    • MagicMirrorΒ² Repository
    Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream
    68 Posts 5 Posters 16.2k Views 4 Watching
      sdetweil @rkorell
      @rkorell do curl -v
        rkorell @sdetweil
        curl --v --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
        curl: option --v: is ambiguous
        curl: try 'curl --help' or 'curl --manual' for more information
          sdetweil @rkorell
          @rkorell not double dash
          just trying to figure out what the problem is
          maybe curl version
          R 3 Replies Last reply Reply Quote 0
            rkorell @sdetweil
            @sdetweil OK
            this is curl --version :-) (just successfully trial&errored)
            curl --version
            curl 7.88.1 (aarch64-unknown-linux-gnu) libcurl/7.88.1 OpenSSL/3.0.15 zlib/1.2.13 brotli/1.0.9 zstd/1.5.4 libidn2/2.3.3 libpsl/0.21.2 (+libidn2/2.3.3) libssh2/1.10.0 nghttp2/1.52.0 librtmp/2.3 OpenLDAP/2.5.13
            Release-Date: 2023-02-20, security patched: 7.88.1-10+deb12u12
            Protocols: dict file ftp ftps gopher gophers http https imap imaps ldap ldaps mqtt pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
            Features: alt-svc AsynchDNS brotli GSS-API HSTS HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL threadsafe TLS-SRP UnixSockets zstd
              rkorell @sdetweil
              @sdetweil because it doesn’t work on windows either this is most likely not a version but a command or URL thing …
                rkorell @sdetweil
                @sdetweil said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
                Dear Sam,
                I caught it …
                The Windows command is not working for other reasons - doesn’t matter…
                The curl on MY Pi doesn’t work because - for some strange reason the resolving of β€œlocalhost” doesn’t work ???
                Figured this out by using another linux client (Macbook) and therefor using IP address of pi remotely - which worked instantly.
                And trying this locally on Pi with IP adreees does the job as well.
                Thanks again for your help!
                Regards,
                Ralf
                  sdetweil @rkorell
                  @rkorell weird, it works on windows for me
                  i just copy/pasted from the repo and
                  changed the address and port at the end
                  i can do it on the same machine or across the network to other machines
                    sdetweil @rkorell
                    @rkorell localhost is(always) mapped to 127.0.0.1 on the same system
                    which is called the loopback adapter, cause the packets never leave the system
                    ping localhost
                    should work
                      rkorell @sdetweil
                      Yes. I’m aware of this, thanks.
                      ping localhost
                      should work
                      Yes, do work:
                      pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ ping localhost
                      PING localhost(localhost (::1)) 56 data bytes
                      64 bytes from localhost (::1): icmp_seq=1 ttl=64 time=0.027 ms
                      64 bytes from localhost (::1): icmp_seq=2 ttl=64 time=0.035 ms
                      64 bytes from localhost (::1): icmp_seq=3 ttl=64 time=0.035 ms
                      64 bytes from localhost (::1): icmp_seq=4 ttl=64 time=0.036 ms
                      64 bytes from localhost (::1): icmp_seq=5 ttl=64 time=0.031 ms
                      64 bytes from localhost (::1): icmp_seq=6 ttl=64 time=0.039 ms
                      ^Z
                      [1]+  Stopped                 ping localhost
                      thanks anyway,
                      Regards,
                      Ralf
                        sdetweil @rkorell
                        @rkorell so, its a curl problem… weird…
                        but its using ipv6 (::1 is the ipv6 version of 127.0.0.1)
                        • 6
                        • 7
                        • 6 / 7
