    MMM-ioBroker - it will not show
    34 Posts 3 Posters 7.8k Views 3 Watching
      sdetweil @kusselin
      @kusselin weird
      npm install electron@35.1.2
      kusselinK 1 Reply Last reply Reply Quote 0
      • kusselinK
        kusselin @sdetweil
        sorry, please forget me :-(
        and now?
        mm@MagicMirror-live:~/MagicMirror$ npm install electron@35.1.2
        added 654 packages in 20s
        285 packages are looking for funding
          run `npm fund` for details
          sdetweil @kusselin
          @kusselin npm start
          • kusselinK
            kusselin @sdetweil
            look :-(
            mm@MagicMirror-live:~$ cd MagicMirror
            mm@MagicMirror-live:~/MagicMirror$ npm start
            npm error code ENOSPC
            npm error syscall write
            npm error errno -28
            npm error nospc ENOSPC: no space left on device, write
            npm error nospc There appears to be insufficient space on your system to finish.
            npm error nospc Clear up some disk space and try again.
            npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-10T19_51_54_629Z-debug-0.log
            and
             verbose cli /usr/local/bin/node /usr/local/bin/npm
            1 info using npm@10.9.2
            2 info using node@v22.14.0
            3 silly config load:file:/usr/local/lib/node_modules/npm/npmrc
            4 silly config load:file:/home/mm/MagicMirror/.npmrc
            5 silly config load:file:/home/mm/.npmrc
            6 silly config load:file:/usr/local/etc/npmrc
            7 verbose title npm run start:x11
            8 verbose argv "run" "start:x11"
            9 verbose logfile logs-max:10 dir:/home/mm/.npm/_logs/2025-04-10T19_51_37_854Z-
            10 verbose logfile /home/mm/.npm/_logs/2025-04-10T19_51_37_854Z-debug-0.log
            11 silly logfile start cleaning logs, removing 1 files
            12 silly logfile done cleaning log files
            13 verbose cwd /home/mm/MagicMirror
            14 verbose os Linux 6.8.12-8-pve
            15 verbose node v22.14.0
            16 verbose npm  v10.9.2
            17 verbose exit 1
            18 verbose code 1
              sdetweil @kusselin
              @kusselin ok, this typically indicates a failing sd card, happens too often
              backup now , but my backup wont work w no disk space
              copy config.js and custom.css to a someplace, network , usb stick, email
              get a list of all the modules
              cd ~/MagicMirror/modules
              ls -laF
              add that output to the place u saved
              make a new sd card, boot, install MagicMirror
              copy back config and css
              reinstall the modules
              • kusselinK
                kusselin @sdetweil
                Thank you…that’s funny…I don’t have any SD in use. I have installed the MM in a Proxmox container…ok then I know that something is wrong and I have to create a new container…config and costum.css I save and modules too…
                Thank you again
                • kusselinK
                  kusselin
                  Hello everyone,
                  hello stedweil,
                  an update…I have reinstalled the MM and I have said that I have it running in a Proxmox container (LXC)…that also worked via this page:
                  https://tteck.github.io/Proxmox/#miscellaneous
                  the installation worked perfectly…then I adjusted the config one after the other…
                  all modules work, regardless of whether they are MMM-Fuel, MMM-Clock or Calender…only not the MMM-ioBroker…my temperature and humidity data records are still not displayed
                  @stedweil: Let’s please go through again step by step what I can do to possibly narrow down the error. I bought the Aquara parts especially to display this via MM and it actually worked until recently.
                  Thank you in advance
                  		module: 'MMM-ioBroker',
                  		position: 'top_left',
                  		  host: '192.168.200.38',
                  		  port: '8082',
                  		  https: false,
                  		  devices: [
                            { name: 'EG-Ankleide',
                              deviceStates: [
                                                { id: 'zigbee.0.00158d0002fb4915.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                                { id: 'zigbee.0.00158d0002fb4915.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                  		  { name: 'EG-Büro',
                              deviceStates: [
                                                { id: 'zigbee.0.00158d0006d571bb.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                                { id: 'zigbee.0.00158d0006d571bb.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                  		  { name: 'EG-Bad',
                              deviceStates: [
                                                { id: 'zigbee.0.00158d0006e3ee77.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                                { id: 'zigbee.0.00158d0006e3ee77.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                  		  { name: 'EG-Wohnzimmer',
                              deviceStates: [
                                                { id: 'hm-rpc.0.NEQ1522239.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                                { id: 'hm-rpc.0.NEQ1522239.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                  		{ name: 'Dach-Speicher',
                              deviceStates: [
                                                { id: 'hm-rpc.0.KEQ0242488.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                                { id: 'hm-rpc.0.KEQ0242488.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                  			{ name: 'Treppenhaus',
                              deviceStates: [
                                                { id: 'hm-rpc.0.LEQ0592936.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                                { id: 'hm-rpc.0.LEQ0592936.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
                  			{ name: 'OG-Bad',
                              deviceStates: [
                                                { id: 'zigbee.0.00158d008b644f6f.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                { id: 'zigbee.0.00158d008b644f6f.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                  			{ name: 'OG-Wohnzimmer',
                              deviceStates: [
                                                { id: 'zigbee.0.00158d008b64556c.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                { id: 'zigbee.0.00158d008b64556c.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                  			{ name: 'OG-Rumpelzimmer',
                              deviceStates: [
                                                { id: 'zigbee.0.00158d008b644eff.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                { id: 'zigbee.0.00158d008b644eff.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                  			{ name: 'OG-Esszimmer',
                              deviceStates: [
                                                { id: 'zigbee.0.00158d008b6192cd.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                { id: 'zigbee.0.00158d008b6192cd.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                  			{ name: 'OG-Schlafzimmer',
                              deviceStates: [
                                                { id: 'zigbee.0.00158d008b69c067.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                { id: 'zigbee.0.00158d008b69c067.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                  			{ name: 'UG-Waschküche',
                              deviceStates: [
                                                { id: 'zigbee.0.00158d008b619293.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                                { id: 'zigbee.0.00158d008b619293.humidity',     icon: 'wi wi-humidity', suffix: '%' }
                  Thermo and humidy of the sleeping room OG:
                  and
                    sdetweil @kusselin
                    @kusselin
                    the id you listed for zigbee ids are different from what you have in the iobroker config
                    i dont know why they would change
                    • kusselinK
                      kusselin @sdetweil
                      hi…i can´t sie that there is a different ID
                      when you look in the config from MM config you see the ID for “OG-Schlafzimmer” an this is the same iD i posted "Sleeping room -OG.
