    V2.31.0 unable to start
    29 Posts 3 Posters 8.2k Views 3 Watching
    • htilburgsH Offline
      htilburgs
      After upgrade to v2.31.0 MM will not start.
      PM2 doesn’t show errors, but with NPM START I become this error:
      [2025-04-10 19:35:00.301] [LOG]   Sockets connected & modules started ...
      Invalid MIT-MAGIC-COOKIE-1 key
      [873086:0410/193500.307514:ERROR:ozone_platform_x11.cc(245)] Missing X server or $DISPLAY
      [873086:0410/193500.308038:ERROR:env.cc(258)] The platform failed to initialize.  Exiting.
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      I did a new install of MM, same error.
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        sdetweil @htilburgs
        @htilburgs how did you upgrade or install
        htilburgsH 1 Reply Last reply Reply Quote 0
          htilburgs @sdetweil
          @sdetweil with the script from you
            sdetweil @htilburgs
            @htilburgs hm
            try
            npm run start:wayland
              htilburgs @sdetweil
              @sdetweil Same error:
              [875833:0410/200935.088653:ERROR:wayland_connection.cc(198)] Failed to connect to Wayland display: No such file or directory (2)
              [875833:0410/200935.088864:ERROR:ozone_platform_wayland.cc(264)] Failed to initialize Wayland platform
              [875833:0410/200935.088893:ERROR:env.cc(258)] The platform failed to initialize.  Exiting.
                sdetweil @htilburgs
                @htilburgs weird,
                show
                lsb_release -a
                  htilburgs @sdetweil
                  No LSB modules are available.
                  Distributor ID: Debian
                  Description:    Debian GNU/Linux 12 (bookworm)
                  Release:        12
                  Codename:       bookworm
                    sdetweil @htilburgs
                    @htilburgs ok, when did you build the sd card?
                    can you show
                    ps -ef | grep way
                    ps -ef | grep labwc
                      htilburgs @sdetweil
                      @sdetweil said in V2.31.0 unable to start:
                      ps -ef | grep way
                      ps -ef | grep labwc
                      pi@mm:~/MagicMirror $ ps -ef | grep way
                      vnc          739       1  0 Apr09 ?        00:00:00 /bin/sh /usr/sbin/wayvnc-run.sh
                      vnc          759     739  0 Apr09 ?        00:00:00 wayvnc --render-cursor --detached --gpu --config /etc/wayvnc/config --socket /tmp/wayvnc/wayvncctl.sock
                      root        1605       1  0 Apr09 ?        00:02:02 python /usr/sbin/wayvnc-control.py
                      lightdm   801759  801726  0 19:20 ?        00:00:02 /usr/bin/rpi-connectd -socket /run/user/106/rpi-connect-wayvnc.sock
                      lightdm   801764  801648  0 19:20 ?        00:00:00 /usr/bin/wayfire -c /usr/share/greeter.ini
                      pi        810604     974  0 19:24 ?        00:00:02 /usr/bin/rpi-connectd -socket /run/user/1000/rpi-connect-wayvnc.sock
                      lightdm   870748       1  0 19:32 ?        00:00:00 /usr/bin/Xwayland -auth /home/lightdm/.Xauthority :0 -rootless -core -terminate 10 -listenfd 30 -listenfd 31 -displayfd 59 -wm 56
                      pi        878864  735951  0 21:00 pts/0    00:00:00 grep --color=auto way
                      pi@mm:~/MagicMirror $ ps -ef | grep labwc
                      pi        878897  735951  0 21:00 pts/0    00:00:00 grep --color=auto labwc
                        sdetweil @htilburgs
                        @htilburgs hm. so start:wayland should have worked
                          htilburgs @sdetweil
                          I did the update, it didn’t work afterwards.
                          Then I’ve tried sudo apt-get update / upgrade, still no luck
                          Today I renamed MagicMirror to .org and did a new install of MagicMirror, same result.
                          So now I’m out of options…
                            sdetweil @htilburgs
                            @htilburgs hmm
                            ok. try this
                            rm -rf ~/.config/Electron
                            note the . (dot) in front of of config
                            restart MagicMirror
                              htilburgs @sdetweil
                              Same error😔
                              npm run start
                                htilburgs @htilburgs
                                I think I take a new SD Card and do an install from scratch to see what happens.
                                htilburgsH 1 Reply Last reply Reply Quote 1
                                  @htilburgs
                                  I took a new SD Card and installed everything from fresh.
