    MMM-ioBroker - it will not show
    34 Posts 3 Posters 7.2k Views 3 Watching
      sdetweil @kusselin
      @kusselin my upgrade script is 2 steps
      test, do nothing
      do
      same script, no parms is test
      add apply to the end does
      BUT, it will NOT install upgrades AGAIN if the version matches
      and you loaded the new code
      so you have to use the word
      force
      instead of
      apply
      please translate the page, instead of having trouble with my english
      kusselinK 1 Reply Last reply Reply Quote 0
      • kusselinK Offline
        kusselin @sdetweil
        Hi sdetweil, thanks for your help. Since I am not a Linux expert I do everything with copy&paste…means also the installation of MM everything made by commands…
        Can you please tell me the Linux commands I need to use to get it working again. thank you!
        Or does it have something to do with Iobroker why the temp values are no longer displayed?
        But in iobroker everything works with the Zigbee adapter.
        I have not changed anything else in the config or anywhere else in MM
        Please help me.
          rkorell Module Developer @kusselin
          Hi @kusselin , Sam is talking about parameters you can - and should - overhand to his update-script.
          If you call the script - as is - without parameter the script only do a “test-run” and did not change anything.
          The “normal” parameter to DO the upgrade is “apyly” for this the unix command is:
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" -apply
          Sam is assuming that you already HAVE done some upgrades - for this reason he states “and you loaded the new code” . IF you had already loaded some new versions the above command will “fail” also because you already HAVE the new version.
          So for this case you have to use the “force” parameter.
          The unix command for this is:
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" -force
          Good luck!
          Ralf
            sdetweil @rkorell
            @rkorell right, but the web page has the copy/paste commands already set up. so you just have to click copy on the correct line, you dont have to type anything
            the ‘problem’ is that you tried the manual update way, which downloaded (git pull) the new MagicMirror version .
            so when my upgrade script checks the version agsinst the github repo they match. oops
            upgrade is so previous because you have a running system. iIdont want to destroy that. so i wont let upgrade run if you are slready at the same level.
            you have to force it
            in this case you take the do copy/paste, which has
            apply
            at the end
            and change the to
            force
            i dont supply a copy/paste for that because i dont want people using it if its not needed,
            iobroker is broken cause MagicMirror is in a weird state
              @sdetweil said in MMM-ioBroker - it will not show:
              valid point, but @kusselin seems to struggle :-)
              Regards,
              Ralf
                sdetweil @rkorell
                @rkorell i understand.
                this is exactly why ive added the upgrade script.
                the base requires system changes. not knowing or understanding can lead to this exact mess
                but ive made install/upgrade a copy paste so there is no typo problems
                using force is dangerous,
                if you use my upgrade script EVERY time, then there will not be problems.
                  @sdetweil :-) For me this is pretty clear and obvious - in addition I do NOT perform every update/upgrade (“never touch a running system”) because I’m checking upfront if a new release brings in anything I potentially need.
                  But the thread opener is at least irritated and asks for commandlines to copy.
                  I assume the thread opener is aware that everything herein is “enter at your own risk”.
                  That you - as the script creator and owner - are even more cautious is appropriate and highly welcome and appreciated!
                  Ralf
                  • kusselinK Offline
                    kusselin @rkorell
                    @rkorell
                    Sorry everyone, I still don’t get it…when I run the upgrade command with -force then node and npm is up to date and I don’t get an error message.
                    Why does Iobroker with the Zigbee adapter suddenly stop displaying anything? Iobroker and the Zigbee adapter are running perfectly.
                      sdetweil @kusselin
                      @kusselin can you show the output of npm start , or if using pm2
                      pm2 logs --lines=100
                      • kusselinK Offline
                        kusselin @sdetweil
                        is the pm2 log located at
                        /home/mm/.pm2
                        and how do I create the output of npm start?
