    MMM-ioBroker - it will not show
    34 Posts 3 Posters 7.5k Views 3 Watching
      rkorell Module Developer @kusselin
      @kusselin said
      Can you please tell me the Linux commands I need to use to get it working again.
      Hi @kusselin , Sam is talking about parameters you can - and should - overhand to his update-script.
      If you call the script - as is - without parameter the script only do a “test-run” and did not change anything.
      The “normal” parameter to DO the upgrade is “apyly” for this the unix command is:
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" -apply
      Sam is assuming that you already HAVE done some upgrades - for this reason he states “and you loaded the new code” . IF you had already loaded some new versions the above command will “fail” also because you already HAVE the new version.
      So for this case you have to use the “force” parameter.
      The unix command for this is:
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" -force
      Good luck!
      Ralf
        sdetweil @rkorell
        @rkorell right, but the web page has the copy/paste commands already set up. so you just have to click copy on the correct line, you dont have to type anything
        the ‘problem’ is that you tried the manual update way, which downloaded (git pull) the new MagicMirror version .
        so when my upgrade script checks the version agsinst the github repo they match. oops
        upgrade is so previous because you have a running system. iIdont want to destroy that. so i wont let upgrade run if you are slready at the same level.
        you have to force it
        in this case you take the do copy/paste, which has
        apply
        at the end
        and change the to
        force
        i dont supply a copy/paste for that because i dont want people using it if its not needed,
        iobroker is broken cause MagicMirror is in a weird state
          @sdetweil said in MMM-ioBroker - it will not show:
          valid point, but @kusselin seems to struggle :-)
          Regards,
          Ralf
            sdetweil @rkorell
            @rkorell i understand.
            this is exactly why ive added the upgrade script.
            the base requires system changes. not knowing or understanding can lead to this exact mess
            but ive made install/upgrade a copy paste so there is no typo problems
            using force is dangerous,
            if you use my upgrade script EVERY time, then there will not be problems.
              @sdetweil :-) For me this is pretty clear and obvious - in addition I do NOT perform every update/upgrade (“never touch a running system”) because I’m checking upfront if a new release brings in anything I potentially need.
              But the thread opener is at least irritated and asks for commandlines to copy.
              I assume the thread opener is aware that everything herein is “enter at your own risk”.
              That you - as the script creator and owner - are even more cautious is appropriate and highly welcome and appreciated!
              Ralf
              kusselinK 1 Reply Last reply Reply Quote 0
              • kusselinK Offline
                kusselin @rkorell
                @rkorell
                Sorry everyone, I still don’t get it…when I run the upgrade command with -force then node and npm is up to date and I don’t get an error message.
                Why does Iobroker with the Zigbee adapter suddenly stop displaying anything? Iobroker and the Zigbee adapter are running perfectly.
                  sdetweil @kusselin
                  @kusselin can you show the output of npm start , or if using pm2
                  pm2 logs --lines=100
                  • kusselinK Offline
                    kusselin @sdetweil
                    is the pm2 log located at
                    /home/mm/.pm2
                    and how do I create the output of npm start?
                    mm@MagicMirror-live:~$ npm start
                    npm error code ENOENT
                    npm error syscall open
                    npm error path /home/mm/package.json
                    npm error errno -2
                    npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/mm/package.json'
                    npm error enoent This is related to npm not being able to find a file.
                    npm error enoent
                    npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-10T19_02_15_732Z-debug-0.log
                    mm@MagicMirror-live:~$ cd MagicMirror
                    mm@MagicMirror-live:~/MagicMirror$ npm start
                    > magicmirror@2.31.0 start
                    > npm run start:x11
                    > magicmirror@2.31.0 start:x11
                    sh: 1: ./node_modules/.bin/electron: not found
                      sdetweil @kusselin
                      @kusselin weird
                      npm install electron@35.1.2
                      • kusselinK Offline
                        kusselin @sdetweil
                        sorry, please forget me :-(
                        and now?