                                  Some information:
                                  cat /sys/firmware/devicetree/base/model
                                  Raspberry Pi 4 Model B Rev 1.4
                                  cat /etc/debian_version
                                  12.10
                                  cat /etc/os-release
                                  PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
                                  NAME="Debian GNU/Linux"
                                  VERSION_ID="12"
                                  VERSION="12 (bookworm)"
                                  VERSION_CODENAME=bookworm
                                  ID=debian
                                  HOME_URL="https://www.debian.org/"
                                  SUPPORT_URL="https://www.debian.org/support"
                                  BUG_REPORT_URL="https://bugs.debian.org/"
                                  uname -a
                                  Linux MagicMirror 6.12.20+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.20-1+rpt1~bpo12+1 (2025-03-19) aarch64 GNU/Linux
                                  node -v
                                  v22.14.0
                                  npm -v
                                  10.9.2
                                  When I start MagicMirror with “npm run start”, then everything seems to work.
                                  pm2 start MagicMirror works and seems to start MagicMirror in Wayland
                                  npm run start:wayland still gives an error
                                  pi@MagicMirror:~/MagicMirror $ npm run start:wayland
                                  > magicmirror@2.31.0 start:wayland
                                  > WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --enable-features=UseOzonePlatform --ozone-platform=wayland
                                  [2025-04-15 21:25:47.140] [LOG]   Starting MagicMirror: v2.31.0
                                  [2025-04-15 21:25:47.175] [LOG]   Loading config ...
                                  [2025-04-15 21:25:47.179] [LOG]   config template file not exists, no envsubst
                                  [2025-04-15 21:25:47.752] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
                                  [2025-04-15 21:25:47.874] [INFO]  Your configuration file doesn't contain syntax errors :)
                                  [2025-04-15 21:25:47.876] [INFO]  Checking modules structure configuration ...
                                  [2025-04-15 21:25:47.988] [INFO]  Your modules structure configuration doesn't contain errors :)
                                  [2025-04-15 21:25:47.991] [LOG]   Loading module helpers ...
                                  [2025-04-15 21:25:47.992] [LOG]   No helper found for module: alert.
                                  [2025-04-15 21:25:48.002] [LOG]   Initializing new module helper ...
                                  [2025-04-15 21:25:48.004] [LOG]   Module helper loaded: updatenotification
                                  [2025-04-15 21:25:48.004] [LOG]   No helper found for module: clock.
                                  [2025-04-15 21:25:48.005] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
                                  [2025-04-15 21:25:48.005] [LOG]   No helper found for module: weather.
                                  [2025-04-15 21:25:48.061] [LOG]   Initializing new module helper ...
                                  [2025-04-15 21:25:48.061] [LOG]   Module helper loaded: MMM-Formula1
                                  [2025-04-15 21:25:48.099] [LOG]   Initializing new module helper ...
                                  [2025-04-15 21:25:48.100] [LOG]   Module helper loaded: MMM-MyGarbage
                                  [2025-04-15 21:25:48.225] [LOG]   Initializing new module helper ...
                                  [2025-04-15 21:25:48.225] [LOG]   Module helper loaded: calendar
                                  [2025-04-15 21:25:48.270] [LOG]   Initializing new module helper ...
                                  [2025-04-15 21:25:48.271] [LOG]   Module helper loaded: MMM-OnSpotify
                                  [2025-04-15 21:25:48.298] [LOG]   Initializing new module helper ...
                                  [2025-04-15 21:25:48.298] [LOG]   Module helper loaded: MMM-Bring
                                  [2025-04-15 21:25:48.487] [LOG]   Initializing new module helper ...
                                  [2025-04-15 21:25:48.487] [LOG]   Module helper loaded: MMM-Tado
                                  [2025-04-15 21:25:48.489] [LOG]   Initializing new module helper ...
                                  [2025-04-15 21:25:48.489] [LOG]   Module helper loaded: MMM-MyHomeWizard
                                  [2025-04-15 21:25:48.491] [LOG]   Initializing new module helper ...
                                  [2025-04-15 21:25:48.492] [LOG]   Module helper loaded: MMM-SystemMonitor
                                  [2025-04-15 21:25:48.523] [LOG]   Initializing new module helper ...
                                  [2025-04-15 21:25:48.523] [LOG]   Module helper loaded: MMM-network-signal
                                  [2025-04-15 21:25:48.525] [LOG]   Initializing new module helper ...
                                  [2025-04-15 21:25:48.526] [LOG]   Module helper loaded: MMM-Universal-Pir
                                  [2025-04-15 21:25:48.526] [LOG]   All module helpers loaded.
                                  [2025-04-15 21:25:48.536] [LOG]   Starting server on port 8080 ...
                                  [2025-04-15 21:25:49.396] [LOG]   Server started ...
                                  [2025-04-15 21:25:49.401] [LOG]   Connecting socket for: updatenotification
                                  [2025-04-15 21:25:49.407] [LOG]   Starting module helper: updatenotification
                                  [2025-04-15 21:25:49.409] [LOG]   Connecting socket for: MMM-Formula1
                                  [2025-04-15 21:25:49.414] [LOG]   Starting module: MMM-Formula1
                                  [2025-04-15 21:25:49.418] [LOG]   Connecting socket for: MMM-MyGarbage
                                  [2025-04-15 21:25:49.419] [LOG]   Starting node_helper for module: MMM-MyGarbage
                                  [2025-04-15 21:25:49.420] [LOG]   Connecting socket for: calendar
                                  [2025-04-15 21:25:49.422] [LOG]   Starting node helper for: calendar
                                  [2025-04-15 21:25:49.424] [LOG]   Connecting socket for: MMM-OnSpotify
                                  [2025-04-15 21:25:49.427] [LOG]   [MMM-OnSpotify] by Fabrizz >> Node helper loaded.
