    MMM-ioBroker - it will not show
    34 Posts 3 Posters 7.2k Views 3 Watching
      sdetweil @rkorell
      @rkorell i understand.
      this is exactly why ive added the upgrade script.
      the base requires system changes. not knowing or understanding can lead to this exact mess
      but ive made install/upgrade a copy paste so there is no typo problems
      using force is dangerous,
      if you use my upgrade script EVERY time, then there will not be problems.
        @sdetweil :-) For me this is pretty clear and obvious - in addition I do NOT perform every update/upgrade (“never touch a running system”) because I’m checking upfront if a new release brings in anything I potentially need.
        But the thread opener is at least irritated and asks for commandlines to copy.
        I assume the thread opener is aware that everything herein is “enter at your own risk”.
        That you - as the script creator and owner - are even more cautious is appropriate and highly welcome and appreciated!
        Ralf
        kusselinK 1 Reply Last reply Reply Quote 0
        • kusselinK Offline
          kusselin @rkorell
          @rkorell
          Sorry everyone, I still don’t get it…when I run the upgrade command with -force then node and npm is up to date and I don’t get an error message.
          Why does Iobroker with the Zigbee adapter suddenly stop displaying anything? Iobroker and the Zigbee adapter are running perfectly.
            sdetweil @kusselin
            @kusselin can you show the output of npm start , or if using pm2
            pm2 logs --lines=100
            • kusselinK Offline
              kusselin @sdetweil
              is the pm2 log located at
              /home/mm/.pm2
              and how do I create the output of npm start?
              mm@MagicMirror-live:~$ npm start
              npm error code ENOENT
              npm error syscall open
              npm error path /home/mm/package.json
              npm error errno -2
              npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/mm/package.json'
              npm error enoent This is related to npm not being able to find a file.
              npm error enoent
              npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-10T19_02_15_732Z-debug-0.log
              mm@MagicMirror-live:~$ cd MagicMirror
              mm@MagicMirror-live:~/MagicMirror$ npm start
              > magicmirror@2.31.0 start
              > npm run start:x11
              > magicmirror@2.31.0 start:x11
              sh: 1: ./node_modules/.bin/electron: not found
                sdetweil @kusselin
                @kusselin weird
                npm install electron@35.1.2
                • kusselinK Offline
                  kusselin @sdetweil
                  sorry, please forget me :-(
                  and now?
                  mm@MagicMirror-live:~/MagicMirror$ npm install electron@35.1.2
                  added 654 packages in 20s
                  285 packages are looking for funding
                    run `npm fund` for details
                    sdetweil @kusselin
                    @kusselin npm start
                    • kusselinK Offline
                      kusselin @sdetweil
                      look :-(
                      npm error code ENOSPC
                      npm error syscall write
                      npm error errno -28
                      npm error nospc ENOSPC: no space left on device, write
                      npm error nospc There appears to be insufficient space on your system to finish.
                      npm error nospc Clear up some disk space and try again.
