    Can´t rotate my display
    20 Posts 4 Posters 5.0k Views 4 Watching
    • K Offline
      Klinge @sdetweil
      @sdetweil I got the following infos
      pi@raspi-mm-bad:~ $ ps -ef | grep labwc
      pi           645     619 42 16:50 ?        00:35:55 /usr/bin/labwc -m
      pi           714     645  0 16:50 ?        00:00:00 /usr/bin/ssh-agent /usr/bin/labwc-pi
      pi         33729   32904 25 18:15 pts/0    00:00:00 grep --color=auto labwc
        sdetweil @Klinge
        @Klinge if you use the os desktop menu top left, preferences, last entry i think is display configuration, you can rotate there
        K R 2 Replies Last reply Reply Quote 1
        • K Offline
          Klinge @sdetweil
          @sdetweil Oh! So simple? It is like at Windows. Only with mouse configuration. I found it under Screen configuration - > orientation
          Thank you again for your help. You are my little hero 😉
          • K Klinge has marked this topic as solved on
            robertybob @sdetweil
            @sdetweil Is it still possible to rotate the screen via the command line? Or must it be done using the desktop? (having the same issue, with the same labwc output, so thought best not to start a new topic)
            S R 3 Replies Last reply Reply Quote 0
              sdetweil @robertybob
              @robertybob i do not know
                @robertybob google search found this
                To rotate the display using the command line on a Raspberry Pi with the LabWC compositor, you can use the wlr-randr command, specifying the output and desired rotation (e.g., wlr-randr --output HDMI-A-1 --rotate right).
                Here's a more detailed breakdown:
                1. Identify your output:
                Determine the name of your display output. You can find this using wlr-randr without any arguments, which will list the available outputs.
                Example: wlr-randr
                Look for an output like HDMI-A-1 or DSI-0.
                2. Rotate the display:
                Use the wlr-randr command with the --output and --rotate options.
                Example (rotate 90 degrees clockwise): wlr-randr --output HDMI-A-1 --rotate right
                Example (rotate 90 degrees counter-clockwise): wlr-randr --output HDMI-A-1 --rotate left
                Example (rotate 180 degrees): wlr-randr --output HDMI-A-1 --rotate 180
                Example (rotate to normal orientation): wlr-randr --output HDMI-A-1 --rotate normal
                3. Make the rotation permanent (optional):
                You can add the wlr-randr command to an autostart file to make the rotation persistent after a reboot.
                Find the autostart file: ~/.config/labwc/autostart
                Add your command: Open the file in a text editor (e.g., nano ~/.config/labwc/autostart) and add the wlr-randr command at the end of the file.
                Example: @wlr-randr --output HDMI-A-1 --rotate right
                Note: The @ symbol is important for autostart scripts.
                4. Troubleshooting:
                  rkorell @robertybob
                  @robertybob yes, screen rotation is still possible via CLI/terminal…
                  edit “/usr/share/dispsetup.sh”
                  eg:
                  sudo nano /usr/share/dispsetup.sh
                  there you will find an if clause at the beginning:
                  if ! raspi-config nonint is_pi || raspi-config nonint is_kms ; then
                  if xrandr --output HDMI-1 --primary --mode 2560x1440 --rate 59.951 --pos 0x0 --rotate left --dryrun>
                  the word after “rotate” defines the rotation :-)
                  NO rotation = “normal”, rest is obvious.
                  You must change this in both occurances.
                  In same statement you define the resolution for the screen, as well - after “mode”(given example 2560x1440)
                  HTH
                  Regards,
                  Ralf
                    robertybob @rkorell
                    @rkorell
                    Mine looks a little different :(
                      @sdetweil The code has seemingly changed
                      That didn’t work, but
                      wlr-randr --output HDMI-A-1 --transform 90
                      does! Except… when I reboot, the screen goes back to the way it was
                        @robertybob did you see the section on autostart? as the
                        wlr-randr is not persistent
