    Magic Mirror with Pi4 OS not working with Pi5
    30 Posts 4 Posters 7.6k Views 4 Watching
    • T Offline
      TomOMaley @sdetweil
      @sdetweil Hello Sam, in the installers/mm.sh, second line, I find: npm run start:x11 ; should I change this to npm start:wayland OR to npm run start:wayland ?
      AND
      then
      pm2 flush
      pn2 restart mm ! Is it pn2 OR pm2 ?
        sdetweil @TomOMaley
        @TomOMaley
        good catch
        npm start, is the only shortcut
        all others require npm run
        see the package.json
        scripts
        list for other npm run commands
        • T Offline
          TomOMaley @sdetweil
          Sorry, don not know, how to edit mm.sh. when I go to ~/MagicMirror/installers/mm.sh I get a long list but can not edit it. When I go to mm.sh via Datei Manager I get only this few lines:
          #!/bin/bash
          This file is still here to keep PM2 working on older installations.
          cd /home/pi5/MagicMirror
          DISPLAY=:0 npm start.
          I have seen that in raspberry config > advanced options one can switch to wayland backends. Could that help here in any way? Sorry but my knowledge in Linux is not really exciting. Thanks for all your effort.
            sdetweil @TomOMaley
            @TomOMaley
            there it is
            edit
            nano is a terminal windows based
            genie is a graphical editor
            there lots of others
            • T Offline
              TomOMaley @sdetweil
              @sdetweil ???
                sdetweil @TomOMaley
                @TomOMaley you replace npm start
                with npm run start:wayland
                right?
                you said you didnt know how to edit. how do you change config.js?
                T 2 Replies Last reply Reply Quote 0
                • T Offline
                  TomOMaley @sdetweil
                  @sdetweil can’t neither write nor do anything in mm.sh
                  • T Offline
                    TomOMaley @sdetweil
                    @sdetweil Thank you so far Sam. I give up and will use my Pi4 where everything runs smothly. It is much to time consuming and frustrating. When I have more time I think I try an MM installation manually from scratch. I really appriciate your help. Can I show my appreciation in any way ?
                      sdetweil @TomOMaley
                      @TomOMaley
                      cd ~/MagicMirror/installers
                      nano mm.sh
                      move around with arrow keys, backspace , etc,
                      change
                      then
                      ctrl-o
                      to write file, hit enter
                      ctrl-x to exit
                      this project requires a lot of learning
                      no shortcuts
                      time for a linux class
                        sdetweil @TomOMaley
                        @TomOMaley said in Magic Mirror with Pi4 OS not working with Pi5:
                        just be careful… there are lots of things my script does for you
