    MMM-PublicTransportHafas: Service Temporarily Unavailable
    29 Posts 8 Posters 9.9k Views 9 Watching
    • O
      othomys
      Hello everyone
      I have been using the tool MMM-PublicTransportHafas for a few years now. So far, I have had no problems with it. But since yesterday, the gadget no longer works. Only the heading and the message “Service Temporarily Unavailable” are displayed.
      A few days before I updated to the latest Raspbian version and the latest MM version. After that, however, MMM-PublicTransportHafas still worked. Only a few days without change did the problem occur.
      Restarting the system did not bring any change. Connection to the internet is available - at least my other modules work.
      Does anyone have an idea why this is?
      Here is my configuration:
      module: "MMM-PublicTransportHafas",
      				stationID: "954693",
      				stationName: "Georg-Schwarz-Str./Merseburger-Str.  ",
        				direction: "",
      				ignoredLines: [],
      				excludedTransportationTypes: [],
      				timeToStation: 5,
      				showColoredLineSymbols: false,
      				useColorForRealtimeInfo: true,
      				showTableHeadersAsSymbols: true,
      				maxUnreachableDepartures: 0,
      				maxReachableDepartures: 3,
      				customLineStyles: "",
      				showOnlyLineNumbers: true,
      				marqueeLongDirections: false,
      				showAbsoluteTime: false,
      				fadeUnreachableDepartures: false,
      				fadeReachableDepartures: false,
      Thank you :-)
      evroomE KristjanESPERANTOK 2 Replies Last reply
      • P
        p1lspeda
        I cannot help you, as I do not have a solution.
        BUT: I have the exact same problem
                                        stationID: "000405041",                   // Replace with your stationID!
                                        stationName: "Höfchen/Listmann",   // Replace with your station name!
                                        direction: "",                    // Show only departures heading to this station. (A station ID.)
                                        ignoredLines: [],                 // Which lines should be ignored? (comma-separated list of line names)
                                        excludedTransportationTypes: [],  // Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: StN for >
                                        timeToStation: 10,                // How long do you need to walk to the next Station?
                                        showColoredLineSymbols: true,     // Want colored line symbols?
                                        useColorForRealtimeInfo: true,    // Want colored real time information (timeToStation, early)?
                                        showTableHeadersAsSymbols: true,  // Table Headers as symbols or text?
                                        maxUnreachableDepartures: 0,      // How many unreachable departures should be shown?
                                        maxReachableDepartures: 10,        // How many reachable departures should be shown?
                                        customLineStyles: "",             // Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitive)
                                        showOnlyLineNumbers: false        // Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
                                        stationID: "008003816",                   // Replace with your stationID!
                                        stationName: "Römisches Theater",   // Replace with your station name!
                                        excludedTransportationTypes: [],  // Which transportation types should not be shown on the mirror? (comma-separated l$
                                        timeToStation: 5,                // How long do you need to walk to the next Station?
                                        customLineStyles: "",             // Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitiv$
                                        showOnlyLineNumbers: false        // Display only the line number instead of the complete name, i. e. "11" instead of$
        evroomE 1 Reply Last reply
        • evroomE
          evroom
          Seems that DB made the service, as used by Hafas, unavailable.
          https://reiseauskunft.bahn.de
          503 Service Temporarily Unavailable
          Also other programs using it have this problem.
          Can only hope that there is or there will be an alternative source.
          It is the one of the 3 most used MagicMirror modules in our household.
          MagicMirror version: 2.37.0
          • evroomE
            evroom @evroom
            Possible work-around.
            Needs travelling via Austria :-)
            To check if your station is available:
            $ cd ~/MagicMirror/modules/MMM-PublicTransportHafas
            $ npm run query oebb
            > mmm-publictransporthafas@2.1.13 query
            > node ./convenience/query_stations.mjs oebb
            Using hafas-client profile: oebb
            Enter an address or station name:
            This will give you a station Id.
            Update config.js:
            $ vi ~/MagicMirror/config/config.js
                  hafasProfile: "oebb",
                  stationID: "<ID>",
                  stationName: "<Stop>",
            For me the list appears again, although I do not see the real-time times, meaning it shows the ⚠ symbol (as set in noRealtimeDelayString: "⚠",).
            One can try different hafas-client profiles, listed in:
            https://github.com/public-transport/hafas-client/blob/main/p/readme.md
            When you are lucky there is a good alternative to db.