                        mm@MagicMirror-live:~$ npm start
                        npm error code ENOENT
                        npm error syscall open
                        npm error path /home/mm/package.json
                        npm error errno -2
                        npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/mm/package.json'
                        npm error enoent This is related to npm not being able to find a file.
                        npm error enoent
                        npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-10T19_02_15_732Z-debug-0.log
                        mm@MagicMirror-live:~$ cd MagicMirror
                        mm@MagicMirror-live:~/MagicMirror$ npm start
                        > magicmirror@2.31.0 start
                        > npm run start:x11
                        > magicmirror@2.31.0 start:x11
                        sh: 1: ./node_modules/.bin/electron: not found
                          sdetweil @kusselin
                          @kusselin weird
                          npm install electron@35.1.2
                          • kusselinK Offline
                            kusselin @sdetweil
                            sorry, please forget me :-(
                            and now?
                            mm@MagicMirror-live:~/MagicMirror$ npm install electron@35.1.2
                            added 654 packages in 20s
                            285 packages are looking for funding
                              run `npm fund` for details
                              sdetweil @kusselin
                              @kusselin npm start
                              • kusselinK Offline
                                kusselin @sdetweil
                                look :-(
                                npm error code ENOSPC
                                npm error syscall write
                                npm error errno -28
                                npm error nospc ENOSPC: no space left on device, write
                                npm error nospc There appears to be insufficient space on your system to finish.
                                npm error nospc Clear up some disk space and try again.
                                npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-10T19_51_54_629Z-debug-0.log
                                and
                                 verbose cli /usr/local/bin/node /usr/local/bin/npm
                                1 info using npm@10.9.2
                                2 info using node@v22.14.0
                                3 silly config load:file:/usr/local/lib/node_modules/npm/npmrc
                                4 silly config load:file:/home/mm/MagicMirror/.npmrc
                                5 silly config load:file:/home/mm/.npmrc
                                6 silly config load:file:/usr/local/etc/npmrc
                                7 verbose title npm run start:x11
                                8 verbose argv "run" "start:x11"
                                9 verbose logfile logs-max:10 dir:/home/mm/.npm/_logs/2025-04-10T19_51_37_854Z-
                                10 verbose logfile /home/mm/.npm/_logs/2025-04-10T19_51_37_854Z-debug-0.log
                                11 silly logfile start cleaning logs, removing 1 files
                                12 silly logfile done cleaning log files
                                13 verbose cwd /home/mm/MagicMirror
                                14 verbose os Linux 6.8.12-8-pve
                                15 verbose node v22.14.0
                                16 verbose npm  v10.9.2
                                17 verbose exit 1
                                18 verbose code 1
                                  sdetweil @kusselin
                                  @kusselin ok, this typically indicates a failing sd card, happens too often
                                  backup now , but my backup wont work w no disk space
                                  copy config.js and custom.css to a someplace, network , usb stick, email
                                  get a list of all the modules
                                  cd ~/MagicMirror/modules
                                  ls -laF
                                  add that output to the place u saved
                                  make a new sd card, boot, install MagicMirror
                                  copy back config and css
                                  reinstall the modules
                                  • kusselinK Offline
                                    kusselin @sdetweil
                                    Thank you…that’s funny…I don’t have any SD in use. I have installed the MM in a Proxmox container…ok then I know that something is wrong and I have to create a new container…config and costum.css I save and modules too…
                                    Thank you again
                                    • kusselinK Offline
                                      kusselin
                                      Hello everyone,
                                      hello stedweil,
                                      an update…I have reinstalled the MM and I have said that I have it running in a Proxmox container (LXC)…that also worked via this page:
                                      https://tteck.github.io/Proxmox/#miscellaneous
                                      the installation worked perfectly…then I adjusted the config one after the other…
                                      all modules work, regardless of whether they are MMM-Fuel, MMM-Clock or Calender…only not the MMM-ioBroker…my temperature and humidity data records are still not displayed
                                      @stedweil: Let’s please go through again step by step what I can do to possibly narrow down the error. I bought the Aquara parts especially to display this via MM and it actually worked until recently.
