    Magic Mirror with Pi4 OS not working with Pi5
    30 Posts 4 Posters 10.8k Views 4 Watching
      sdetweil @TomOMaley
      @TomOMaley sorry I dont know what you are talking about,
      • T Offline
        TomOMaley @sdetweil
        @sdetweil The question is, how can I stop MM in order to go back to the grafic desktop?
          sdetweil @TomOMaley
          @TomOMaley ctrl-m should minimize
          • T Offline
            TomOMaley @sdetweil
            @sdetweil Thank you very much Sam, that makes life easier. I didn’t know the key combination.
              sdetweil @TomOMaley
              @TomOMaley it’s the same keystroke as Windows
              • T Offline
                TomOMaley @sdetweil
                @sdetweil Hello Sam, I finally tried also your backup-restore link and it worked perfectly. Unfortunately, the calendar module no longer loads my iOS events (next events and birthdays), it only shows “Loading”. Also the news feeds are not shown. For the latter, the message “No news at the moment” appears. I have found various solutions on the net, but I don’t dare to try them out so as not to produce any more mess. The same config.js works fine on a Raspberry Pi 4. Hope you will and can help?
                  sdetweil @TomOMaley
                  @TomOMaley hm, working perfectly and modules not working is an oxymoron… lol
                  can you show the messages at npm start time for calendar? watch out, some messages show the full calendar url
                  can you tell me the MagicMirror version on the.pi 4
                  and show the calendar config, xxx out any private info, don’t delete any lines
                  • butchkemperB Offline
                    butchkemper
                    From my own recent experience, you have a copy of the previous config.js file but the modules cloned into the new system may not be the same as what was cloned into the old system.
                    Butch Kemper
                    Resistance is not Futile!
                    It is voltage divided by current.
                      sdetweil @butchkemper
                      @butchkemper my backup restore gets the modules from the same prior url
                      but might not be the same version, if the module was updated since the last clone/pull (but 99% of the time this is a good change )
                      • T Offline
                        TomOMaley @sdetweil
                        @sdetweil Hi, Thanks for your quick answer. I do not know what you mean with
                        The MagicMirror Version on the pi4 is 2.24.0
                        Your restore link restored everything back as expected. All modules are running besides of those named above. The “alert” module, “updatenotification”, “clock”, “calendar_monthly”, “weather”, “MMM-MoonPhase”, etc. etc. are running well.
                          sdetweil @TomOMaley
                          @TomOMaley when MagicMirror starts, w npm start
                          there are messages output
                          if you use pm2 then
                          pn2 logs --lines=xxxx
                          where xxxx is the number of lines to display, default 15
                          • T Offline
                            TomOMaley
                            That is what I get with pm2 logs --lines=20.
                            [TAILING] Tailing last 20 lines for [all] processes (change the value with --lines option)
                            /home/pi5/.pm2/pm2.log last 20 lines:
                            PM2 | 2025-03-17T20:06:56: PM2 log: Concurrent actions : 2
                            PM2 | 2025-03-17T20:06:56: PM2 log: SIGTERM timeout : 1600
                            PM2 | 2025-03-17T20:06:56: PM2 log: ===============================================================================
                            PM2 | 2025-03-17T20:06:56: PM2 log: App [mm:0] starting in -fork mode-
                            PM2 | 2025-03-17T20:06:56: PM2 log: App [mm:0] online
                            PM2 | 2025-03-17T20:57:48: PM2 log: Stopping app:mm id:0
                            PM2 | 2025-03-17T20:57:49: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                            PM2 | 2025-03-17T20:57:49: PM2 log: pid=1128 msg=process killed
                            PM2 | 2025-03-17T20:57:49: PM2 log: App [mm:0] starting in -fork mode-
                            PM2 | 2025-03-17T20:57:49: PM2 log: App [mm:0] online
                            PM2 | 2025-03-17T21:16:19: PM2 log: Stopping app:mm id:0
                            PM2 | 2025-03-17T21:16:19: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                            PM2 | 2025-03-17T21:16:19: PM2 log: pid=3621 msg=process killed
                            PM2 | 2025-03-17T21:16:19: PM2 log: App [mm:0] starting in -fork mode-
                            PM2 | 2025-03-17T21:16:19: PM2 log: App [mm:0] online
                            PM2 | 2025-03-17T21:20:13: PM2 log: Stopping app:mm id:0
                            PM2 | 2025-03-17T21:20:13: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                            PM2 | 2025-03-17T21:20:13: PM2 log: pid=4540 msg=process killed
                            PM2 | 2025-03-17T21:20:13: PM2 log: App [mm:0] starting in -fork mode-
                            PM2 | 2025-03-17T21:20:13: PM2 log: App [mm:0] online
                            /home/pi5/.pm2/logs/mm-error.log last 20 lines:
                            0|mm | [5164:0317/212015.666827:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.666942:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.667063:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.667127:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.669483:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.671772:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.672140:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.672271:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.672606:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.672981:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.673132:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.674044:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.674213:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.674280:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.674369:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.674413:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.674498:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.674546:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.674644:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [5164:0317/212015.674691:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                            /home/pi5/.pm2/logs/mm-out.log last 20 lines:
