    Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream
    68 Posts 5 Posters 25.1k Views 4 Watching
    • R
      @sdetweil said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
      so i wrote MMM-CurlToNotification
      Dear Sam,
      trying to help I’m struggled with your module CurlToNotification :-(
        module:"MMM-CurlToNotification",
        config:{
          url_name:"doorbell", // the path of the url for curl post
      And consecutively running
      curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
      Shows an error message:
      pi@MagicMirrorPi5:~/MagicMirror/modules $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
      <!DOCTYPE html>
      <html lang="en">
      <head>
      <meta charset="utf-8">
      <title>Error</title>
      </head>
      <body>
      <pre>InternalServerError: stream is not readable<br> &nbsp; &nbsp;at readStream (/home/pi/MagicMirror/node_modules/raw-body/index.js:185:17)<br> &nbsp; &nbsp;at getRawBody (/home/pi/MagicMirror/node_modules/raw-body/index.js:116:12)<br> &nbsp; &nbsp;at read (/home/pi/MagicMirror/node_modules/body-parser/lib/read.js:79:3)<br> &nbsp; &nbsp;at jsonParser (/home/pi/MagicMirror/node_modules/body-parser/lib/types/json.js:138:5)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:95:5)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:91:12)<br> &nbsp; &nbsp;at trim_prefix (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:328:13)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:286:9<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:346:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:280:10)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/body-parser/lib/read.js:132:5<br> &nbsp; &nbsp;at AsyncResource.runInAsyncScope (node:async_hooks:206:9)<br> &nbsp; &nbsp;at invokeCallback (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:238:16)<br> &nbsp; &nbsp;at done (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:227:7)<br> &nbsp; &nbsp;at IncomingMessage.onEnd (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/raw-body/index.js:287:7)<br> &nbsp; &nbsp;at IncomingMessage.emit (node:events:518:28)<br> &nbsp; &nbsp;at endReadableNT (node:internal/streams/readable:1698:12)<br> &nbsp; &nbsp;at process.processTicksAndRejections (node:internal/process/task_queues:82:21)</pre>
      </body>
      </html>
      From Windows Client (changing localhost to MagicMirrors IP address a different error message:
      PS C:\Users\Familienbenutzer> curl --header "Content-Type: application/json"   --request POST   --data "{\"notification\":\"SHOW_ALERT\",\"payload\":{\"message\":\"fribble\"}}" http://1xx.yy.zz.157:8080/doorbell
      Invoke-WebRequest : Es wurde kein Positionsparameter gefunden, der das Argument "Content-Type: application/json"
      akzeptiert.
      In Zeile:1 Zeichen:1
      + curl --header "Content-Type: application/json"   --request POST   --d ...
          + CategoryInfo          : InvalidArgument: (:) [Invoke-WebRequest], ParameterBindingException
          + FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
      Any hint for me?
      Thanks and regards,
      Ralf
        sdetweil @rkorell
        @rkorell and you did restart MagicMirror after installing the module, right?
        you can also add config parm (make sure there is a trailing comma after doorbell
           debug:true,
        R 1 Reply Last reply
        • R
          yes, indeed :-)
          And a trailing comma is there…
          In the meantime I had even a PI-reboot (for other reasons) - error persists.
          Even with debug-option enabled no debug message from your module.
          Neither in pm2 logs nor in developer’s console…
          Ralf
          S R 3 Replies Last reply
            sdetweil @rkorell
            @rkorell weird
            i am away from my computer for most of the day helping family
            i will review asap
            • R
              @sdetweil Take your time!
              Family is most important.
              This issue is REALLY not important, neither urgent.
              I do not need this module right now - was just for testing, if I can help @Cr4z33 further with some examples to copy - as asked.
              So don’t hurry.
              Ralf
              Reply Quote 1
              • R
                rkorell Module Developer @rkorell
                @rkorell said in Need help with MMM-MQTTbridge not "communicating" with MMM-RTSPStream:
                all messages in dev-console …
                • R
                  startup log
                  0|MagicMir | > magicmirror@2.31.0-develop start
                  0|MagicMir | > npm run start:x11
                  0|MagicMir |
                  0|MagicMir |
                  0|MagicMir | > magicmirror@2.31.0-develop start:x11
                  0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                  0|MagicMir |
                  0|MagicMir | [2025-05-03 17:06:27.179] [LOG]   Starting MagicMirror: v2.31.0-develop
                  0|MagicMir | [2025-05-03 17:06:27.189] [LOG]   Loading config ...