                                      Thank you in advance
                                      		module: 'MMM-ioBroker',
                                      		position: 'top_left',
                                      		  host: '192.168.200.38',
                                      		  port: '8082',
                                      		  https: false,
                                      		  devices: [
                                                { name: 'EG-Ankleide',
                                                  deviceStates: [
        { id: 'zigbee.0.00158d0002fb4915.temperature', icon: 'wi wi-thermometer', suffix: '°' },
        { id: 'zigbee.0.00158d0002fb4915.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                                      		  { name: 'EG-Büro',
                                                  deviceStates: [
        { id: 'zigbee.0.00158d0006d571bb.temperature', icon: 'wi wi-thermometer', suffix: '°' },
        { id: 'zigbee.0.00158d0006d571bb.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                                      		  { name: 'EG-Bad',
                                                  deviceStates: [
        { id: 'zigbee.0.00158d0006e3ee77.temperature', icon: 'wi wi-thermometer', suffix: '°' },
        { id: 'zigbee.0.00158d0006e3ee77.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                                      		  { name: 'EG-Wohnzimmer',
                                                  deviceStates: [
        { id: 'hm-rpc.0.NEQ1522239.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'hm-rpc.0.NEQ1522239.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                                      		{ name: 'Dach-Speicher',
                                                  deviceStates: [
        { id: 'hm-rpc.0.KEQ0242488.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'hm-rpc.0.KEQ0242488.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                                      			{ name: 'Treppenhaus',
                                                  deviceStates: [
        { id: 'hm-rpc.0.LEQ0592936.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'hm-rpc.0.LEQ0592936.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                                      			{ name: 'OG-Bad',
                                                  deviceStates: [
        { id: 'zigbee.0.00158d008b644f6f.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'zigbee.0.00158d008b644f6f.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                                      			{ name: 'OG-Wohnzimmer',
                                                  deviceStates: [
        { id: 'zigbee.0.00158d008b64556c.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'zigbee.0.00158d008b64556c.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                                      			{ name: 'OG-Rumpelzimmer',
                                                  deviceStates: [
        { id: 'zigbee.0.00158d008b644eff.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'zigbee.0.00158d008b644eff.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                                      			{ name: 'OG-Esszimmer',
                                                  deviceStates: [
        { id: 'zigbee.0.00158d008b6192cd.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'zigbee.0.00158d008b6192cd.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                                      			{ name: 'OG-Schlafzimmer',
                                                  deviceStates: [
        { id: 'zigbee.0.00158d008b69c067.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'zigbee.0.00158d008b69c067.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                                      			{ name: 'UG-Waschküche',
                                                  deviceStates: [
        { id: 'zigbee.0.00158d008b619293.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
        { id: 'zigbee.0.00158d008b619293.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                                      Thermo and humidy of the sleeping room OG:
                                      and
                                        sdetweil @kusselin
                                        @kusselin
                                        the id you listed for zigbee ids are different from what you have in the iobroker config
                                        i dont know why they would change
                                        • kusselinK Offline
                                          kusselin @sdetweil
                                          hi…i can´t sie that there is a different ID
                                          when you look in the config from MM config you see the ID for “OG-Schlafzimmer” an this is the same iD i posted "Sleeping room -OG.
                                          and when the ID were wrong between MM and iobroker the name don´t displayed, but it´s o.k. and the name is display…
                                          what else could it be?
                                          I’m a bit annoyed because there must be more people who do this with Iobroker…and no one answers here :-(
                                            sdetweil @kusselin
                                            @kusselin sorry, I didn’t scroll down to see that you had multiple items listed…
                                            is it only the OG room not displaying??
                                            can you display the output of the npm start for the container
                                            can you insure the container can ping the server
                                            ‘192.168.200.38’
