    Can´t rotate my display
    20 Posts 4 Posters 6.9k Views 4 Watching
    • K Offline
      Klinge
      I have just reinstalled my MMM. Everything is fine except the last step.
      I am trying to rotate my display 90 degrees clockwise. To do this, I have added
      /boot/firmware/config.txt
      I commented out the line following line
      # dtoverlay=vc4-kms-v3d
      and added the line
      display_hdmi_rotate=1
      underneath
      But by commenting the line out, the Raspi no longer starts correctly. Only a black screen appears.
      The operating system is already started. I can still access it via SSH. But I can see only a black screen.
      As soon as I uncomment the line
      again, the Raspi starts correctly. But then the screen is not rotated, even though I have not deleted the line
      It would be great if you could help me again.
      Than in advance
      Klinge
        sdetweil @Klinge
        @Klinge which version of the OS did you install??
        with the Wayland compositor
        or the latest with the LabWC compositor
        they are different on how to rotate than the old X11
        • K Offline
          Klinge @sdetweil
          @sdetweil I use
          Raspberry Pi OS with desktop
          Release date: November 19th 2024
          System: 64-bit
          Kernel version: 6.6
          Debian version: 12 (bookworm)
          and a Raspberry 3 Model b+
            sdetweil @Klinge
            @Klinge ok, do
            ps -ef | grep labwc
            i think it will return the labwc compositor process info
            • K Offline
              Klinge @sdetweil
              @sdetweil I got the following infos
              pi@raspi-mm-bad:~ $ ps -ef | grep labwc
              pi           645     619 42 16:50 ?        00:35:55 /usr/bin/labwc -m
              pi           714     645  0 16:50 ?        00:00:00 /usr/bin/ssh-agent /usr/bin/labwc-pi
              pi         33729   32904 25 18:15 pts/0    00:00:00 grep --color=auto labwc
                sdetweil @Klinge
                @Klinge if you use the os desktop menu top left, preferences, last entry i think is display configuration, you can rotate there
                K R 2 Replies Last reply Reply Quote 1
                • K Offline
                  Klinge @sdetweil
                  @sdetweil Oh! So simple? It is like at Windows. Only with mouse configuration. I found it under Screen configuration - > orientation
                  Thank you again for your help. You are my little hero 😉
                  • K Klinge has marked this topic as solved on
                    robertybob @sdetweil
                    @sdetweil Is it still possible to rotate the screen via the command line? Or must it be done using the desktop? (having the same issue, with the same labwc output, so thought best not to start a new topic)
                    S R 3 Replies Last reply Reply Quote 0
                      sdetweil @robertybob
                      @robertybob i do not know
                        @robertybob google search found this
                        To rotate the display using the command line on a Raspberry Pi with the LabWC compositor, you can use the wlr-randr command, specifying the output and desired rotation (e.g., wlr-randr --output HDMI-A-1 --rotate right).
                        Here's a more detailed breakdown:
                        1. Identify your output:
                        Determine the name of your display output. You can find this using wlr-randr without any arguments, which will list the available outputs.
                        Example: wlr-randr
                        Look for an output like HDMI-A-1 or DSI-0.
                        2. Rotate the display:
                        Use the wlr-randr command with the --output and --rotate options.
                        Example (rotate 90 degrees clockwise): wlr-randr --output HDMI-A-1 --rotate right
                        Example (rotate 90 degrees counter-clockwise): wlr-randr --output HDMI-A-1 --rotate left
                        Example (rotate 180 degrees): wlr-randr --output HDMI-A-1 --rotate 180
                        Example (rotate to normal orientation): wlr-randr --output HDMI-A-1 --rotate normal
                        3. Make the rotation permanent (optional):
                        You can add the wlr-randr command to an autostart file to make the rotation persistent after a reboot.
                        Find the autostart file: ~/.config/labwc/autostart
                        Add your command: Open the file in a text editor (e.g., nano ~/.config/labwc/autostart) and add the wlr-randr command at the end of the file.
                        Example: @wlr-randr --output HDMI-A-1 --rotate right
                        Note: The @ symbol is important for autostart scripts.
                        4. Troubleshooting:
                          rkorell Module Developer @robertybob
                          @robertybob yes, screen rotation is still possible via CLI/terminal…
                          edit “/usr/share/dispsetup.sh”
                          eg:
                          sudo nano /usr/share/dispsetup.sh
                          there you will find an if clause at the beginning:
                          if ! raspi-config nonint is_pi || raspi-config nonint is_kms ; then
                          if xrandr --output HDMI-1 --primary --mode 2560x1440 --rate 59.951 --pos 0x0 --rotate left --dryrun>
                          the word after “rotate” defines the rotation :-)
                          NO rotation = “normal”, rest is obvious.
                          You must change this in both occurances.
                          In same statement you define the resolution for the screen, as well - after “mode”(given example 2560x1440)
                          HTH
                          Regards,
                          Ralf
                            robertybob @rkorell
                            @rkorell
                            Mine looks a little different :(
                              @sdetweil The code has seemingly changed
                              That didn’t work, but
                              wlr-randr --output HDMI-A-1 --transform 90
                              does! Except… when I reboot, the screen goes back to the way it was
                                @robertybob did you see the section on autostart? as the
                                wlr-randr is not persistent
                                  @sdetweil Ah, I couldn’t find the folder as it’s not in /.config/labwc/autostart but instead appears to be /usr/share/labwc
                                  I’ll give that a go! Thank you :D
                                    @robertybob .config is usually in the user folder (note the . in front)
                                      @robertybob said in Can´t rotate my display:
                                      OK, that’s bad…
                                      (It’s a Pi5, right?).
                                      The complete content of my dispsetup.sh is as follows:
                                      #!/bin/sh
                                      fi
                                      fi
                                      if [ -e /usr/share/tssetup.sh ] ; then
                                      . /usr/share/tssetup.sh
                                      fi
                                      if [ -e /usr/share/ovscsetup.sh ] ; then
                                      . /usr/share/ovscsetup.sh
                                      fi
                                      exit 0
                                      If I interpret your line correctly, you are using the Wayland-Window-Manager?
                                      (wlandr => wayland … ???).
                                      My box is a Pi4B, no wayland.
                                      I’ve seen elsewhere that the Pi5 can be forced to use X11 again - than the above should work directly.
                                      Otherwise you may give it a try to put your code into the dispsetup.sh?
                                      Here I found the description of your commandlines above. Unfortunately there is no description how to get this pesistent…
                                      In Addition I just found a hint in Raspberry-Forum
                                      There a guy stated:
                                      sudo nano .config/wayfire.ini
                                      -> scrolled down and changed the output section as below:
                                      [output:HDMI-A-1]
                                      mode = 1920X1080@60000
                                      position = 0,0
                                      transform = 90
                                      May this is the right way with wayland…
                                      Regards,
                                      Ralf
                                        robertybob @rkorell
                                        @rkorell Ah, sorry, I’m using a Raspberry Pi 3 :)
                                        Nothing I’ve tried has worked so far, even ChatGPT is failing me :(
                                        S R 2 Replies Last reply Reply Quote 0
                                          @robertybob go back the x11 in raspi-config
                                            Raspberry Pi 3 :)
                                            May this in combination with bookworm?
                                            Sam acknowledged my assumption a posting above…
                                            • back to X11 …
                                            Regards,
                                            Ralf
