    MMM-ioBroker - it will not show
    34 Posts 3 Posters 7.5k Views 3 Watching
      @sdetweil :-) For me this is pretty clear and obvious - in addition I do NOT perform every update/upgrade (“never touch a running system”) because I’m checking upfront if a new release brings in anything I potentially need.
      But the thread opener is at least irritated and asks for commandlines to copy.
      I assume the thread opener is aware that everything herein is “enter at your own risk”.
      That you - as the script creator and owner - are even more cautious is appropriate and highly welcome and appreciated!
      Ralf
      kusselinK 1 Reply Last reply Reply Quote 0
      • kusselinK Offline
        kusselin @rkorell
        @rkorell
        Sorry everyone, I still don’t get it…when I run the upgrade command with -force then node and npm is up to date and I don’t get an error message.
        Why does Iobroker with the Zigbee adapter suddenly stop displaying anything? Iobroker and the Zigbee adapter are running perfectly.
          sdetweil @kusselin
          @kusselin can you show the output of npm start , or if using pm2
          pm2 logs --lines=100
          • kusselinK Offline
            kusselin @sdetweil
            is the pm2 log located at
            /home/mm/.pm2
            and how do I create the output of npm start?
            mm@MagicMirror-live:~$ npm start
            npm error code ENOENT
            npm error syscall open
            npm error path /home/mm/package.json
            npm error errno -2
            npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/mm/package.json'
            npm error enoent This is related to npm not being able to find a file.
            npm error enoent
            npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-10T19_02_15_732Z-debug-0.log
            mm@MagicMirror-live:~$ cd MagicMirror
            mm@MagicMirror-live:~/MagicMirror$ npm start
            > magicmirror@2.31.0 start
            > npm run start:x11
            > magicmirror@2.31.0 start:x11
            sh: 1: ./node_modules/.bin/electron: not found
              sdetweil @kusselin
              @kusselin weird
              npm install electron@35.1.2
              • kusselinK Offline
                kusselin @sdetweil
                sorry, please forget me :-(
                and now?
                mm@MagicMirror-live:~/MagicMirror$ npm install electron@35.1.2
                added 654 packages in 20s
                285 packages are looking for funding
                  run `npm fund` for details
                  sdetweil @kusselin
                  @kusselin npm start
                  • kusselinK Offline
                    kusselin @sdetweil
                    look :-(
                    npm error code ENOSPC
                    npm error syscall write
                    npm error errno -28
                    npm error nospc ENOSPC: no space left on device, write
                    npm error nospc There appears to be insufficient space on your system to finish.
                    npm error nospc Clear up some disk space and try again.
                    npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-10T19_51_54_629Z-debug-0.log
                    and
                     verbose cli /usr/local/bin/node /usr/local/bin/npm
                    1 info using npm@10.9.2
                    2 info using node@v22.14.0
                    3 silly config load:file:/usr/local/lib/node_modules/npm/npmrc
                    4 silly config load:file:/home/mm/MagicMirror/.npmrc
                    5 silly config load:file:/home/mm/.npmrc
                    6 silly config load:file:/usr/local/etc/npmrc
                    7 verbose title npm run start:x11
                    8 verbose argv "run" "start:x11"
                    9 verbose logfile logs-max:10 dir:/home/mm/.npm/_logs/2025-04-10T19_51_37_854Z-
                    10 verbose logfile /home/mm/.npm/_logs/2025-04-10T19_51_37_854Z-debug-0.log
                    11 silly logfile start cleaning logs, removing 1 files
                    12 silly logfile done cleaning log files
                    13 verbose cwd /home/mm/MagicMirror
                    14 verbose os Linux 6.8.12-8-pve
                    15 verbose node v22.14.0
                    16 verbose npm  v10.9.2
                    17 verbose exit 1
                    18 verbose code 1
                      sdetweil @kusselin
                      @kusselin ok, this typically indicates a failing sd card, happens too often
                      backup now , but my backup wont work w no disk space
                      copy config.js and custom.css to a someplace, network , usb stick, email
                      get a list of all the modules
                      cd ~/MagicMirror/modules
                      ls -laF
                      add that output to the place u saved
                      make a new sd card, boot, install MagicMirror
                      copy back config and css
                      reinstall the modules
                      • kusselinK Offline
                        kusselin @sdetweil
                        Thank you…that’s funny…I don’t have any SD in use. I have installed the MM in a Proxmox container…ok then I know that something is wrong and I have to create a new container…config and costum.css I save and modules too…
                        Thank you again
                        • kusselinK Offline
                          kusselin
                          Hello everyone,
                          hello stedweil,
                          an update…I have reinstalled the MM and I have said that I have it running in a Proxmox container (LXC)…that also worked via this page:
                          https://tteck.github.io/Proxmox/#miscellaneous
                          the installation worked perfectly…then I adjusted the config one after the other…
                          all modules work, regardless of whether they are MMM-Fuel, MMM-Clock or Calender…only not the MMM-ioBroker…my temperature and humidity data records are still not displayed
                          @stedweil: Let’s please go through again step by step what I can do to possibly narrow down the error. I bought the Aquara parts especially to display this via MM and it actually worked until recently.