                        mm@MagicMirror-live:~/MagicMirror$ npm install electron@35.1.2
                        added 654 packages in 20s
                        285 packages are looking for funding
                          run `npm fund` for details
                          sdetweil @kusselin
                          @kusselin npm start
                          • kusselinK Offline
                            kusselin @sdetweil
                            look :-(
                            npm error code ENOSPC
                            npm error syscall write
                            npm error errno -28
                            npm error nospc ENOSPC: no space left on device, write
                            npm error nospc There appears to be insufficient space on your system to finish.
                            npm error nospc Clear up some disk space and try again.
                            npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-10T19_51_54_629Z-debug-0.log
                            and
                             verbose cli /usr/local/bin/node /usr/local/bin/npm
                            1 info using npm@10.9.2
                            2 info using node@v22.14.0
                            3 silly config load:file:/usr/local/lib/node_modules/npm/npmrc
                            4 silly config load:file:/home/mm/MagicMirror/.npmrc
                            5 silly config load:file:/home/mm/.npmrc
                            6 silly config load:file:/usr/local/etc/npmrc
                            7 verbose title npm run start:x11
                            8 verbose argv "run" "start:x11"
                            9 verbose logfile logs-max:10 dir:/home/mm/.npm/_logs/2025-04-10T19_51_37_854Z-
                            10 verbose logfile /home/mm/.npm/_logs/2025-04-10T19_51_37_854Z-debug-0.log
                            11 silly logfile start cleaning logs, removing 1 files
                            12 silly logfile done cleaning log files
                            13 verbose cwd /home/mm/MagicMirror
                            14 verbose os Linux 6.8.12-8-pve
                            15 verbose node v22.14.0
                            16 verbose npm  v10.9.2
                            17 verbose exit 1
                            18 verbose code 1
                              sdetweil @kusselin
                              @kusselin ok, this typically indicates a failing sd card, happens too often
                              backup now , but my backup wont work w no disk space
                              copy config.js and custom.css to a someplace, network , usb stick, email
                              get a list of all the modules
                              cd ~/MagicMirror/modules
                              ls -laF
                              add that output to the place u saved
                              make a new sd card, boot, install MagicMirror
                              copy back config and css
                              reinstall the modules
                              • kusselinK Offline
                                kusselin @sdetweil
                                Thank you…that’s funny…I don’t have any SD in use. I have installed the MM in a Proxmox container…ok then I know that something is wrong and I have to create a new container…config and costum.css I save and modules too…
                                Thank you again
                                • kusselinK Offline
                                  kusselin
                                  Hello everyone,
                                  hello stedweil,
                                  an update…I have reinstalled the MM and I have said that I have it running in a Proxmox container (LXC)…that also worked via this page:
                                  https://tteck.github.io/Proxmox/#miscellaneous
                                  the installation worked perfectly…then I adjusted the config one after the other…
                                  all modules work, regardless of whether they are MMM-Fuel, MMM-Clock or Calender…only not the MMM-ioBroker…my temperature and humidity data records are still not displayed
                                  @stedweil: Let’s please go through again step by step what I can do to possibly narrow down the error. I bought the Aquara parts especially to display this via MM and it actually worked until recently.
