    MMM-CalendarExt3 and MMM-MonthlyCalendar blank
    59 Posts 3 Posters 23.3k Views 3 Watching
      Scott-M @sdetweil
      Luckily I had a slow week at work!
      This seems to have worked:
      sudo apt-get -y  -o Dpkg::Options::=“–force-confdef” -o Dpkg::Options::=“–force-confnew” full-upgrade
      I have brought my Pi5 home, and a couple of micro SDs so happy to test when I can. I do have a lot of driving chilren around to do but some time in between.
        sdetweil @Scott-M
        @Scott-M thank you very much
        ok, I’ve updated raspberry.sh on the v231 branch
        let me know what you find when u can
          Scott-M @sdetweil
          These seems to be a subtle difference between our keyboard layouts perhaps,
          raspberry.sh has this line
          upgrade_result=$(sudo apt-get -y  -o Dpkg::Options::=“–force-confdef” -o Dpkg::Options::=“–force-confnew” full-upgrade | pv -l -p)
          but the quotes around –force-confdef and –force-confnew are the wrong type . Should be:
          upgrade_result=$(sudo apt-get -y  -o Dpkg::Options::="–force-confdef" -o Dpkg::Options::="–force-confnew" full-upgrade | pv -l -p)
          It causes this error:
          dpkg: error: need an action option
          Type dpkg --help for help about installing and deinstalling packages [*];
          Use 'apt' or 'aptitude' for user-friendly package management;
          Type dpkg -Dhelp for a list of dpkg debug flag values;
          Type dpkg --force-help for a list of forcing options;
          Type dpkg-deb --help for help about manipulating *.deb files;
          Options marked [*] produce a lot of output - pipe it through 'less' or 'more' !
          E: Sub-process dpkg --set-selections returned an error code (2)
          E: Couldn't record the approved state changes as dpkg selection states
          Maybe just replace the quotes rather than copy and pase. I noticed the same thing when I copied the link you sent previously for the test branch.
            sdetweil @Scott-M
            @Scott-M I copied directly from your original post, it also shows the curved quotes
            pushed fix
            S S 2 Replies Last reply Reply Quote 0
              Scott-M @sdetweil
              @sdetweil So it does, not sure why, I copied it from the terminal window.
                sdetweil @Scott-M
                @Scott-M said in MMM-CalendarExt3 and MMM-MonthlyCalendar blank:
                the MagicMirror forums assume word processing for quotes unless in a code block
                once you save it, poof… it will never change back automatically
                so it looks like you decided to add the code black later… (just experience )
                  @Scott-M note this latest fix also changes MagicMirror.sh to detect which window manager is running (wayland or labwc) and use the different start command if detected
                    Scott-M @sdetweil
                    I probably did add the code block after. Lesson learned! And this is partly why I am having more issues with this. It has been very frustating, after it worked last night, it isn’t now.
                    I think I know what the issue is but it is time consuming writing the SD image and running the script so if you can bear with me. I want to test it at least twice before I update here.
                    I suspect the 2 dashes before
                    --force-confdef
                    --force-confnew
                    have been replaced by a single dash of a different character type. Again, because I put the code block around the text after I copied it.
                    This should be the correct code but let me test again to make sure. It has worked once, just want to do it again and will update.
                    sudo apt-get -y -o Dpkg::Options::="--force-confdef" -o Dpkg::Options::="--force-confnew" full-upgrade
                    In the mean time, the above code will auto select the default option if one is available and then answer Yes if there is no default. In the case of the prompt that was appearing, the old configuration file ‘/etc/xdg/labwc-greeter/autostart’ is kept. If you want the package maintainers file instead just remove the first option:
                      sdetweil @Scott-M
                      @Scott-M yes the double dash was replaced with single… new update pushed…
                        Scott-M @sdetweil
                        It seemed to get through the upgrade stage very quickly and
                        apt-get upgrade  started
                        apt-get upgrade result =rc=0 Reading package lists...
                        Building dependency tree...
                        in the log seems to show the upgrade didn’t work. I will run the script locally on the pi and send the output to the termnial to see what is happening but it won’t be tonight, I have to go out now.
                        Update tomorrow…
                          Scott-M @Scott-M
                          MagicMirror did run though…
                            Scott-M
                            So, I have tried the following, each on a freshlly flashed OS.
                            1 - Copied
                            directly from the raspberry.sh script, updated and then upgraded using the above and it worked.
                            2 - Modified the script as below and ran it locally so I can see the output in terminal during the upgrade part, and it worked, no errors durring the upgrade. And Magic Mirror Ran successfully.
                            	if [ $upgrade -eq $true ]; then
                            	   sudo apt-get install pv -y >>$logfile
                            	   echo "apt-get upgrade  started" >> $logfile
                            	   sudo apt-get -y -o Dpkg::Options::="--force-confdef" -o Dpkg::Options::="--force-confnew" full-upgrade | tee -a $logfile
                            	   #upgrade_result=$(sudo apt-get -y -o Dpkg::Options::="--force-confdef" -o Dpkg::Options::="--force-confnew" full-upgrade | pv -l -p)
                            	   #upgrade_result=$(sudo apt-get --assume-yes full-upgrade  2>&1 | pv -l -p)
                            		 #upgrade_rc=$?
                            		 #echo apt-get upgrade result ="rc=$upgrade_rc $upgrade_result" >> $logfile
                            	fi
                            3 - Copied your raspberry.sh script to the home directory unmodified and ran it locally and it also works. Log file still reads
                            But it worked, is the what you would expect in the log?
                            4 - Run the script again directly using.
                            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/v231/raspberry.sh)"
                            This works and the log file reads the same
                            Running apg-get full-upgrade again show that there is nothing new to do.
                            Bottom line, it works!
                            Attempt no 2 running the modified script locally, the whole upgrade output went to the log file.
                              sdetweil @Scott-M
                              @Scott-M thanks. pv is a tool for showing progress on the commandline
                              it shows <=>
                              moving left to right or right to left as output goes thru
                              i put it in because others said they didnt know if it was still working or hung
                              ill make changes, new release coming
                                sdetweil @Scott-M
                                sudo apt-get -y -o Dpkg::Options::=“–force-confdef” -o Dpkg::Options::=“–force-confnew” full-upgrade | tee -a $logfile
                                updated script, removed pv , give it a try if you have time
                                  Scott-M @sdetweil
                                  All good, works fine.
                                    sdetweil @Scott-M
                                    @Scott-M woohoo… thanks…
                                    • O Offline
                                      orayoflighto Project Sponsor @sdetweil
                                      Sorry to reply to an old thread, but I am getting this same error message when installing on a Pi5 32 bit.
                                      I tried the 64 bit version and that resulted in a black screen after a period of runtime with the default configs which is a separate issue.
                                      Can I install a package separate from the script to get around this issue?
                                        sdetweil @orayoflighto
                                        @orayoflighto sure you can install manually. See the doc
                                        https://docs.magicmirror.builders/getting-started/requirements.html
                                        Trixie 32 bit looks to be trouble
                                        Pi5 should be 64 bit
                                        Can you send me the ~/install.log
                                        • O Offline
                                          Thanks for the quick response. I ended up wiping and reinstalling the 64 bit version so I lost the log. I will try and get that version to work.
                                          • 3 / 3