                          Thank you in advance
                          		module: 'MMM-ioBroker',
                          		position: 'top_left',
                          		  host: '192.168.200.38',
                          		  port: '8082',
                          		  https: false,
                          		  devices: [
                                    { name: 'EG-Ankleide',
                                      deviceStates: [
                                                        { id: 'zigbee.0.00158d0002fb4915.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                                        { id: 'zigbee.0.00158d0002fb4915.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                          		  { name: 'EG-Büro',
                                      deviceStates: [
                                                        { id: 'zigbee.0.00158d0006d571bb.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                                        { id: 'zigbee.0.00158d0006d571bb.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                          		  { name: 'EG-Bad',
                                      deviceStates: [
                                                        { id: 'zigbee.0.00158d0006e3ee77.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                                        { id: 'zigbee.0.00158d0006e3ee77.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                          		  { name: 'EG-Wohnzimmer',
                                      deviceStates: [
                                                        { id: 'hm-rpc.0.NEQ1522239.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                                        { id: 'hm-rpc.0.NEQ1522239.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                          		{ name: 'Dach-Speicher',
                                      deviceStates: [
                                                        { id: 'hm-rpc.0.KEQ0242488.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                                        { id: 'hm-rpc.0.KEQ0242488.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                          			{ name: 'Treppenhaus',
                                      deviceStates: [
                                                        { id: 'hm-rpc.0.LEQ0592936.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                                        { id: 'hm-rpc.0.LEQ0592936.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                          			{ name: 'OG-Bad',
                                      deviceStates: [
                                                        { id: 'zigbee.0.00158d008b644f6f.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                        { id: 'zigbee.0.00158d008b644f6f.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                          			{ name: 'OG-Wohnzimmer',
                                      deviceStates: [
                                                        { id: 'zigbee.0.00158d008b64556c.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                        { id: 'zigbee.0.00158d008b64556c.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                          			{ name: 'OG-Rumpelzimmer',
                                      deviceStates: [
                                                        { id: 'zigbee.0.00158d008b644eff.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                        { id: 'zigbee.0.00158d008b644eff.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                          			{ name: 'OG-Esszimmer',
                                      deviceStates: [
                                                        { id: 'zigbee.0.00158d008b6192cd.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                        { id: 'zigbee.0.00158d008b6192cd.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                          			{ name: 'OG-Schlafzimmer',
                                      deviceStates: [
                                                        { id: 'zigbee.0.00158d008b69c067.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                        { id: 'zigbee.0.00158d008b69c067.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                          			{ name: 'UG-Waschküche',
                                      deviceStates: [
                                                        { id: 'zigbee.0.00158d008b619293.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                        { id: 'zigbee.0.00158d008b619293.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                          Thermo and humidy of the sleeping room OG:
                          and
                            sdetweil @kusselin
                            @kusselin
                            the id you listed for zigbee ids are different from what you have in the iobroker config
                            i dont know why they would change
                            • kusselinK Offline
                              kusselin @sdetweil
                              hi…i can´t sie that there is a different ID
                              when you look in the config from MM config you see the ID for “OG-Schlafzimmer” an this is the same iD i posted "Sleeping room -OG.
                              and when the ID were wrong between MM and iobroker the name don´t displayed, but it´s o.k. and the name is display…
                              what else could it be?
                              I’m a bit annoyed because there must be more people who do this with Iobroker…and no one answers here :-(
                                sdetweil @kusselin
                                @kusselin sorry, I didn’t scroll down to see that you had multiple items listed…
                                is it only the OG room not displaying??
                                can you display the output of the npm start for the container
                                can you insure the container can ping the server
                                ‘192.168.200.38’
                                • kusselinK Offline
                                  kusselin @sdetweil
                                   ping 192.168.200.38
                                  Ping wird ausgeführt für 192.168.200.38 mit 32 Bytes Daten:
                                  Antwort von 192.168.200.38: Bytes=32 Zeit<1ms TTL=64
                                  Ping-Statistik für 192.168.200.38:
                                      Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
                                      (0% Verlust),
                                  Ca. Zeitangaben in Millisek.:
                                      Minimum = 0ms, Maximum = 0ms, Mittelwert = 0ms
                                  MagicMirror LXC Container
                                      🌐   Provided by: community-scripts ORG | GitHub: https://github.com/community-scripts/ProxmoxVE
                                      🖥️   OS: Debian GNU/Linux - Version: 12
                                      🏠   Hostname: magicmirror-live
                                      💡   IP Address: 192.168.200.74
                                  root@magicmirror-live:~# cd /magicmirror
                                  -bash: cd: /magicmirror: No such file or directory
                                  root@magicmirror-live:~# cd /opt
                                  root@magicmirror-live:/opt# cd magicmirror
                                  root@magicmirror-live:/opt/magicmirror# npm start
                                  > npm run start:x11
                                  /opt/magicmirror/node_modules/electron/dist/electron: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory
                                    sdetweil @kusselin
                                    @kusselin said in MMM-ioBroker - it will not show:
                                    libnss3.so
                                    yeh, gotta load that in the container
                                    • kusselinK Offline
                                      kusselin @sdetweil
                                      Hi sdetweil, ha the MM is installed in a Proxmox LXC Container with Ubuntu 24.xx via the Proxmox Helpers scripts. But I already mentioned that above…MM is not installed on a PI…
                                      What does the message say?
                                      Have you discovered the error?
                                      But it worked all the time in the container.
                                      How do you load it into the container?
                                      Thank you
                                        sdetweil @kusselin
                                        I don’t know anything about proxmox containers…
                                        if on docker and you want the web UI to work, you have to install that library
                                        (sudo apt… in the dockerfile)
                                        I don’t know how you do that on proxmox container…
                                        • kusselinK Offline
                                          kusselin @sdetweil
                                          Do you mean then sudo apt install libnss3.so ?
                                          root@magicmirror-live:/opt/magicmirror# apt install libnss3.so
                                          Reading package lists... Done
                                          Building dependency tree... Done
                                          E: Unable to locate package libnss3.so
                                          E: Couldn't find any package by glob 'libnss3.so'
                                            sdetweil @kusselin
                                            @kusselin see
                                            https://github.com/claabs/epicgames-freegames-node/issues/359
