    Can´t rotate my display
    20 Posts 4 Posters 7.3k Views 4 Watching
      robertybob @sdetweil
      @sdetweil Is it still possible to rotate the screen via the command line? Or must it be done using the desktop? (having the same issue, with the same labwc output, so thought best not to start a new topic)
      S R 3 Replies Last reply Reply Quote 0
        sdetweil @robertybob
        @robertybob i do not know
          @robertybob google search found this
          To rotate the display using the command line on a Raspberry Pi with the LabWC compositor, you can use the wlr-randr command, specifying the output and desired rotation (e.g., wlr-randr --output HDMI-A-1 --rotate right).
          Here's a more detailed breakdown:
          1. Identify your output:
          Determine the name of your display output. You can find this using wlr-randr without any arguments, which will list the available outputs.
          Example: wlr-randr
          Look for an output like HDMI-A-1 or DSI-0.
          2. Rotate the display:
          Use the wlr-randr command with the --output and --rotate options.
          Example (rotate 90 degrees clockwise): wlr-randr --output HDMI-A-1 --rotate right
          Example (rotate 90 degrees counter-clockwise): wlr-randr --output HDMI-A-1 --rotate left
          Example (rotate 180 degrees): wlr-randr --output HDMI-A-1 --rotate 180
          Example (rotate to normal orientation): wlr-randr --output HDMI-A-1 --rotate normal
          3. Make the rotation permanent (optional):
          You can add the wlr-randr command to an autostart file to make the rotation persistent after a reboot.
          Find the autostart file: ~/.config/labwc/autostart
          Add your command: Open the file in a text editor (e.g., nano ~/.config/labwc/autostart) and add the wlr-randr command at the end of the file.
          Example: @wlr-randr --output HDMI-A-1 --rotate right
          Note: The @ symbol is important for autostart scripts.
          4. Troubleshooting:
            rkorell Module Developer @robertybob
            @robertybob yes, screen rotation is still possible via CLI/terminal…
            edit “/usr/share/dispsetup.sh”
            eg:
            sudo nano /usr/share/dispsetup.sh
            there you will find an if clause at the beginning:
            if ! raspi-config nonint is_pi || raspi-config nonint is_kms ; then
            if xrandr --output HDMI-1 --primary --mode 2560x1440 --rate 59.951 --pos 0x0 --rotate left --dryrun>
            the word after “rotate” defines the rotation :-)
            NO rotation = “normal”, rest is obvious.
            You must change this in both occurances.
            In same statement you define the resolution for the screen, as well - after “mode”(given example 2560x1440)
            HTH
            Regards,
            Ralf
              robertybob @rkorell
              @rkorell
              Mine looks a little different :(
                @sdetweil The code has seemingly changed
                That didn’t work, but
                wlr-randr --output HDMI-A-1 --transform 90
                does! Except… when I reboot, the screen goes back to the way it was
                  @robertybob did you see the section on autostart? as the
                  wlr-randr is not persistent
                    @sdetweil Ah, I couldn’t find the folder as it’s not in /.config/labwc/autostart but instead appears to be /usr/share/labwc
                    I’ll give that a go! Thank you :D
                      @robertybob .config is usually in the user folder (note the . in front)
                        @robertybob said in Can´t rotate my display:
                        OK, that’s bad…
                        (It’s a Pi5, right?).
                        The complete content of my dispsetup.sh is as follows:
                        #!/bin/sh
                        fi
                        fi
                        if [ -e /usr/share/tssetup.sh ] ; then
                        . /usr/share/tssetup.sh
                        fi
                        if [ -e /usr/share/ovscsetup.sh ] ; then
                        . /usr/share/ovscsetup.sh
                        fi
                        exit 0
                        If I interpret your line correctly, you are using the Wayland-Window-Manager?
                        (wlandr => wayland … ???).
                        My box is a Pi4B, no wayland.
                        I’ve seen elsewhere that the Pi5 can be forced to use X11 again - than the above should work directly.
                        Otherwise you may give it a try to put your code into the dispsetup.sh?
                        Here I found the description of your commandlines above. Unfortunately there is no description how to get this pesistent…
                        In Addition I just found a hint in Raspberry-Forum
                        There a guy stated:
                        sudo nano .config/wayfire.ini
                        -> scrolled down and changed the output section as below:
                        [output:HDMI-A-1]
                        mode = 1920X1080@60000
                        position = 0,0
                        transform = 90
                        May this is the right way with wayland…
                        Regards,
                        Ralf
                          robertybob @rkorell
                          @rkorell Ah, sorry, I’m using a Raspberry Pi 3 :)
                          Nothing I’ve tried has worked so far, even ChatGPT is failing me :(
                          S R 2 Replies Last reply Reply Quote 0
                            @robertybob go back the x11 in raspi-config
                              Raspberry Pi 3 :)
                              May this in combination with bookworm?
                              Sam acknowledged my assumption a posting above…
                              • back to X11 …
                              Regards,
                              Ralf
