    MMM-ioBroker - it will not show
    34 Posts 3 Posters 5.0k Views 3 Watching
    • kusselinK Offline
      kusselin
      Hello everyone, I have had the MMM-ioBroker module installed for some time and it has always worked and displayed my Aquara temperature gauges…recently it has stopped displaying anything :-( the module is up to date.
      what can I do? what is wrong?
      mm@MagicMirror-live:~/MagicMirror$ git pull && npm run install-mm
      Already up to date.
      > magicmirror@2.31.0 install-mm
      > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: magicmirror@2.31.0
      npm error notsup Not compatible with your version of node/npm: magicmirror@2.31.0
      npm error notsup Required: {"node":">=22.14.0"}
      npm error notsup Actual:   {"npm":"10.8.2","node":"v20.18.1"}
      npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-09T19_49_38_299Z-debug-0.log
      what must i do? Im not the expert…how is the befehl for update npm?
      mm@MagicMirror-live:~/MagicMirror$ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
      update log will be in /home/mm/MagicMirror/installers/upgrade.log
      Minimum Node version: v22.14.0
      Installed Node version: v20.18.1
      Node should be upgraded.
      A Node process is currently running. Can't upgrade.
      Please quit all Node processes and restart the update.
      running process(s) are
      mm           304     271  0 Feb03 ?        00:00:00 sh -c node ./serveronly
      mm           305     304  0 Feb03 ?        01:28:58 node ./serveronly
        sdetweil @kusselin
        @kusselin you need to be at a different node js level
        22.14.0
        if you had used my upgrade script it would have handled that
        kusselinK 1 Reply Last reply Reply Quote 0
        • kusselinK Offline
          kusselin @sdetweil
          @sdetweil is this o.k. so?
          Already up to date.
          > magicmirror@2.31.0 postinstall
          > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
          > magicmirror@2.31.0 install-vendor
          > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          changed 1 package in 1s
          > magicmirror@2.31.0 install-fonts
          > echo "Installing fonts ...
          > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          changed 2 packages in 4s
          > magicmirror@2.31.0 prepare
          > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
          no husky installed.
          added 6 packages, removed 7 packages, and changed 193 packages in 34s
          Installed Node version: v22.14.0
          No Node.js upgrade necessary.
          Minimum npm version: V10.9.2
          Installed npm version: V10.9.2
          No npm upgrade necessary.
          saving custom.css
          upgrading from version 2.31.0 to 2.31.0
          MagicMirror running under control of PM2, stopping
          [PM2] Applying action stopProcessId on app [MagicMirror](ids: [ 0 ])
          [PM2] [MagicMirror](0) ✓
          │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
          │ 0  │ MagicMirror    │ default     │ 2.31.0  │ fork    │ 0        │ 0      │ 437  │ stopped   │ 0%       │ 0b       │ mm       │ disabled │
          fetching latest revisions
          updating dependencies for active modules with package.json files
                  processing for module MMM-Fuel please wait
                  skipped processing for MMM-Fuel, doing test run
                  processing complete for module MMM-Fuel
                  processing for module MMM-RNV please wait
                  skipped processing for MMM-RNV, doing test run
                  processing complete for module MMM-RNV
                  processing for module MMM-PublicTransportHafas please wait
                  skipped processing for MMM-PublicTransportHafas, doing test run
                  processing complete for module MMM-PublicTransportHafas
                  processing for module MMM-ioBroker please wait
                  skipped processing for MMM-ioBroker, doing test run
                  processing complete for module MMM-ioBroker
                  processing for module MMM-COVID19-AMPEL please wait
                  skipped processing for MMM-COVID19-AMPEL, doing test run
                  processing complete for module MMM-COVID19-AMPEL
                  processing for module MMM-soccer please wait
                  skipped processing for MMM-soccer, doing test run
                  processing complete for module MMM-soccer
                  processing for module MMM-Carousel please wait
                  skipped processing for MMM-Carousel, doing test run
                  processing complete for module MMM-Carousel
                  processing for module MMM-Remote-Control please wait
                  skipped processing for MMM-Remote-Control, doing test run
                  processing complete for module MMM-Remote-Control
          restoring custom.css
            sdetweil @kusselin
            @kusselin
            no
            • kusselinK Offline
              kusselin @sdetweil
              @sdetweil Sorry, but I don’t understand what you mean by test run?
              Suddenly the temperature is no longer displayed and I don’t know where the error lies?
              What do I have to do to get it working again?
              thank you thank you thank you
                sdetweil @kusselin
                @kusselin my upgrade script is 2 steps
                test, do nothing
                do
                same script, no parms is test
                add apply to the end does
                BUT, it will NOT install upgrades AGAIN if the version matches
                and you loaded the new code
                so you have to use the word
                force
                instead of
                apply
                please translate the page, instead of having trouble with my english
                • kusselinK Offline
                  kusselin @sdetweil
                  Hi sdetweil, thanks for your help. Since I am not a Linux expert I do everything with copy&paste…means also the installation of MM everything made by commands…
                  Can you please tell me the Linux commands I need to use to get it working again. thank you!
                  Or does it have something to do with Iobroker why the temp values are no longer displayed?
                  But in iobroker everything works with the Zigbee adapter.
                  I have not changed anything else in the config or anywhere else in MM
                  Please help me.
                    rkorell @kusselin
                    Hi @kusselin , Sam is talking about parameters you can - and should - overhand to his update-script.
                    If you call the script - as is - without parameter the script only do a “test-run” and did not change anything.
                    The “normal” parameter to DO the upgrade is “apyly” for this the unix command is:
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" -apply
                    Sam is assuming that you already HAVE done some upgrades - for this reason he states “and you loaded the new code” . IF you had already loaded some new versions the above command will “fail” also because you already HAVE the new version.
                    So for this case you have to use the “force” parameter.
                    The unix command for this is:
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" -force
                    Good luck!
                    Ralf
                      sdetweil @rkorell
                      @rkorell right, but the web page has the copy/paste commands already set up. so you just have to click copy on the correct line, you dont have to type anything
                      the ‘problem’ is that you tried the manual update way, which downloaded (git pull) the new MagicMirror version .
                      so when my upgrade script checks the version agsinst the github repo they match. oops
                      upgrade is so previous because you have a running system. iIdont want to destroy that. so i wont let upgrade run if you are slready at the same level.
                      you have to force it
                      in this case you take the do copy/paste, which has
                      apply
                      at the end
                      and change the to
                      force
                      i dont supply a copy/paste for that because i dont want people using it if its not needed,
                      iobroker is broken cause MagicMirror is in a weird state
                        rkorell @sdetweil
                        @sdetweil said in MMM-ioBroker - it will not show:
                        valid point, but @kusselin seems to struggle :-)
                        Regards,
                        Ralf
                        • 1 / 4
