    Voice assistant
    voice controltroubleshoot
    8 Posts 3 Posters 2.4k Views 3 Watching
    • N Offline
      notgood
      Can anyone recommend me voice assistant module that works on raspberry Pi 3
        sdetweil @notgood
        @notgood i’d look thru the third party modules list, linked above
        what do you want this voice assistant to do?
        Amazon has pretty much killed software based Alexa services
        see https://forum.magicmirror.builders/topic/16069/alexa-implementations-now-more-difficult-and-some-features-will-stop-working
        and there is currently not a Google Assistant or Apple Home
        interface
        C N 2 Replies Last reply Reply Quote 0
        • C Offline
          cyberphox @sdetweil
          Putting an echo dot behind the mirror was a lot less headache then trying to get any Alexa modules working…
          S N 2 Replies Last reply Reply Quote 0
            sdetweil @cyberphox
            @cyberphox yes AlexaControl module helps.
              @notgood I use the nodred alexa skill to configure alexa devices for my HomeAssistant devices, and automations. (devices connected wth mqtt via zigbee controller, and zigbee2mqtt docker container)
              • N Offline
                notgood @sdetweil
                @sdetweil hi thank you for replying,is there way I can with on this forum like direct message, I wanted to ask some doubts about mm
                • N Offline
                  notgood @cyberphox
                  @cyberphox i do have echo dot but it’s speaker not working properly,Thank you for replying
                    sdetweil @notgood
                    @notgood there is chat, under a users profile