            Reply Quote 1
            • evroomE
              evroom @othomys
              @othomys said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
              For you I found this one:
              $ npm run query insa
              Enter an address or station name: Georg-Schwarz
              Stops found for 'Georg-Schwarz':
               > Stop: Leipzig, Georg-Schwarz-/Merseburger Str.
                 Transport product(s): Tram, Bus
              So your config will be:
                    hafasProfile: "insa",
                    stationID: "12555",
                    stationName: "Georg-Schwarz-Str./Merseburger-Str.",
              Reply Quote 1
              • evroomE
                evroom @p1lspeda
                @p1lspeda said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
                Höfchen/Listmann
                For you, try this:
                $ npm run query rmv
                Using hafas-client profile: rmv
                Enter an address or station name: Höfchen/Listmann
                Stops found for 'Höfchen/Listmann':
                 > Stop: MZ Höfchen/Listmann
                   Transport product(s): Bus
                Config:
                     hafasProfile: "rmv",
                     stationID: "3029051",
                Reply Quote 1
                  sdetweil @evroom
                  @evroom what folder to be in??
                  • evroomE
                    evroom @sdetweil
                    Reply Quote 1
                    • KristjanESPERANTOK
                      KristjanESPERANTO Module Developer @othomys
                      @othomys I have a solution, just need a bit time to implement it properly. I’ll try to bring out a new release at the weekend :-)
                      KristjanESPERANTOK 1 Reply Last reply
                      Reply Quote 2
                        KristjanESPERANTO Module Developer @KristjanESPERANTO
                        New release 3.0.0 is out 👩‍💻. Please update the module and test it 🚊⏰😀
                        MZ-BERM 1 Reply Last reply
                        Reply Quote 2
                        • MZ-BERM
                          MZ-BER @KristjanESPERANTO
                          @KristjanESPERANTO thanks for the update but it is still not working. I haven’t checked the log yet but will let you know later the day.
                            KristjanESPERANTO Module Developer @MZ-BER
                            @MZ-BER How did you do the update?
                            git pull
                            npm ci
                            evroomE MZ-BERM 2 Replies Last reply
                            Reply Quote 1
                            • evroomE
                              evroom @KristjanESPERANTO
                              @KristjanESPERANTO
                              I did the update and it is looking much better now.
                              I reverted back to db (npm run query dbis working again).
                              Only one thing I noticed:
                              On display (last update 11:15)
                              11:08 +1.0333333333333334
                              11:28 +0
                              The 11:08 entry is in the past (maxUnreachableDepartures: 2,).
                              The +1.0333333333333334 is a bit too much :-)
                              Reply Quote 2
                              • MZ-BERM
                                @KristjanESPERANTO I missed the npm ci. Now it is working as expected. Thank you 😊
                                Reply Quote 1
                                  KristjanESPERANTO Module Developer @evroom
                                  @evroom said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
                                  I just released version 3.0.1 to fix this 😀
                                  evroomE V 2 Replies Last reply
                                  • evroomE
                                    @KristjanESPERANTO said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
                                    At this moment I see an entry in the past with +0.5.
                                    Also saw +0.6.
                                    When turning on debug, I only see delay values of 0, 60 and null, so I wonder where the current 0.5 comes from.
                                    The values for when and plannedWhen all have a difference of 0 or 1 minute.
                                    It seems that it only affects the first entry in the list, which in my case is the first unreachable in the past.
                                    And it does not really bother me, but it still is odd.
                                    • V
                                      Volkae @KristjanESPERANTO
                                      @KristjanESPERANTO
                                      I did the update
                                      git pull
                                      npm ci
                                      but it still does not work.
                                      Any idea??
                                      V 1 Reply Last reply
                                      • V
                                        Volkae @Volkae
                                        @Volkae
                                        pi@magicmirror-buero:~/MagicMirror/modules/MMM-PublicTransportHafas $ npm ci
                                        npm warn deprecated vbb-translate-ids@3.1.0: Deprecated. Use vbb-translate-ids@latest.
                                        npm warn deprecated hafas-client@2.10.4: Deprecated. Use hafas-client@latest.
                                          KristjanESPERANTO Module Developer @Volkae
                                          @Volkae Looks like you don’t use my fork. I recommend deleting the module and install this: https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas
                                          S V 2 Replies Last reply
                                            sdetweil @KristjanESPERANTO
                                            I think to be more clear, deleting the module folder
