    MMM-ioBroker - it will not show
    34 Posts 3 Posters 6.8k Views 3 Watching
    • kusselinK Offline
      kusselin @sdetweil
      Thank you…that’s funny…I don’t have any SD in use. I have installed the MM in a Proxmox container…ok then I know that something is wrong and I have to create a new container…config and costum.css I save and modules too…
      Thank you again
      • kusselinK Offline
        kusselin
        Hello everyone,
        hello stedweil,
        an update…I have reinstalled the MM and I have said that I have it running in a Proxmox container (LXC)…that also worked via this page:
        https://tteck.github.io/Proxmox/#miscellaneous
        the installation worked perfectly…then I adjusted the config one after the other…
        all modules work, regardless of whether they are MMM-Fuel, MMM-Clock or Calender…only not the MMM-ioBroker…my temperature and humidity data records are still not displayed
        @stedweil: Let’s please go through again step by step what I can do to possibly narrow down the error. I bought the Aquara parts especially to display this via MM and it actually worked until recently.
        Thank you in advance
        		module: 'MMM-ioBroker',
        		position: 'top_left',
        		  host: '192.168.200.38',
        		  port: '8082',
        		  https: false,
        		  devices: [
                  { name: 'EG-Ankleide',
                    deviceStates: [
                                      { id: 'zigbee.0.00158d0002fb4915.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                      { id: 'zigbee.0.00158d0002fb4915.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
        		  { name: 'EG-Büro',
                    deviceStates: [
                                      { id: 'zigbee.0.00158d0006d571bb.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                      { id: 'zigbee.0.00158d0006d571bb.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
        		  { name: 'EG-Bad',
                    deviceStates: [
                                      { id: 'zigbee.0.00158d0006e3ee77.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                      { id: 'zigbee.0.00158d0006e3ee77.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
        		  { name: 'EG-Wohnzimmer',
                    deviceStates: [
                                      { id: 'hm-rpc.0.NEQ1522239.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                      { id: 'hm-rpc.0.NEQ1522239.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
        		{ name: 'Dach-Speicher',
                    deviceStates: [
                                      { id: 'hm-rpc.0.KEQ0242488.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                      { id: 'hm-rpc.0.KEQ0242488.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
        			{ name: 'Treppenhaus',
                    deviceStates: [
                                      { id: 'hm-rpc.0.LEQ0592936.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                      { id: 'hm-rpc.0.LEQ0592936.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
        			{ name: 'OG-Bad',
                    deviceStates: [
                                      { id: 'zigbee.0.00158d008b644f6f.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                      { id: 'zigbee.0.00158d008b644f6f.humidity',     icon: 'wi wi-humidity', suffix: '%' }
        			{ name: 'OG-Wohnzimmer',
                    deviceStates: [
                                      { id: 'zigbee.0.00158d008b64556c.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                      { id: 'zigbee.0.00158d008b64556c.humidity',     icon: 'wi wi-humidity', suffix: '%' }
        			{ name: 'OG-Rumpelzimmer',
                    deviceStates: [
                                      { id: 'zigbee.0.00158d008b644eff.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                      { id: 'zigbee.0.00158d008b644eff.humidity',     icon: 'wi wi-humidity', suffix: '%' }
        			{ name: 'OG-Esszimmer',
                    deviceStates: [
                                      { id: 'zigbee.0.00158d008b6192cd.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                      { id: 'zigbee.0.00158d008b6192cd.humidity',     icon: 'wi wi-humidity', suffix: '%' }
        			{ name: 'OG-Schlafzimmer',
                    deviceStates: [
                                      { id: 'zigbee.0.00158d008b69c067.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                      { id: 'zigbee.0.00158d008b69c067.humidity',     icon: 'wi wi-humidity', suffix: '%' }
        			{ name: 'UG-Waschküche',
                    deviceStates: [
                                      { id: 'zigbee.0.00158d008b619293.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                      { id: 'zigbee.0.00158d008b619293.humidity',     icon: 'wi wi-humidity', suffix: '%' }
        Thermo and humidy of the sleeping room OG:
        and
          sdetweil @kusselin
          @kusselin
          the id you listed for zigbee ids are different from what you have in the iobroker config
          i dont know why they would change
          kusselinK 1 Reply Last reply Reply Quote 0
          • kusselinK Offline
            kusselin @sdetweil
            hi…i can´t sie that there is a different ID
            when you look in the config from MM config you see the ID for “OG-Schlafzimmer” an this is the same iD i posted "Sleeping room -OG.
            and when the ID were wrong between MM and iobroker the name don´t displayed, but it´s o.k. and the name is display…
            what else could it be?
