    Slideshow for PDFs question
    Scheduled Pinned Locked Moved Forum
    13 Posts 3 Posters 8.6k Views 3 Watching
    • K
      kochb1988
      Hello. Trying to see if there’s a module that can show PDFs instead of pics. I know that there is the screen rotation module. Is there a document / pdf show and/or PDF slideshow in the modules. If so, what is the name so that I can research it? Thank you in advance.
        sdetweil @kochb1988
        @kochb1988 i have not seen a module that says it does this.
        did u look thru the third party modules? (list linked in the top menu above)
        K 1 Reply Last reply
        • K
          kochb1988 @sdetweil
          @sdetweil I have not seen a real good example of what I believe is needed. I’m looking at it 2 ways at once just in case. 1: A rotating MM screen (module exists) between a calendar and a pdf viewer (don’t believe it exists. 2: The ability to control the rotation of the screen. Such as: Always showing the calendar. But, when time for a presentation, the user can click something on-screen (with kb/mouse attached) that would switch the screen to the PDF and maaayyyyybe have the ability to control the PDF slide show.
            sdetweil @kochb1988
            @kochb1988 mmm-pages can do this
            using the hidden page config for pdf module
            but you need the pdf module
              @kochb1988 here is a lib someone could use to create a module
              https://www.npmjs.com/package/pdfjs-dist
              the module would need to create a canvas element for the
              library to draw in. not hard
              use the getscripts: method to load the lib for browser access
              C 1 Reply Last reply
              • C
                chrisfr1976 @sdetweil
                Challenge accepted :)
                MMM-PDFSlideshow
                I had some time today so I sat down and created something. Maybe useful. I’ll upload some Asterix-pdf to my mirror.
                I’m happy with this status. If anyone needs modifications create a pull request. I’m not happy with the fullscreen behavior since the scaling does not work as expected (fullscreen always uses the full width, so a full page display is not nice in landscape orientation). But I do not really need this.
                Regards, Chris.
                Reply Quote 2
                  sdetweil @chrisfr1976
                  @chrisfr1976 cool. why fullscreen or if set to fullscreen position?
                  can be sized w css
                  • C
                    @sdetweil Hi, this is the rest of my tries to show the page in 100% in fullscreen mode. So if position is set to a fullscreen region then also the fullscreen flag must be activated.
                    Regards, Chris.
                      @chrisfr1976 cool, should be possible to control in fullscreen w css.
                      in car, does this support url to pdf, or just local file?
                      (just local file)
                      • C
                        now also hosted PDF-files are supported. PDF with url have now the lead. The local pdfs/ folder is the fall-back if no URL is set or in case of any errors.
                        But:
                        Most remote PDF is being blocked due to Cross-Origin Resource Sharing restrictions. The server hosting the PDF (https://www.w3.org/… etc.) is not allowing MagicMirror to access its resource. So the server-side PDF is downloaded locally and saved in a folder. Once the file exists locally, the download isn’t performed again. So if the server pdf is updated then the local download must be deleted.
                        • If a URL-PDF (or one single PDF) should be displayed change displayTime: 10000, to a higher value (avoid flickering)
                        • If a downloaded and local pdf should be displayed then copy or move the pdf from the pdfURL to pdfs folder and leave the URL in the config blank.
                        I think there are some optimizations in file handling possible and maybe a new PDF-URL can be sent with MMM-Remote module. But I won’t work on that any further. I will use the local folder in general (if I use the module at all - don’t know).
                        Regards, Chris.
                          @chrisfr1976 have you looked at the cors server api we provide?
                          • C
                            Ö, no :)
                            Where?
                            Regards, Chris.
                              @chrisfr1976 not well documented and not 100%
                              http://mm_server:mm_port/cors?url=…,
                              sendheaders=…,
                              receiveheaders=…
                              send/receive headers are headername:value,…
                              code in js/server_functions.js
                              for my readme support in mmm-config i had to fallback to curl/wget
