    Security bug - Wifi vs Wired on RPI
    5 Posts 3 Posters 3.3k Views 3 Watching
    • C Offline
      captsi
      I have a strange issue, which I’ve been narrowing down but can’t seem to resolve. Someone more knowledgeable should be able to help.
      My router recently failed, and my ISP replaced it with a Linksys router. They replaced the main wifi settings so some things work fine, yet others do not.
      I tried upgrading using the script, and initially met with failure. Eventually I got it working by hard wiring the RPI. In fact I got it all working by hard wiring the RPI, so it wasn’t an update thing after all.
      I am running Calender Ext - and that is working fine. I am also running OneCallWeather and UKTide - neither is working. The issue appears to be that the MM is not even fetching the data, whether it is struggling to resolve servers or getting stuck at a firewall, I dont know. Both modules are stuck at “Loading…” Nothing showing in the errors when running npm start dev.
      I am running Debain Bookworm. Latest version of MM. Node v20.18.1
      So, how can I recode the weather and tide to behave similar to Calendar? How can I make the RPI think I am as secure as a wired connection? Or how can I kick a Linksys router into allowing the appropriate packets through?
      Thanks all!
        sdetweil @captsi
        @captsi for OneCallWeather you need to get a new v3 apikey
        which requires a credit card. usage below 1000 api requests per day are currently free
        i do not know on Uktide. did you look at its github page issues tab for any reports similar to yours?
        • C Offline
          captsi @sdetweil
          @sdetweil I’ve been happily running the OpenWeather for 3 years, and the weather API works fine when it’s hard wired! Defo not the 1000 requests issue. Thanks for the pointer though.
            sdetweil @captsi
            @captsi ok, sounds like a wifi bad router
            plainbrokeP 1 Reply Last reply Reply Quote 0
            • plainbrokeP Offline
              plainbroke @sdetweil
              @captsi
              Can you reconfigure the new router to the same settings you had in the old one.
              or update the pi to the new wifi?
