    Version 2.30.0 weather module, stuck loading, worked fine before upgrade
    52 Posts 6 Posters 33.7k Views 7 Watching
    • butchkemperB
      butchkemper
      The configuration parameters I use are:
      module "MMM-OpenWeatherForecase"
      latitude and NOT lat
      longitude and NOT lon
      apikey and NOT apiKey   <----  Notice the "K"
      Some MM configuration keywords have abbreviations but not all. The module README file gives the values for the keywords.
      Also, since your apikey has been revealed to the world, you should cancel the posted key and generate a new key. Always keep the apikey secret.
      Butch
      Resistance is not Futile!
      It is voltage divided by current.
      • butchkemperB
        butchkemper
        @sdetweil I noticed this discretion between the Weather module documentation:
        • The “Weather” documentation has “apiKey” - large case “K”,
        • The “MMM-OpenWeatherForecast” documentation has “apikey” - small case “k”.
        Butch
          sdetweil @butchkemper
          @butchkemper modules can go anything they want
          what is used internally can be anything required
          I looked at the doc for the default weather module before posting above. as there are two instances, one works the other doesn’t. apikey is the issue
          • S sdetweil marked this topic as a regular topic on
          • AssassinsA
            Assassins
            Work on 2.29.0 with api2.5
            But now on 2.33.0
            It say “NaN”
            I get the error 401, it say the apiKey i wrong, but is write from my api key from the website.
            How can i get a apiKey to api3.0 without to paid for it. ???
            The api2.5 still work, but not on this modul.
                  module: 'weather',
                  position: 'bottom_left',
                  header: 'Ballerup',
                     lat: "55.7317",
                     lon: "12.3633",
                     apiKey: "xxxxx765xxxx98xxxjhx888"
              sdetweil @Assassins
              @Assassins you cannot get V3 apikey from open weather without providing a credit card.
              they don’t charge unless you go over 1000/request per day.
              now, you CAN make 2.5 work (if they still accept api requests they keep telling us they are going to do (have done!!)) just be warned that they can/will end this function sometime…
              in the module config section
              apiKey: 2.5_key
              apiVersion: 2.5
              and
              weatherEndpoint: “current” OR “forecast”
              edited
              AssassinsA 1 Reply Last reply Reply Quote 0
              • AssassinsA
                Assassins @sdetweil
                I can only see the header now, where is write Ballerup
                  module: 'weather',
                  header: 'Ballerup',
                    apiVersion: "2.5",
                    weatherEndpoint: "/current",
                     lat: "55.7317",
                     lon: "12.3633",
                  sdetweil @Assassins
                  @Assassins
                  sorry
                  weatherEndpoint: “current” or 'forecast" , no /
                  also, the old api use location or locationID, not lat/lon
                  and I see you can’t look them up anymore on OWM site
                  here is from the old doc
                  locationID	Location ID from OpenWeatherMap This will override anything you put in location.
                  Leave blank if you want to use location. <------=======
                  Example: 1234567
                  Default value: false
                  Note: When the location and locationID are both not set, the location will be based on the information provided by the calendar module. The first upcoming event with location data will be used.
                  location	The location used for weather information.
                  Example: 'Amsterdam,Netherlands'
                  so it ‘seems’ that location by itself would do it.
                  • AssassinsA
                    Assassins @sdetweil
                    This is the same, can only see the header.
                    Is work yesterday on MM 2.29.0
                      module: 'weather',
                      header: 'Ballerup',
                        apiVersion: '2.5',
                       apiBase: 'https://api.openweathermap.org/data/',
                        weatherEndpoint: '/no',
                        locationID: '2624341',
                        apiKey: 'BBnjsdnsdfnsdj8789dsfjsdnfnXX',
                        showHumidity: true,
                        initialLoadDelay: 1500
                      sdetweil @Assassins
                      @Assassins said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
                      apiBase: ‘https://api.openweathermap.org/data/’,
                      weatherEndpoint: ‘/no’,
                      no apiBase, that didn’t change
                      the weatherEndpoint is either “current” OR “forecast”
                      I originally gave them to you with leading / , so my comment was without the / (no /)
                      • AssassinsA
                        Assassins @sdetweil
                        Is the same mate
                          module: 'weather',
                          header: 'Ballerup',
                            apiVersion: '2.5',
                            weatherEndpoint: 'current',    // i have try the forecast to
                            apiKey: 'xxjljkjsksldjkj3478bjjk',
                            showHumidity: true,
                          sdetweil @Assassins
                          @Assassins seems it doesn’t work anymore… using my old 2.5 key I get code failure with openweathermap
                          but we changed the sample defaults to a free provider that might work
                          			module: "weather",
                          				weatherProvider: "openmeteo",
                          				type: "current",
                          				lat: 40.776676,
                          				lon: -73.971321
                          			module: "weather",
                          			header: "Weather Forecast",
                          				type: "forecast",
                          				lat: 40.776676,
                          				lon: -73.971321
                          • AssassinsA
                            Assassins @sdetweil
                            @sdetweil said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
                            Strange, works on my sd card with MM2.29.0 and also works on MMM-DynamicWeather and on MMM-WeatherOrNot with MM2.33.0.
                            Don’t know why openweathermap doesn’t work with MM2.33.0.
                            Besides that, it may have something to do with the code in MM2.33.0 that has been rewritten.
                            • S SdR referenced this topic on
                            • 3 / 3