                  0|MagicMir | [2025-05-03 17:06:27.190] [LOG]   config template file not exists, no envsubst
                  0|MagicMir | [2025-05-03 17:06:27.369] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
                  0|MagicMir | [2025-05-03 17:06:27.436] [INFO]  Your configuration file doesn't contain syntax errors :)
                  0|MagicMir | [2025-05-03 17:06:27.437] [INFO]  Checking modules structure configuration ...
                  0|MagicMir | [2025-05-03 17:06:27.473] [INFO]  Your modules structure configuration doesn't contain errors :)
                  0|MagicMir | [2025-05-03 17:06:27.474] [LOG]   Loading module helpers ...
                  0|MagicMir | [2025-05-03 17:06:27.474] [LOG]   No helper found for module: alert.
                  0|MagicMir | [2025-05-03 17:06:27.475] [LOG]   No helper found for module: MMM-MagicMover.
                  0|MagicMir | [2025-05-03 17:06:27.476] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   Module helper loaded: MMM-CurlToNotification
                  0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   No helper found for module: clock.
                  0|MagicMir | [2025-05-03 17:06:27.477] [LOG]   No helper found for module: MMM-Profilepicture.
                  0|MagicMir | [2025-05-03 17:06:27.484] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.484] [LOG]   Module helper loaded: MMM-Logging
                  0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   Module helper loaded: MMM-MoonPhase
                  0|MagicMir | [2025-05-03 17:06:27.491] [LOG]   No helper found for module: MMM-Globe.
                  0|MagicMir | [2025-05-03 17:06:27.492] [LOG]   No helper found for module: weather.
                  0|MagicMir | [2025-05-03 17:06:27.523] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.524] [LOG]   Module helper loaded: MMM-JsonValue
                  0|MagicMir | [2025-05-03 17:06:27.531] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.531] [LOG]   Module helper loaded: MMM-MyGarbage
                  0|MagicMir | [2025-05-03 17:06:27.532] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
                  0|MagicMir | [2025-05-03 17:06:27.532] [LOG]   No helper found for module: MMM-RAIN-MAP.
                  0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Check MagicMirror² version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version: 2.31.0-develop
                  0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Version is ok!
                  0|MagicMir | [2025-05-03 17:06:27.641] [LOG]   Module helper loaded: MMM-Strava
                  0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   Module helper loaded: MMM-Todoist
                  0|MagicMir | [2025-05-03 17:06:27.718] [LOG]   No helper found for module: MMM-UselessFacts.
                  0|MagicMir | [2025-05-03 17:06:27.748] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.748] [LOG]   Module helper loaded: MMM-FRITZ-Box-Callmonitor-py3
                  0|MagicMir | [2025-05-03 17:06:27.749] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.749] [LOG]   Module helper loaded: MMM-SystemMonitor
                  0|MagicMir | [2025-05-03 17:06:27.750] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.750] [LOG]   Module helper loaded: MMM-SystemInfo
                  0|MagicMir | [2025-05-03 17:06:27.782] [LOG]   2025-05-03T17:06:27 <log> init module helper birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:15 Class.init)
                  0|MagicMir | [2025-05-03 17:06:27.782] [LOG]   Module helper loaded: birthdaylist
                  0|MagicMir | [2025-05-03 17:06:27.898] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.899] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
                  0|MagicMir | [2025-05-03 17:06:27.925] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.925] [LOG]   Module helper loaded: newsfeed
                  0|MagicMir | [2025-05-03 17:06:27.945] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.945] [LOG]   Module helper loaded: MMM-Remote-Control
                  0|MagicMir | [2025-05-03 17:06:27.982] [LOG]   Initializing new module helper ...
                  0|MagicMir | [2025-05-03 17:06:27.983] [LOG]   Module helper loaded: calendar
                  0|MagicMir | [2025-05-03 17:06:27.983] [LOG]   All module helpers loaded.
                  0|MagicMir | [2025-05-03 17:06:27.986] [LOG]   Starting server on port 8080 ...
