Magic Mirror with Pi4 OS not working with Pi5
30 Posts 4 Posters 3.8k Views 4 Watching
  • T Offline
    TomOMaley
    Hi, got a new Pi 5 and wanted to run it with the SD Card of my Pi4. Did not work. So I had to install new OS for the Pi5. How can I get my Mirror running on this new OS ? I am afraid copy paste would not work ?
    S 1 Reply Last reply Mar 12, 2025, 12:44 PM Reply Quote 0
      sdetweil @TomOMaley
      @TomOMaley boot your pi4
      use my backup scripts where to save the MagicMirror config
      see https://github.com/sdetweil/MagicMirror-backup-restore
      copy the MM_backup folder to some other media
      or use the github option to save
      boot your pi5 sd card
      if you have not installed MagicMirror, use my automated ibstall script
      see https://github.com/sdetweil/MagicMirror_scripts
      once the base MagicMirror is runnable
      then use the restore scripts where to restore the MagicMirror configuration (including modules)
      R T 2 Replies Last reply Mar 12, 2025, 1:06 PM Reply Quote 0
        rkorell @sdetweil
        @sdetweil Hi Sam,
        quick question which came in my mind as reading this:
        As you might remember, bugsounet left this forum and closed his git-repositories…
        As far as I understood your restore mechanism rebuilds the modules from their respective git-repositories.
        This is not doable for the described scenario, right?
        What to do?
        Especially for e.g. MMM-PIR which has extensive dependencies which are installed by some scripts from bugsounet’s git-repo …
        Thanks for any hint!
        Regards,
        Ralf
        S 1 Reply Last reply Mar 12, 2025, 1:22 PM Reply Quote 0
          sdetweil @rkorell
          @rkorell correct. it restores from source repo
          someone saved a new repo for mmm-pir (see the 3rd party list)
          sadly the modules will die. he made it near impossible to keep them active
          you cannot migrate most of them in binary form either.
          but i can add messaging in both backup and restore.
          R 1 Reply Last reply Mar 12, 2025, 1:39 PM Reply Quote 0
            rkorell @sdetweil
            @sdetweil said in Magic Mirror with Pi4 OS not working with Pi5:
            you cannot migrate
            Yeah, that’s what I was afraid of…
            Sad!
            thanks for confirmation anyway!
            Ralf
            S 1 Reply Last reply Mar 12, 2025, 2:54 PM Reply Quote 0
              sdetweil @rkorell
              @rkorell I added an issue to the back/restore repo to track what to do here
              • T Offline
                TomOMaley @sdetweil
                @sdetweil Hello, thank you very much, I somehow managed to do that by ‘manually’ copying the modules etc. back. But I still have the following problem. I use an original Raspi keyboard and used to get into the ‘dock’ with the ‘Berry’ key, so that I could call up the terminal and end the MagicMirror with ‘pm2 stop mm’. This no longer works and I can only get out via RealVNC. Do you have a solution for this?
                S 1 Reply Last reply Mar 13, 2025, 5:36 PM Reply Quote 0
                  sdetweil @TomOMaley
                  @TomOMaley sorry I dont know what you are talking about,
                  T 1 Reply Last reply Mar 13, 2025, 6:23 PM Reply Quote 0
                  • T Offline
                    TomOMaley @sdetweil
                    @sdetweil The question is, how can I stop MM in order to go back to the grafic desktop?
                    S 1 Reply Last reply Mar 13, 2025, 7:43 PM Reply Quote 0
                      sdetweil @TomOMaley
                      @TomOMaley ctrl-m should minimize
                      T 1 Reply Last reply Mar 14, 2025, 2:13 AM Reply Quote 0
                      1 / 3
