, but
        wlr-randr --output HDMI-A-1 --transform 90
        does! Except… when I reboot, the screen goes back to the way it was
        S 1 Reply Last reply Mar 10, 2025, 5:54 PM Reply Quote 0
          sdetweil @robertybob
          @robertybob did you see the section on autostart? as the
          wlr-randr is not persistent
          R 1 Reply Last reply Mar 10, 2025, 6:05 PM Reply Quote 0
            @sdetweil Ah, I couldn’t find the folder as it’s not in /.config/labwc/autostart but instead appears to be /usr/share/labwc
            I’ll give that a go! Thank you :D
            S 1 Reply Last reply Mar 10, 2025, 6:09 PM Reply Quote 0
              @robertybob .config is usually in the user folder (note the . in front)
                rkorell @robertybob
                @robertybob said in Can´t rotate my display:
                OK, that’s bad…
                (It’s a Pi5, right?).
                The complete content of my dispsetup.sh is as follows:
                #!/bin/sh
                fi
                fi
                if [ -e /usr/share/tssetup.sh ] ; then
                . /usr/share/tssetup.sh
                fi
                if [ -e /usr/share/ovscsetup.sh ] ; then
                . /usr/share/ovscsetup.sh
                fi
                exit 0
                If I interpret your line correctly, you are using the Wayland-Window-Manager?
                (wlandr => wayland … ???).
                My box is a Pi4B, no wayland.
                I’ve seen elsewhere that the Pi5 can be forced to use X11 again - than the above should work directly.
                Otherwise you may give it a try to put your code into the dispsetup.sh?
                Here I found the description of your commandlines above. Unfortunately there is no description how to get this pesistent…
                In Addition I just found a hint in Raspberry-Forum
                There a guy stated:
                sudo nano .config/wayfire.ini
                -> scrolled down and changed the output section as below:
                [output:HDMI-A-1]
                mode = 1920X1080@60000
                position = 0,0
                transform = 90
                May this is the right way with wayland…
                Regards,
                Ralf
                R 1 Reply Last reply Mar 10, 2025, 10:09 PM Reply Quote 1
                  robertybob @rkorell
                  @rkorell Ah, sorry, I’m using a Raspberry Pi 3 :)
                  Nothing I’ve tried has worked so far, even ChatGPT is failing me :(
                  S R 2 Replies Last reply Mar 10, 2025, 10:33 PM Reply Quote 0
                    @robertybob go back the x11 in raspi-config
                      rkorell @robertybob
                      Raspberry Pi 3 :)
                      May this in combination with bookworm?
                      Sam acknowledged my assumption a posting above…
                      • back to X11 …
                      Regards,
                      Ralf
                      2 / 2
