    Can´t rotate my display
    20 Posts 4 Posters 7.3k Views 4 Watching
      sdetweil @robertybob
      @robertybob i do not know
        @robertybob google search found this
        To rotate the display using the command line on a Raspberry Pi with the LabWC compositor, you can use the wlr-randr command, specifying the output and desired rotation (e.g., wlr-randr --output HDMI-A-1 --rotate right).
        Here's a more detailed breakdown:
        1. Identify your output:
        Determine the name of your display output. You can find this using wlr-randr without any arguments, which will list the available outputs.
        Example: wlr-randr
        Look for an output like HDMI-A-1 or DSI-0.
        2. Rotate the display:
        Use the wlr-randr command with the --output and --rotate options.
        Example (rotate 90 degrees clockwise): wlr-randr --output HDMI-A-1 --rotate right
        Example (rotate 90 degrees counter-clockwise): wlr-randr --output HDMI-A-1 --rotate left
        Example (rotate 180 degrees): wlr-randr --output HDMI-A-1 --rotate 180
        Example (rotate to normal orientation): wlr-randr --output HDMI-A-1 --rotate normal
        3. Make the rotation permanent (optional):
        You can add the wlr-randr command to an autostart file to make the rotation persistent after a reboot.
        Find the autostart file: ~/.config/labwc/autostart
        Add your command: Open the file in a text editor (e.g., nano ~/.config/labwc/autostart) and add the wlr-randr command at the end of the file.
        Example: @wlr-randr --output HDMI-A-1 --rotate right
        Note: The @ symbol is important for autostart scripts.
        4. Troubleshooting:
          rkorell Module Developer @robertybob
          @robertybob yes, screen rotation is still possible via CLI/terminal…
          edit “/usr/share/dispsetup.sh”
          eg:
          sudo nano /usr/share/dispsetup.sh
          there you will find an if clause at the beginning:
          if ! raspi-config nonint is_pi || raspi-config nonint is_kms ; then
          if xrandr --output HDMI-1 --primary --mode 2560x1440 --rate 59.951 --pos 0x0 --rotate left --dryrun>
          the word after “rotate” defines the rotation :-)
          NO rotation = “normal”, rest is obvious.
          You must change this in both occurances.
          In same statement you define the resolution for the screen, as well - after “mode”(given example 2560x1440)
          HTH
          Regards,
          Ralf
            robertybob @rkorell
            @rkorell
            Mine looks a little different :(
              robertybob @sdetweil
              @sdetweil The code has seemingly changed
              That didn’t work, but
              wlr-randr --output HDMI-A-1 --transform 90
              does! Except… when I reboot, the screen goes back to the way it was
                @robertybob did you see the section on autostart? as the
                wlr-randr is not persistent
                  @sdetweil Ah, I couldn’t find the folder as it’s not in /.config/labwc/autostart but instead appears to be /usr/share/labwc
                  I’ll give that a go! Thank you :D
                    @robertybob .config is usually in the user folder (note the . in front)
                      @robertybob said in Can´t rotate my display:
                      OK, that’s bad…
                      (It’s a Pi5, right?).
                      The complete content of my dispsetup.sh is as follows:
                      #!/bin/sh
                      fi
                      fi
                      if [ -e /usr/share/tssetup.sh ] ; then
                      . /usr/share/tssetup.sh
                      fi
                      if [ -e /usr/share/ovscsetup.sh ] ; then
                      . /usr/share/ovscsetup.sh
                      fi
                      exit 0
                      If I interpret your line correctly, you are using the Wayland-Window-Manager?
                      (wlandr => wayland … ???).
                      My box is a Pi4B, no wayland.
                      I’ve seen elsewhere that the Pi5 can be forced to use X11 again - than the above should work directly.
                      Otherwise you may give it a try to put your code into the dispsetup.sh?
                      Here I found the description of your commandlines above. Unfortunately there is no description how to get this pesistent…
                      In Addition I just found a hint in Raspberry-Forum
                      There a guy stated:
                      sudo nano .config/wayfire.ini
                      -> scrolled down and changed the output section as below:
                      [output:HDMI-A-1]
                      mode = 1920X1080@60000
                      position = 0,0
                      transform = 90
                      May this is the right way with wayland…
                      Regards,
                      Ralf
                        robertybob @rkorell
                        @rkorell Ah, sorry, I’m using a Raspberry Pi 3 :)
                        Nothing I’ve tried has worked so far, even ChatGPT is failing me :(
                        S R 2 Replies Last reply Reply Quote 0
                          @robertybob go back the x11 in raspi-config
                            Raspberry Pi 3 :)
                            May this in combination with bookworm?
                            Sam acknowledged my assumption a posting above…
                            • back to X11 …
                            Regards,
                            Ralf