                            0|mm | [2025-03-17 21:20:15.575] [LOG] Connecting socket for: MMM-MoonPhase
                            0|mm | [2025-03-17 21:20:15.575] [LOG] Starting module helper: MMM-MoonPhase
                            0|mm | [2025-03-17 21:20:15.575] [LOG] Connecting socket for: MMM-FroniusSolar2
                            0|mm | [2025-03-17 21:20:15.576] [LOG] Connecting socket for: MMM-text-clock
                            0|mm | [2025-03-17 21:20:15.576] [LOG] Starting module helper: MMM-text-clock
                            0|mm | [2025-03-17 21:20:15.577] [LOG] Connecting socket for: mmm-systemtemperature
                            0|mm | [2025-03-17 21:20:15.579] [LOG] Starting node helper: mmm-systemtemperature
                            0|mm | [2025-03-17 21:20:15.580] [LOG] Sockets connected & modules started …
                            0|mm | [2025-03-17 21:20:15.697] [LOG] Launching application.
                            0|mm | [2025-03-17 21:20:16.212] [INFO] System information:
                            0|mm | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 5 Model B Rev 1.1; virtual: false
                            0|mm | ### OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.74+rpt-rpi-2712
                            0|mm | ### VERSIONS: electron: 32.3.3; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                            0|mm | ### OTHER: timeZone: Etc/GMT-1; ELECTRON_ENABLE_GPU: undefined
                            0|mm | [2025-03-17 21:20:16.814] [INFO] Checking git for module: calendar_monthly
                            0|mm | [2025-03-17 21:20:16.829] [INFO] Checking git for module: MMM-MoonPhase
                            0|mm | [2025-03-17 21:20:16.839] [INFO] Checking git for module: MMM-FroniusSolar2
                            0|mm | [2025-03-17 21:20:16.855] [INFO] Checking git for module: MMM-text-clock
                            0|mm | [2025-03-17 21:20:16.863] [INFO] Checking git for module: mmm-systemtemperature
                            0|mm | [2025-03-17 21:20:16.871] [INFO] Checking git for module: MagicMirror
                              sdetweil @TomOMaley
                              @TomOMaley OK, need to see more lines,
                              but
                              to get rid of some noise errors
                              edit the ~/MagicMirror/installers/mm.sh
                              and change npm start to
                              npm run start:wayland
                              then
                              pm2 flush
                              pn2 restart mm
                              wait a while, then pm2 logs --lines=50
                              • T Offline
                                TomOMaley @sdetweil
                                @sdetweil Hello Sam, in the installers/mm.sh, second line, I find: npm run start:x11 ; should I change this to npm start:wayland OR to npm run start:wayland ?
                                AND
                                then
                                pm2 flush
                                pn2 restart mm ! Is it pn2 OR pm2 ?
                                  sdetweil @TomOMaley
                                  @TomOMaley
                                  good catch
                                  npm start, is the only shortcut
                                  all others require npm run
                                  see the package.json
                                  scripts
                                  list for other npm run commands
                                  • T Offline
                                    TomOMaley @sdetweil
                                    Sorry, don not know, how to edit mm.sh. when I go to ~/MagicMirror/installers/mm.sh I get a long list but can not edit it. When I go to mm.sh via Datei Manager I get only this few lines:
                                    #!/bin/bash
                                    This file is still here to keep PM2 working on older installations.
                                    cd /home/pi5/MagicMirror
                                    DISPLAY=:0 npm start.
                                    I have seen that in raspberry config > advanced options one can switch to wayland backends. Could that help here in any way? Sorry but my knowledge in Linux is not really exciting. Thanks for all your effort.
                                      sdetweil @TomOMaley
                                      @TomOMaley
                                      there it is
                                      edit
                                      nano is a terminal windows based
                                      genie is a graphical editor
                                      there lots of others
                                      • T Offline
                                        TomOMaley @sdetweil
                                        @sdetweil ???
                                          sdetweil @TomOMaley
                                          @TomOMaley you replace npm start
                                          with npm run start:wayland
                                          right?
                                          you said you didnt know how to edit. how do you change config.js?
                                          T 2 Replies Last reply Reply Quote 0
                                          • T Offline
                                            TomOMaley @sdetweil
                                            @sdetweil can’t neither write nor do anything in mm.sh
