    message Remote Control
    18 Posts 2 Posters 4.3k Views 2 Watching
    • P Offline
      pat59
      Hello,
      How can I remove this update message without doing it? I did it and had to contact Mr. SDETWEIL because my Mirror stopped working. He fixed it, thank you.20250312_091938.jpg
      • P Offline
        pat59
        Yes, I systematically restart after each change in js.
        Well, you did find that there were indeed two update notifications in config.js.
        Something I would never have thought of after making the change in the second update notification in config.js. This one works, no more messages, even though I spent hours solving a lesson in restraint. Thanks again.
          sdetweil @pat59
          @pat59 this is caused by the updatenotification module
          as we just installed a fresh copy, i dont understand why this is showing again
          so you have 2 choices
          disable the updatenotification module in config.js
          module:"updatenotification",
          disabled:true,
          or
          add the MMM-Remote-Control module to the updateNotification ignore list
          module:"updatenotification".
          position:"...."
          config:{
            ignoreModules:['MMM-Remote-Control']
          • P Offline
            pat59
            Hello
            Sorry ,but l forgot to mention that this is a second mirror ,not the one you repaired for me .
            l tried your instruction, but it doen’t reboot .
            module: “updatenotification”,
            position: “”,
            ignoreModules: [‘MMM-Remote-Control’]
            updateAutorestart: true, // restart MagicMirror automaticaly after update
            updates: [
            // MMM-MeteoFrance rule
            “MMM-MeteoFrance”: “npm run update”
              sdetweil @pat59
              @pat59
              position: “”,
              yes, this is invalid
              i put that line there to make sure you understood where the following lines should be. not to indicate exact text
              you have to learn how to debug and resolve these kinds of issue
              1st thing is to look at the logs, as you use pm2 to autolaunch MagicMirror
              that is
              pm2 logs --lines=xxxx
              where xxxx is some number, default 15
              • P Offline
                pat59
                Okay, thanks, I’ll look at it again, thanks.
                  sdetweil @pat59
                  @pat59 did you find and fix the problem?
                  • P Offline
                    pat59
                    Good evening.
                    No, I haven’t found anything. I’ve searched extensively and tried for 5 hours, but to no avail.
                    I tried this: /{
                    / It doesn’t work. I went to the forum and tried some things in js.conf.
                    This morning, I turned on the one you fixed for me, and the update message came back. I’ll continue using it. Thanks again for your message.
                      sdetweil @pat59
                      @pat59 can you do this
                      From a terminal window
                      pm2 stop all
                      cd ~/MagicMirror
                      npm start &>somefile.txt
                      The post the contents of somefile.txt
                      • P Offline
                        pat59
                        Thank you, it works.
                        I was far from finding this. Thanks again for everything.
                        Sincerely,
                        • P Offline
                          pat59
                          I spoke too quickly after performing the manipulation it restarts by itself no more messages however once I restart the raspberry the message reappears.
                          In the message it tells me https://github.com Username
                            sdetweil @pat59
                            @pat59 said in message Remote Control:
                            in the message it tells me https://github.com Username
                            sorry, I don’t understand that text
                            as I said, you have to disable the updateNotification module
                              module: "updatenotification",
                              disabled: true,
                            OR
                            you have to list the modules to ignore
                               position: whatever it is,
                                 ignoreModules:["MMM-Remote-Control"]
                            these messages in the pm2 log
                            [2025-03-14 20:51:34.981] [INFO]  Checking git for module: MMM-MealieMenu
                            [2025-03-14 20:51:35.028] [INFO]  Checking git for module: MMM-pages
                            [2025-03-14 20:51:35.070] [INFO]  Checking git for module: MMM-CurlToNotification
                            are from the updateNotification module checking each module not ignored
                            • P Offline
                              pat59
                              disabled :true,
                              position: "top_center",
                                ignoreModules:["MMM-Remote-Control"],
                                updates: [
                                    "MMM-MeteoFrance": "npm run update"
                              the message is still there , l don't know anymotre after several attempts to modify the js config
                                sdetweil @pat59
                                @pat59 and you restarted MagicMirror after changing config?
                                can you show the screen again?
                                are there multiple instances of updatenotification in the config.js?
                                • P Offline
                                  pat59
                                    sdetweil @pat59
                                    @pat59 great work…
                                    • P Offline
                                      pat59
                                      The excellent work is partly due to your patience, thank you for everything, I am so happy.
                                        sdetweil @pat59
                                        @pat59 I think you should try my MMM-Config module, as you continue to have problems with config.js
                                        https://github.com/sdetweil/MMM-Config
                                        this will present a form for the system and module properties.
                                        it will also support adding modules too…
                                        it will also show you when you have multiple instances…
                                        • P Offline
                                          pat59
                                          Hello
                                          Thank you, I’ll try. Thank you. Have a nice day.