                                  [2025-04-15 21:25:49.428] [LOG]   Connecting socket for: MMM-Bring
                                  [2025-04-15 21:25:49.430] [LOG]   Connecting socket for: MMM-Tado
                                  [2025-04-15 21:25:49.438] [LOG]       - MMM-Tado: Refresh token loaded.
                                  [2025-04-15 21:25:49.440] [LOG]   Connecting socket for: MMM-MyHomeWizard
                                  [2025-04-15 21:25:49.443] [LOG]   Starting node_helper for: MMM-MyHomeWizard
                                  [2025-04-15 21:25:49.444] [LOG]   Connecting socket for: MMM-SystemMonitor
                                  [2025-04-15 21:25:49.446] [LOG]   Starting module helper: MMM-SystemMonitor
                                  [2025-04-15 21:25:49.450] [LOG]   Connecting socket for: MMM-network-signal
                                  [2025-04-15 21:25:49.452] [LOG]   MMM-network-signal helper started ...
                                  [2025-04-15 21:25:49.454] [LOG]   Connecting socket for: MMM-Universal-Pir
                                  [2025-04-15 21:25:49.457] [LOG]   Sockets connected & modules started ...
                                  [2025-04-15 21:25:50.513] [LOG]   Launching application.
                                  [2025-04-15 21:25:51.278] [INFO]  System information:
                                  ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.4; virtual: false
                                  ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-v8
                                  ### VERSIONS: electron: 35.1.5; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
                                  ### OTHER:    timeZone: Europe/Amsterdam; ELECTRON_ENABLE_GPU: undefined
                                  /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
                                  I was just wondering, couldn’t it have something to do with the WAYLAND_DISPLAY parameter?
                                    sdetweil @htilburgs
                                    @htilburgs could be
                                    when you open a terminal session and do
                                    env
                                    is the WAYLAND_DISPLAY variable set?
                                    that code you referenced says use WAYLAND_DISPLAY, and if not set, set it to wayland-1
                                      htilburgs @sdetweil
                                      @sdetweil It seems it’s not set
                                      pi@MagicMirror:~ $ env
                                      SHELL=/bin/bash
                                      NO_AT_BRIDGE=1
                                      PWD=/home/pi
                                      LOGNAME=pi
                                      XDG_SESSION_TYPE=tty
                                      MOTD_SHOWN=pam
                                      HOME=/home/pi
                                      LANG=en_GB.UTF-8
                                      LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=00:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.avif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:*~=00;90:*#=00;90:*.bak=00;90:*.old=00;90:*.orig=00;90:*.part=00;90:*.rej=00;90:*.swp=00;90:*.tmp=00;90:*.dpkg-dist=00;90:*.dpkg-old=00;90:*.ucf-dist=00;90:*.ucf-new=00;90:*.ucf-old=00;90:*.rpmnew=00;90:*.rpmorig=00;90:*.rpmsave=00;90:
                                      SSH_CONNECTION=192.168.0.200 57994 192.168.0.47 22
                                      XDG_SESSION_CLASS=user
                                      TERM=xterm-256color
                                      USER=pi
                                      SHLVL=1
                                      XDG_SESSION_ID=4
                                      XDG_RUNTIME_DIR=/run/user/1000
                                      SSH_CLIENT=192.168.0.200 57994 22
                                      PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                      DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
                                      SSH_TTY=/dev/pts/0
                                      OLDPWD=/home/pi/.config
                                      TEXTDOMAIN=Linux-PAM
                                      _=/usr/bin/env
                                      pi@MagicMirror:~ $
                                      How do I set this?
                                        sdetweil @htilburgs
                                        @htilburgs in terminal window no spaces between things…
                                        this is like the windows set var=value (without the set prefix)
                                        WAYLAND_DISPLAY=wayland-x
                                        x is a number from 0 to …
                                        we thought wayand-1 was default
                                          htilburgs @sdetweil
                                          In terminal window I typed WAYLAND_DISPLAY=wayland-1
                                          Then I did “env”, nothing changed.
                                          npm run start:wayland still gives the same error.
                                            sdetweil @htilburgs
                                            @htilburgs said in V2.31.0 unable to start:
                                            you should have seen this in the env output
                                            but our code says IF NOT SET, use wayland-1
                                            which looks like an error
                                            so if you set it to the same value it won’t improve
                                            I’d try wayland-0
                                            maybe the wlr_randr command will tell you what it is?