                                  Thank you in advance
                                  		module: 'MMM-ioBroker',
                                  		position: 'top_left',
                                  		  host: '192.168.200.38',
                                  		  port: '8082',
                                  		  https: false,
                                  		  devices: [
                                            { name: 'EG-Ankleide',
                                              deviceStates: [
        { id: 'zigbee.0.00158d0002fb4915.temperature', icon: 'wi wi-thermometer', suffix: '°' },
        { id: 'zigbee.0.00158d0002fb4915.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                                  		  { name: 'EG-Büro',
                                              deviceStates: [
        { id: 'zigbee.0.00158d0006d571bb.temperature', icon: 'wi wi-thermometer', suffix: '°' },
        { id: 'zigbee.0.00158d0006d571bb.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                                  		  { name: 'EG-Bad',
                                              deviceStates: [
        { id: 'zigbee.0.00158d0006e3ee77.temperature', icon: 'wi wi-thermometer', suffix: '°' },
        { id: 'zigbee.0.00158d0006e3ee77.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                                  		  { name: 'EG-Wohnzimmer',
                                              deviceStates: [
        { id: 'hm-rpc.0.NEQ1522239.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'hm-rpc.0.NEQ1522239.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                                  		{ name: 'Dach-Speicher',
                                              deviceStates: [
        { id: 'hm-rpc.0.KEQ0242488.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'hm-rpc.0.KEQ0242488.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                                  			{ name: 'Treppenhaus',
                                              deviceStates: [
        { id: 'hm-rpc.0.LEQ0592936.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'hm-rpc.0.LEQ0592936.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                                  			{ name: 'OG-Bad',
                                              deviceStates: [
        { id: 'zigbee.0.00158d008b644f6f.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'zigbee.0.00158d008b644f6f.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                                  			{ name: 'OG-Wohnzimmer',
                                              deviceStates: [
        { id: 'zigbee.0.00158d008b64556c.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'zigbee.0.00158d008b64556c.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                                  			{ name: 'OG-Rumpelzimmer',
                                              deviceStates: [
        { id: 'zigbee.0.00158d008b644eff.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'zigbee.0.00158d008b644eff.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                                  			{ name: 'OG-Esszimmer',
                                              deviceStates: [
        { id: 'zigbee.0.00158d008b6192cd.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'zigbee.0.00158d008b6192cd.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                                  			{ name: 'OG-Schlafzimmer',
                                              deviceStates: [
        { id: 'zigbee.0.00158d008b69c067.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'zigbee.0.00158d008b69c067.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                                  			{ name: 'UG-Waschküche',
                                              deviceStates: [
        { id: 'zigbee.0.00158d008b619293.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'zigbee.0.00158d008b619293.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                                  Thermo and humidy of the sleeping room OG:
                                  and
                                    sdetweil @kusselin
                                    @kusselin
                                    the id you listed for zigbee ids are different from what you have in the iobroker config
                                    i dont know why they would change
                                    • kusselinK Offline
                                      kusselin @sdetweil
                                      hi…i can´t sie that there is a different ID
                                      when you look in the config from MM config you see the ID for “OG-Schlafzimmer” an this is the same iD i posted "Sleeping room -OG.
                                      and when the ID were wrong between MM and iobroker the name don´t displayed, but it´s o.k. and the name is display…
                                      what else could it be?
                                      I’m a bit annoyed because there must be more people who do this with Iobroker…and no one answers here :-(
                                        sdetweil @kusselin
                                        @kusselin sorry, I didn’t scroll down to see that you had multiple items listed…
                                        is it only the OG room not displaying??
                                        can you display the output of the npm start for the container
                                        can you insure the container can ping the server
                                        ‘192.168.200.38’
                                        • kusselinK Offline
                                          kusselin @sdetweil
                                           ping 192.168.200.38
                                          Ping wird ausgeführt für 192.168.200.38 mit 32 Bytes Daten:
                                          Antwort von 192.168.200.38: Bytes=32 Zeit<1ms TTL=64
                                          Ping-Statistik für 192.168.200.38:
                                              Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
                                              (0% Verlust),
                                          Ca. Zeitangaben in Millisek.:
                                              Minimum = 0ms, Maximum = 0ms, Mittelwert = 0ms
                                          MagicMirror LXC Container
                                              🌐   Provided by: community-scripts ORG | GitHub: https://github.com/community-scripts/ProxmoxVE
                                              🖥️   OS: Debian GNU/Linux - Version: 12
                                              🏠   Hostname: magicmirror-live
                                              💡   IP Address: 192.168.200.74
                                          root@magicmirror-live:~# cd /magicmirror
                                          -bash: cd: /magicmirror: No such file or directory
                                          root@magicmirror-live:~# cd /opt
                                          root@magicmirror-live:/opt# cd magicmirror
                                          root@magicmirror-live:/opt/magicmirror# npm start
                                          > npm run start:x11
                                          /opt/magicmirror/node_modules/electron/dist/electron: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory
                                            sdetweil @kusselin
                                            @kusselin said in MMM-ioBroker - it will not show:
                                            libnss3.so
                                            yeh, gotta load that in the container