                  0|MagicMir | [2025-05-03 17:06:28.296] [LOG]   Server started ...
                  0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Connecting socket for: MMM-CurlToNotification
                  0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Starting module helper: MMM-CurlToNotification
                  0|MagicMir | [2025-05-03 17:06:28.297] [LOG]   Connecting socket for: MMM-Logging
                  0|MagicMir | [2025-05-03 17:06:28.298] [LOG]   2025-05-03T17:06:28 <log> Module helper started for MMM-Logging (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:19 Class.start)
                  0|MagicMir | [2025-05-03 17:06:28.298] [LOG]   Connecting socket for: MMM-MoonPhase
                  0|MagicMir | [2025-05-03 17:06:28.304] [LOG]   Starting module helper: MMM-MoonPhase
                  0|MagicMir | [2025-05-03 17:06:28.304] [LOG]   Connecting socket for: MMM-JsonValue
                  0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   Connecting socket for: MMM-MyGarbage
                  0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   2025-05-03T17:06:28 <log> Starting node_helper for module: MMM-MyGarbage (/home/pi/MagicMirror/modules/MMM-MyGarbage/node_helper.js:9 Class.start)
                  0|MagicMir | [2025-05-03 17:06:28.305] [LOG]   Connecting socket for: MMM-Strava
                  0|MagicMir | [2025-05-03 17:06:28.306] [LOG]   2025-05-03T17:06:28 <log> Starting module helper: MMM-Strava (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:47 Class.start)
                  0|MagicMir | [2025-05-03 17:06:28.306] [LOG]   Connecting socket for: MMM-Todoist
                  0|MagicMir | [2025-05-03 17:06:28.307] [LOG]   2025-05-03T17:06:28 <log> Starting node helper for: MMM-Todoist (/home/pi/MagicMirror/modules/MMM-Todoist/node_helper.js:19 Class.start)
                  0|MagicMir | [2025-05-03 17:06:28.307] [LOG]   Connecting socket for: MMM-FRITZ-Box-Callmonitor-py3
                  0|MagicMir | [2025-05-03 17:06:28.312] [LOG]   2025-05-03T17:06:28 <log> Starting module: MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:28 Class.start)
                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: MMM-SystemMonitor
                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Starting module helper: MMM-SystemMonitor
                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: MMM-SystemInfo
                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Starting node helper: MMM-SystemInfo
                  0|MagicMir | [2025-05-03 17:06:28.313] [LOG]   Connecting socket for: birthdaylist
                  0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
                  0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Connecting socket for: newsfeed
                  0|MagicMir | [2025-05-03 17:06:28.314] [LOG]   Starting node helper for: newsfeed
                  0|MagicMir | [2025-05-03 17:06:28.318] [LOG]   Connecting socket for: MMM-Remote-Control
                  0|MagicMir | [2025-05-03 17:06:28.319] [LOG]   Starting node helper for: MMM-Remote-Control
                  0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Connecting socket for: calendar
                  0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Starting node helper for: calendar
                  0|MagicMir | [2025-05-03 17:06:28.323] [LOG]   Sockets connected & modules started ...
                  0|MagicMir | [2025-05-03 17:06:28.540] [LOG]   Launching application.
                  0|MagicMir | [2025-05-03 17:06:28.915] [INFO]  System information:
                  0|MagicMir | ### SYSTEM:   manufacturer: ; model: ; virtual: false
                  0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-2712
                  0|MagicMir | ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                  0|MagicMir | ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                  0|MagicMir | [2025-05-03 17:06:29.613] [LOG]   [MMM-Remote-Control] Could not get defaults for MMM-RAIN-MAP. See #335.