                      npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-10T19_51_54_629Z-debug-0.log
                      and
                       verbose cli /usr/local/bin/node /usr/local/bin/npm
                      1 info using npm@10.9.2
                      2 info using node@v22.14.0
                      3 silly config load:file:/usr/local/lib/node_modules/npm/npmrc
                      4 silly config load:file:/home/mm/MagicMirror/.npmrc
                      5 silly config load:file:/home/mm/.npmrc
                      6 silly config load:file:/usr/local/etc/npmrc
                      7 verbose title npm run start:x11
                      8 verbose argv "run" "start:x11"
                      9 verbose logfile logs-max:10 dir:/home/mm/.npm/_logs/2025-04-10T19_51_37_854Z-
                      10 verbose logfile /home/mm/.npm/_logs/2025-04-10T19_51_37_854Z-debug-0.log
                      11 silly logfile start cleaning logs, removing 1 files
                      12 silly logfile done cleaning log files
                      13 verbose cwd /home/mm/MagicMirror
                      14 verbose os Linux 6.8.12-8-pve
                      15 verbose node v22.14.0
                      16 verbose npm  v10.9.2
                      17 verbose exit 1
                      18 verbose code 1
                        sdetweil @kusselin
                        @kusselin ok, this typically indicates a failing sd card, happens too often
                        backup now , but my backup wont work w no disk space
                        copy config.js and custom.css to a someplace, network , usb stick, email
                        get a list of all the modules
                        cd ~/MagicMirror/modules
                        ls -laF
                        add that output to the place u saved
                        make a new sd card, boot, install MagicMirror
                        copy back config and css
                        reinstall the modules
                        • kusselinK Offline
                          kusselin @sdetweil
                          Thank you…that’s funny…I don’t have any SD in use. I have installed the MM in a Proxmox container…ok then I know that something is wrong and I have to create a new container…config and costum.css I save and modules too…
                          Thank you again
                          • kusselinK Offline
                            kusselin
                            Hello everyone,
                            hello stedweil,
                            an update…I have reinstalled the MM and I have said that I have it running in a Proxmox container (LXC)…that also worked via this page:
                            https://tteck.github.io/Proxmox/#miscellaneous
                            the installation worked perfectly…then I adjusted the config one after the other…
                            all modules work, regardless of whether they are MMM-Fuel, MMM-Clock or Calender…only not the MMM-ioBroker…my temperature and humidity data records are still not displayed
                            @stedweil: Let’s please go through again step by step what I can do to possibly narrow down the error. I bought the Aquara parts especially to display this via MM and it actually worked until recently.
                            Thank you in advance
                            		module: 'MMM-ioBroker',
                            		position: 'top_left',
                            		  host: '192.168.200.38',
                            		  port: '8082',
                            		  https: false,
                            		  devices: [
                                      { name: 'EG-Ankleide',
                                        deviceStates: [
                                                          { id: 'zigbee.0.00158d0002fb4915.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                                          { id: 'zigbee.0.00158d0002fb4915.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                            		  { name: 'EG-Büro',
                                        deviceStates: [
                                                          { id: 'zigbee.0.00158d0006d571bb.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                                          { id: 'zigbee.0.00158d0006d571bb.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                            		  { name: 'EG-Bad',
                                        deviceStates: [
                                                          { id: 'zigbee.0.00158d0006e3ee77.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                                          { id: 'zigbee.0.00158d0006e3ee77.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                            		  { name: 'EG-Wohnzimmer',
                                        deviceStates: [
                                                          { id: 'hm-rpc.0.NEQ1522239.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                                          { id: 'hm-rpc.0.NEQ1522239.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                            		{ name: 'Dach-Speicher',
                                        deviceStates: [
                                                          { id: 'hm-rpc.0.KEQ0242488.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                                          { id: 'hm-rpc.0.KEQ0242488.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                            			{ name: 'Treppenhaus',
                                        deviceStates: [
                                                          { id: 'hm-rpc.0.LEQ0592936.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                                          { id: 'hm-rpc.0.LEQ0592936.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                            			{ name: 'OG-Bad',
                                        deviceStates: [
                                                          { id: 'zigbee.0.00158d008b644f6f.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                          { id: 'zigbee.0.00158d008b644f6f.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                            			{ name: 'OG-Wohnzimmer',
                                        deviceStates: [
                                                          { id: 'zigbee.0.00158d008b64556c.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                          { id: 'zigbee.0.00158d008b64556c.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                            			{ name: 'OG-Rumpelzimmer',
                                        deviceStates: [
                                                          { id: 'zigbee.0.00158d008b644eff.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                          { id: 'zigbee.0.00158d008b644eff.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                            			{ name: 'OG-Esszimmer',
                                        deviceStates: [
                                                          { id: 'zigbee.0.00158d008b6192cd.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                          { id: 'zigbee.0.00158d008b6192cd.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                            			{ name: 'OG-Schlafzimmer',
                                        deviceStates: [
                                                          { id: 'zigbee.0.00158d008b69c067.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                          { id: 'zigbee.0.00158d008b69c067.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                            			{ name: 'UG-Waschküche',
                                        deviceStates: [
                                                          { id: 'zigbee.0.00158d008b619293.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                          { id: 'zigbee.0.00158d008b619293.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                            Thermo and humidy of the sleeping room OG:
                            and
                              sdetweil @kusselin
                              @kusselin
                              the id you listed for zigbee ids are different from what you have in the iobroker config
                              i dont know why they would change
                              • kusselinK Offline
                                kusselin @sdetweil
                                hi…i can´t sie that there is a different ID
                                when you look in the config from MM config you see the ID for “OG-Schlafzimmer” an this is the same iD i posted "Sleeping room -OG.
