    Can´t rotate my display
    20 Posts 4 Posters 7.5k Views 4 Watching
      rkorell Module Developer @robertybob
      @robertybob yes, screen rotation is still possible via CLI/terminal…
      edit “/usr/share/dispsetup.sh”
      eg:
      sudo nano /usr/share/dispsetup.sh
      there you will find an if clause at the beginning:
      if ! raspi-config nonint is_pi || raspi-config nonint is_kms ; then
      if xrandr --output HDMI-1 --primary --mode 2560x1440 --rate 59.951 --pos 0x0 --rotate left --dryrun>
      the word after “rotate” defines the rotation :-)
      NO rotation = “normal”, rest is obvious.
      You must change this in both occurances.
      In same statement you define the resolution for the screen, as well - after “mode”(given example 2560x1440)
      HTH
      Regards,
      Ralf
      R 1 Reply Last reply
        robertybob @rkorell
        @rkorell
        Mine looks a little different :(
          robertybob @sdetweil
          @sdetweil The code has seemingly changed
          That didn’t work, but
          wlr-randr --output HDMI-A-1 --transform 90
          does! Except… when I reboot, the screen goes back to the way it was
            sdetweil @robertybob
            @robertybob did you see the section on autostart? as the
            wlr-randr is not persistent
              @sdetweil Ah, I couldn’t find the folder as it’s not in /.config/labwc/autostart but instead appears to be /usr/share/labwc
              I’ll give that a go! Thank you :D
                @robertybob .config is usually in the user folder (note the . in front)
                  @robertybob said in Can´t rotate my display:
                  OK, that’s bad…
                  (It’s a Pi5, right?).
                  The complete content of my dispsetup.sh is as follows:
                  #!/bin/sh
                  fi
                  fi
                  if [ -e /usr/share/tssetup.sh ] ; then
                  . /usr/share/tssetup.sh
                  fi
                  if [ -e /usr/share/ovscsetup.sh ] ; then
                  . /usr/share/ovscsetup.sh
                  fi
                  exit 0
                  If I interpret your line correctly, you are using the Wayland-Window-Manager?
                  (wlandr => wayland … ???).
                  My box is a Pi4B, no wayland.
                  I’ve seen elsewhere that the Pi5 can be forced to use X11 again - than the above should work directly.
                  Otherwise you may give it a try to put your code into the dispsetup.sh?
                  Here I found the description of your commandlines above. Unfortunately there is no description how to get this pesistent…
                  In Addition I just found a hint in Raspberry-Forum
                  There a guy stated:
                  sudo nano .config/wayfire.ini
                  -> scrolled down and changed the output section as below:
                  [output:HDMI-A-1]
                  mode = 1920X1080@60000
                  position = 0,0
                  transform = 90
                  May this is the right way with wayland…
                  Regards,
                  Ralf
                    robertybob @rkorell
                    @rkorell Ah, sorry, I’m using a Raspberry Pi 3 :)
                    Nothing I’ve tried has worked so far, even ChatGPT is failing me :(
                    S R 2 Replies Last reply
                      @robertybob go back the x11 in raspi-config
                        Raspberry Pi 3 :)
                        May this in combination with bookworm?
                        Sam acknowledged my assumption a posting above…
                        • back to X11 …
                        Regards,
                        Ralf
