    Magic Mirror with Pi4 OS not working with Pi5
    30 Posts 4 Posters 10.9k Views 4 Watching
    • T Offline
      TomOMaley
      Hi, got a new Pi 5 and wanted to run it with the SD Card of my Pi4. Did not work. So I had to install new OS for the Pi5. How can I get my Mirror running on this new OS ? I am afraid copy paste would not work ?
        sdetweil @TomOMaley
        @TomOMaley boot your pi4
        use my backup scripts where to save the MagicMirror config
        see https://github.com/sdetweil/MagicMirror-backup-restore
        copy the MM_backup folder to some other media
        or use the github option to save
        boot your pi5 sd card
        if you have not installed MagicMirror, use my automated ibstall script
        see https://github.com/sdetweil/MagicMirror_scripts
        once the base MagicMirror is runnable
        then use the restore scripts where to restore the MagicMirror configuration (including modules)
        R T 2 Replies Last reply Reply Quote 0
          @sdetweil Hi Sam,
          quick question which came in my mind as reading this:
          As you might remember, bugsounet left this forum and closed his git-repositories…
          As far as I understood your restore mechanism rebuilds the modules from their respective git-repositories.
          This is not doable for the described scenario, right?
          What to do?
          Especially for e.g. MMM-PIR which has extensive dependencies which are installed by some scripts from bugsounet’s git-repo …
          Thanks for any hint!
          Regards,
          Ralf
            sdetweil @rkorell
            @rkorell correct. it restores from source repo
            someone saved a new repo for mmm-pir (see the 3rd party list)
            sadly the modules will die. he made it near impossible to keep them active
            you cannot migrate most of them in binary form either.
            but i can add messaging in both backup and restore.
              @sdetweil said in Magic Mirror with Pi4 OS not working with Pi5:
              you cannot migrate
              Yeah, that’s what I was afraid of…
              Sad!
              thanks for confirmation anyway!
              Ralf
                sdetweil @rkorell
                @rkorell I added an issue to the back/restore repo to track what to do here
                • T Offline
                  TomOMaley @sdetweil
                  @sdetweil Hello, thank you very much, I somehow managed to do that by ‘manually’ copying the modules etc. back. But I still have the following problem. I use an original Raspi keyboard and used to get into the ‘dock’ with the ‘Berry’ key, so that I could call up the terminal and end the MagicMirror with ‘pm2 stop mm’. This no longer works and I can only get out via RealVNC. Do you have a solution for this?
                    sdetweil @TomOMaley
                    @TomOMaley sorry I dont know what you are talking about,
                    • T Offline
                      TomOMaley @sdetweil
                      @sdetweil The question is, how can I stop MM in order to go back to the grafic desktop?
                        sdetweil @TomOMaley
                        @TomOMaley ctrl-m should minimize
                        • T Offline
                          TomOMaley @sdetweil
                          @sdetweil Thank you very much Sam, that makes life easier. I didn’t know the key combination.
                            sdetweil @TomOMaley
                            @TomOMaley it’s the same keystroke as Windows
                            • T Offline
                              TomOMaley @sdetweil
                              @sdetweil Hello Sam, I finally tried also your backup-restore link and it worked perfectly. Unfortunately, the calendar module no longer loads my iOS events (next events and birthdays), it only shows “Loading”. Also the news feeds are not shown. For the latter, the message “No news at the moment” appears. I have found various solutions on the net, but I don’t dare to try them out so as not to produce any more mess. The same config.js works fine on a Raspberry Pi 4. Hope you will and can help?
                                sdetweil @TomOMaley
                                @TomOMaley hm, working perfectly and modules not working is an oxymoron… lol
                                can you show the messages at npm start time for calendar? watch out, some messages show the full calendar url
                                can you tell me the MagicMirror version on the.pi 4
                                and show the calendar config, xxx out any private info, don’t delete any lines
                                • butchkemperB Offline
                                  butchkemper
                                  From my own recent experience, you have a copy of the previous config.js file but the modules cloned into the new system may not be the same as what was cloned into the old system.
                                  Butch Kemper
                                  Resistance is not Futile!
                                  It is voltage divided by current.
                                    sdetweil @butchkemper
                                    @butchkemper my backup restore gets the modules from the same prior url
                                    but might not be the same version, if the module was updated since the last clone/pull (but 99% of the time this is a good change )
                                    • T Offline
                                      TomOMaley @sdetweil
                                      @sdetweil Hi, Thanks for your quick answer. I do not know what you mean with
                                      The MagicMirror Version on the pi4 is 2.24.0
                                      Your restore link restored everything back as expected. All modules are running besides of those named above. The “alert” module, “updatenotification”, “clock”, “calendar_monthly”, “weather”, “MMM-MoonPhase”, etc. etc. are running well.
                                        sdetweil @TomOMaley
                                        @TomOMaley when MagicMirror starts, w npm start
                                        there are messages output
                                        if you use pm2 then
                                        pn2 logs --lines=xxxx
                                        where xxxx is the number of lines to display, default 15
                                        • T Offline
                                          TomOMaley
                                          That is what I get with pm2 logs --lines=20.