            I’m a bit annoyed because there must be more people who do this with Iobroker…and no one answers here :-(
              sdetweil @kusselin
              @kusselin sorry, I didn’t scroll down to see that you had multiple items listed…
              is it only the OG room not displaying??
              can you display the output of the npm start for the container
              can you insure the container can ping the server
              ‘192.168.200.38’
              • kusselinK Offline
                kusselin @sdetweil
                 ping 192.168.200.38
                Ping wird ausgeführt für 192.168.200.38 mit 32 Bytes Daten:
                Antwort von 192.168.200.38: Bytes=32 Zeit<1ms TTL=64
                Ping-Statistik für 192.168.200.38:
                    Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
                    (0% Verlust),
                Ca. Zeitangaben in Millisek.:
                    Minimum = 0ms, Maximum = 0ms, Mittelwert = 0ms
                MagicMirror LXC Container
                    🌐   Provided by: community-scripts ORG | GitHub: https://github.com/community-scripts/ProxmoxVE
                    🖥️   OS: Debian GNU/Linux - Version: 12
                    🏠   Hostname: magicmirror-live
                    💡   IP Address: 192.168.200.74
                root@magicmirror-live:~# cd /magicmirror
                -bash: cd: /magicmirror: No such file or directory
                root@magicmirror-live:~# cd /opt
                root@magicmirror-live:/opt# cd magicmirror
                root@magicmirror-live:/opt/magicmirror# npm start
                > magicmirror@2.31.0 start
                > npm run start:x11
                > magicmirror@2.31.0 start:x11
                /opt/magicmirror/node_modules/electron/dist/electron: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory
                  sdetweil @kusselin
                  @kusselin said in MMM-ioBroker - it will not show:
                  libnss3.so
                  yeh, gotta load that in the container
                  • kusselinK Offline
                    kusselin @sdetweil
                    Hi sdetweil, ha the MM is installed in a Proxmox LXC Container with Ubuntu 24.xx via the Proxmox Helpers scripts. But I already mentioned that above…MM is not installed on a PI…
                    What does the message say?
                    Have you discovered the error?
                    But it worked all the time in the container.
                    How do you load it into the container?
                    Thank you
                      sdetweil @kusselin
                      I don’t know anything about proxmox containers…
                      if on docker and you want the web UI to work, you have to install that library
                      (sudo apt… in the dockerfile)
                      I don’t know how you do that on proxmox container…
                      • kusselinK Offline
                        kusselin @sdetweil
                        Do you mean then sudo apt install libnss3.so ?
                        root@magicmirror-live:/opt/magicmirror# apt install libnss3.so
                        Reading package lists... Done
                        Building dependency tree... Done
                        Reading state information... Done
                        E: Unable to locate package libnss3.so
                        E: Couldn't find any package by glob 'libnss3.so'
                          sdetweil @kusselin
                          @kusselin see
                          https://github.com/claabs/epicgames-freegames-node/issues/359
                          • kusselinK Offline
                            kusselin @sdetweil
                            Hello, thank you. I have installed the dependency in github to your link and made a reboot…unfortunately the temp and humidity is still not displayed :-(
                            look i have now done “npm start” again…now this message comes up:
                            root@magicmirror-test:/opt/magicmirror# npm start
                            > npm run start:x11
                            /opt/magicmirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
                            it’s just strange…I’ve never had these messages before…I’ve reinstalled the MM several times…but I’ve never had these messages…
                            As the developer of MM, could you explain to me what this message means?
                            thanks a lot Sam
                              sdetweil @kusselin
                              @kusselin a program is made up of lots of functions to call services of all kinds. electron is a browser program, they all want to draw graphics on the screen. everything is graphics
                              how they do that depends on a lot of system functions
                              each release of the program needs system services and these may change
                              gtk is the graphical toolkit
                              now you need to load that library too
                              we just use electron, we dont know what its dependencies are, but this why we say you need full os instead of lite
                              • kusselinK Offline
                                kusselin @sdetweil
                                what i just don’t understand is… i have installed the MM in the LXC several times and never received these messages…why now?
                                I have to create a new user with ‘adduser’ and then what do I have to do Sam?