                                and when the ID were wrong between MM and iobroker the name don´t displayed, but it´s o.k. and the name is display…
                                what else could it be?
                                I’m a bit annoyed because there must be more people who do this with Iobroker…and no one answers here :-(
                                  sdetweil @kusselin
                                  @kusselin sorry, I didn’t scroll down to see that you had multiple items listed…
                                  is it only the OG room not displaying??
                                  can you display the output of the npm start for the container
                                  can you insure the container can ping the server
                                  ‘192.168.200.38’
                                  • kusselinK Offline
                                    kusselin @sdetweil
                                     ping 192.168.200.38
                                    Ping wird ausgeführt für 192.168.200.38 mit 32 Bytes Daten:
                                    Antwort von 192.168.200.38: Bytes=32 Zeit<1ms TTL=64
                                    Ping-Statistik für 192.168.200.38:
                                        Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
                                        (0% Verlust),
                                    Ca. Zeitangaben in Millisek.:
                                        Minimum = 0ms, Maximum = 0ms, Mittelwert = 0ms
                                    MagicMirror LXC Container
                                        🌐   Provided by: community-scripts ORG | GitHub: https://github.com/community-scripts/ProxmoxVE
                                        🖥️   OS: Debian GNU/Linux - Version: 12
                                        🏠   Hostname: magicmirror-live
                                        💡   IP Address: 192.168.200.74
                                    root@magicmirror-live:~# cd /magicmirror
                                    -bash: cd: /magicmirror: No such file or directory
                                    root@magicmirror-live:~# cd /opt
                                    root@magicmirror-live:/opt# cd magicmirror
                                    root@magicmirror-live:/opt/magicmirror# npm start
                                    > npm run start:x11
                                    /opt/magicmirror/node_modules/electron/dist/electron: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory
                                      sdetweil @kusselin
                                      @kusselin said in MMM-ioBroker - it will not show:
                                      libnss3.so
                                      yeh, gotta load that in the container
                                      • kusselinK Offline
                                        kusselin @sdetweil
                                        Hi sdetweil, ha the MM is installed in a Proxmox LXC Container with Ubuntu 24.xx via the Proxmox Helpers scripts. But I already mentioned that above…MM is not installed on a PI…
                                        What does the message say?
                                        Have you discovered the error?
                                        But it worked all the time in the container.
                                        How do you load it into the container?
                                        Thank you
                                          sdetweil @kusselin
                                          I don’t know anything about proxmox containers…
                                          if on docker and you want the web UI to work, you have to install that library
                                          (sudo apt… in the dockerfile)
                                          I don’t know how you do that on proxmox container…
                                          • kusselinK Offline
                                            kusselin @sdetweil
                                            Do you mean then sudo apt install libnss3.so ?
                                            root@magicmirror-live:/opt/magicmirror# apt install libnss3.so
                                            Reading package lists... Done
                                            Building dependency tree... Done
                                            E: Unable to locate package libnss3.so
                                            E: Couldn't find any package by glob 'libnss3.so'