                      and when the ID were wrong between MM and iobroker the name don´t displayed, but it´s o.k. and the name is display…
                      what else could it be?
                      I’m a bit annoyed because there must be more people who do this with Iobroker…and no one answers here :-(
                        sdetweil @kusselin
                        @kusselin sorry, I didn’t scroll down to see that you had multiple items listed…
                        is it only the OG room not displaying??
                        can you display the output of the npm start for the container
                        can you insure the container can ping the server
                        ‘192.168.200.38’
                        • kusselinK
                          kusselin @sdetweil
                           ping 192.168.200.38
                          Ping wird ausgeführt für 192.168.200.38 mit 32 Bytes Daten:
                          Antwort von 192.168.200.38: Bytes=32 Zeit<1ms TTL=64
                          Ping-Statistik für 192.168.200.38:
                              Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
                              (0% Verlust),
                          Ca. Zeitangaben in Millisek.:
                              Minimum = 0ms, Maximum = 0ms, Mittelwert = 0ms
                          MagicMirror LXC Container
                              🌐   Provided by: community-scripts ORG | GitHub: https://github.com/community-scripts/ProxmoxVE
                              🖥️   OS: Debian GNU/Linux - Version: 12
                              🏠   Hostname: magicmirror-live
                              💡   IP Address: 192.168.200.74
                          root@magicmirror-live:~# cd /magicmirror
                          -bash: cd: /magicmirror: No such file or directory
                          root@magicmirror-live:~# cd /opt
                          root@magicmirror-live:/opt# cd magicmirror
                          root@magicmirror-live:/opt/magicmirror# npm start
                          > magicmirror@2.31.0 start
                          > npm run start:x11
                          > magicmirror@2.31.0 start:x11
                          /opt/magicmirror/node_modules/electron/dist/electron: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory
                            sdetweil @kusselin
                            @kusselin said in MMM-ioBroker - it will not show:
                            libnss3.so
                            yeh, gotta load that in the container
                            • kusselinK
                              kusselin @sdetweil
                              Hi sdetweil, ha the MM is installed in a Proxmox LXC Container with Ubuntu 24.xx via the Proxmox Helpers scripts. But I already mentioned that above…MM is not installed on a PI…
                              What does the message say?
                              Have you discovered the error?
                              But it worked all the time in the container.
                              How do you load it into the container?
                              Thank you
                                sdetweil @kusselin
                                I don’t know anything about proxmox containers…
                                if on docker and you want the web UI to work, you have to install that library
                                (sudo apt… in the dockerfile)
                                I don’t know how you do that on proxmox container…
                                • kusselinK
                                  kusselin @sdetweil
                                  Do you mean then sudo apt install libnss3.so ?
                                  root@magicmirror-live:/opt/magicmirror# apt install libnss3.so
                                  Reading package lists... Done
                                  Building dependency tree... Done
                                  E: Unable to locate package libnss3.so
                                  E: Couldn't find any package by glob 'libnss3.so'
                                    sdetweil @kusselin
                                    @kusselin see
                                    https://github.com/claabs/epicgames-freegames-node/issues/359
                                    • kusselinK
                                      kusselin @sdetweil
                                      Hello, thank you. I have installed the dependency in github to your link and made a reboot…unfortunately the temp and humidity is still not displayed :-(
                                      look i have now done “npm start” again…now this message comes up:
                                      root@magicmirror-test:/opt/magicmirror# npm start
                                      > npm run start:x11
                                      /opt/magicmirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
                                      it’s just strange…I’ve never had these messages before…I’ve reinstalled the MM several times…but I’ve never had these messages…
                                      As the developer of MM, could you explain to me what this message means?
                                      thanks a lot Sam
                                        sdetweil @kusselin
                                        @kusselin a program is made up of lots of functions to call services of all kinds. electron is a browser program, they all want to draw graphics on the screen. everything is graphics
                                        how they do that depends on a lot of system functions
                                        each release of the program needs system services and these may change
                                        gtk is the graphical toolkit
                                        now you need to load that library too
                                        we just use electron, we dont know what its dependencies are, but this why we say you need full os instead of lite
                                        • kusselinK
                                          kusselin @sdetweil
                                          what i just don’t understand is… i have installed the MM in the LXC several times and never received these messages…why now?
                                          I have to create a new user with ‘adduser’ and then what do I have to do Sam?