                                          [TAILING] Tailing last 20 lines for [all] processes (change the value with --lines option)
                                          /home/pi5/.pm2/pm2.log last 20 lines:
                                          PM2 | 2025-03-17T20:06:56: PM2 log: Concurrent actions : 2
                                          PM2 | 2025-03-17T20:06:56: PM2 log: SIGTERM timeout : 1600
                                          PM2 | 2025-03-17T20:06:56: PM2 log: ===============================================================================
                                          PM2 | 2025-03-17T20:06:56: PM2 log: App [mm:0] starting in -fork mode-
                                          PM2 | 2025-03-17T20:06:56: PM2 log: App [mm:0] online
                                          PM2 | 2025-03-17T20:57:48: PM2 log: Stopping app:mm id:0
                                          PM2 | 2025-03-17T20:57:49: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                          PM2 | 2025-03-17T20:57:49: PM2 log: pid=1128 msg=process killed
                                          PM2 | 2025-03-17T20:57:49: PM2 log: App [mm:0] starting in -fork mode-
                                          PM2 | 2025-03-17T20:57:49: PM2 log: App [mm:0] online
                                          PM2 | 2025-03-17T21:16:19: PM2 log: Stopping app:mm id:0
                                          PM2 | 2025-03-17T21:16:19: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                          PM2 | 2025-03-17T21:16:19: PM2 log: pid=3621 msg=process killed
                                          PM2 | 2025-03-17T21:16:19: PM2 log: App [mm:0] starting in -fork mode-
                                          PM2 | 2025-03-17T21:16:19: PM2 log: App [mm:0] online
                                          PM2 | 2025-03-17T21:20:13: PM2 log: Stopping app:mm id:0
                                          PM2 | 2025-03-17T21:20:13: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                          PM2 | 2025-03-17T21:20:13: PM2 log: pid=4540 msg=process killed
                                          PM2 | 2025-03-17T21:20:13: PM2 log: App [mm:0] starting in -fork mode-
                                          PM2 | 2025-03-17T21:20:13: PM2 log: App [mm:0] online
                                          /home/pi5/.pm2/logs/mm-error.log last 20 lines:
                                          0|mm | [5164:0317/212015.666827:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.666942:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.667063:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.667127:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.669483:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.671772:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.672140:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.672271:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.672606:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.672981:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.673132:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.674044:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.674213:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.674280:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.674369:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.674413:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.674498:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.674546:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.674644:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                                          0|mm | [5164:0317/212015.674691:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                                          /home/pi5/.pm2/logs/mm-out.log last 20 lines:
                                          0|mm | [2025-03-17 21:20:15.575] [LOG] Connecting socket for: MMM-MoonPhase
                                          0|mm | [2025-03-17 21:20:15.575] [LOG] Starting module helper: MMM-MoonPhase
                                          0|mm | [2025-03-17 21:20:15.575] [LOG] Connecting socket for: MMM-FroniusSolar2
                                          0|mm | [2025-03-17 21:20:15.576] [LOG] Connecting socket for: MMM-text-clock
                                          0|mm | [2025-03-17 21:20:15.576] [LOG] Starting module helper: MMM-text-clock
                                          0|mm | [2025-03-17 21:20:15.577] [LOG] Connecting socket for: mmm-systemtemperature
                                          0|mm | [2025-03-17 21:20:15.579] [LOG] Starting node helper: mmm-systemtemperature
                                          0|mm | [2025-03-17 21:20:15.580] [LOG] Sockets connected & modules started …
                                          0|mm | [2025-03-17 21:20:15.697] [LOG] Launching application.
                                          0|mm | [2025-03-17 21:20:16.212] [INFO] System information:
                                          0|mm | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 5 Model B Rev 1.1; virtual: false
                                          0|mm | ### OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.74+rpt-rpi-2712
                                          0|mm | ### VERSIONS: electron: 32.3.3; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                                          0|mm | ### OTHER: timeZone: Etc/GMT-1; ELECTRON_ENABLE_GPU: undefined
                                          0|mm | [2025-03-17 21:20:16.814] [INFO] Checking git for module: calendar_monthly
                                          0|mm | [2025-03-17 21:20:16.829] [INFO] Checking git for module: MMM-MoonPhase
                                          0|mm | [2025-03-17 21:20:16.839] [INFO] Checking git for module: MMM-FroniusSolar2
                                          0|mm | [2025-03-17 21:20:16.855] [INFO] Checking git for module: MMM-text-clock
                                          0|mm | [2025-03-17 21:20:16.863] [INFO] Checking git for module: mmm-systemtemperature
                                          0|mm | [2025-03-17 21:20:16.871] [INFO] Checking git for module: MagicMirror
                                            sdetweil @TomOMaley
                                            @TomOMaley OK, need to see more lines,
                                            but
                                            to get rid of some noise errors
                                            edit the ~/MagicMirror/installers/mm.sh
                                            and change npm start to
                                            npm run start:wayland
                                            then
                                            pm2 flush
                                            pn2 restart mm
                                            wait a while, then pm2 logs --lines=50