                  0|MagicMir | [2025-05-03 17:06:31.249] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxxxxxxxxx%40group.calendar.google.com/private-5yyyyyyyyyyyyyyyyyyyyyy/basic.ics - Interval: 300000
                  0|MagicMir | [2025-05-03 17:06:31.278] [LOG]   2025-05-03T17:06:31 <info> MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:31.279] [LOG]   2025-05-03T17:06:31 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:31.303] [LOG]   2025-05-03T17:06:31 <log> Received config for MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:56 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:31.304] [LOG]   2025-05-03T17:06:31 <log> MMM-FRITZ-Box-Callmonitor-py3 is waiting for incoming calls. (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:118 Class.setupMonitor)
                  0|MagicMir | [2025-05-03 17:06:31.376] [LOG]   Create new newsfetcher for url: https://www.gutekueche.de/feed/wochenrezepte - Interval: 300000
                  0|MagicMir | [2025-05-03 17:06:31.382] [LOG]   Create new newsfetcher for url: https://www.gutekueche.de/feed/tagesrezept - Interval: 300000
                  0|MagicMir | [2025-05-03 17:06:31.385] [LOG]   Create new newsfetcher for url: https://www.chefkoch.de/recipe-of-the-day/rss - Interval: 300000
                  0|MagicMir | [2025-05-03 17:06:31.389] [LOG]   Create new calendarfetcher for url: https://www.feiertage-deutschland.de/kalender-download/ics/feiertage-deutschland.ics - Interval: 604800000
                  0|MagicMir | [2025-05-03 17:06:31.394] [LOG]   2025-05-03T17:06:31 <log> Starting module helper:  birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:27 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:32.046] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:32.050] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:32.194] [LOG]   2025-05-03T17:06:32 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:32.353] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                  0|MagicMir | [2025-05-03 17:06:32.398] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                  0|MagicMir | [2025-05-03 17:06:32.495] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                  0|MagicMir | [2025-05-03 17:06:32.734] [INFO]  Calendar-Fetcher: Broadcasting 51 events from https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxgroup.calendar.google.com/private-yyyyyyyyyyyyyyyyyyyyyyyyyyyy/basic.ics.
                  0|MagicMir | [2025-05-03 17:06:32.827] [LOG]   2025-05-03T17:06:32 <log> Refreshed access token because it has expired. Expired at: 17:06:31 now is: 17:06:32 (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/core/SpotifyConnector.js:24 )
                  0|MagicMir | [2025-05-03 17:06:33.418] [LOG]   2025-05-03T17:06:33 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  0|MagicMir | [2025-05-03 17:06:34.302] [INFO]  Calendar-Fetcher: Broadcasting 22 events from https://www.feiertage-deutschland.de/kalender-download/ics/feiertage-deutschland.ics.
                    sdetweil @rkorell
                    @rkorell git pull in the module folder restart MM
                    in the npm start output, should see (I sent 3 requests)
                    [2025-05-03 18:30:03.519] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'HIDE_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
                    [2025-05-03 18:30:36.302] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'SHOW_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
                    [2025-05-03 18:31:00.765] [LOG]   MMM-CurlToNotificationreceived request to post notification  { notification: 'HIDE_ALERT', payload: { message: 'fribble' } }  with id=module_20_MMM-CurlToNotification
                    and in the dev console
                    MMM-CurlToNotification.js:14 MMM-CurlToNotification received request to send notication  HIDE_ALERT  with payload  {message: 'fribble'}
                    MMM-CurlToNotification.js:14 MMM-CurlToNotification received request to send notication  SHOW_ALERT  with payload  {message: 'fribble'}
                    R 2 Replies Last reply
                    • R
                      @sdetweil I`m away from home today, will check tomorrow…
                      Thanks.
                      Ralf
                      • R
                        As your posting above implies your debug message confirms a received message - but the message cannot be received, because the curl command doesn’t work …
                        As per your advise I’ve git pulled, restarted mirror - but get same error message as before.
                        The curl command is bad or the URL doesn’t work.
                        I don’t know why and have no idea how to figure this out…
                        Screen input- and output as follws:
                        pi@MagicMirrorPi5:~ $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                        <!DOCTYPE html>
                        <html lang="en">
                        <head>
                        </head>
                        <body>
                        </body>
                        </html>
                        pi@MagicMirrorPi5:~ $ cd MagicMirror/modules
                        pi@MagicMirrorPi5:~/MagicMirror/modules $ cd MMM-CurlToNotification/
                        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ git pull
                        Updating 71ea1c1..bd1e417
                        Fast-forward
                         MMM-CurlToNotification.js | 14 ++++++++++----
                         README.md                 |  1 +
                         node_helper.js            | 13 +++++++++++--
                         3 files changed, 22 insertions(+), 6 deletions(-)
                        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ pm2 restart MagicMirror
                        Use --update-env to update environment variables
                        [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                        [PM2] [MagicMirror](0) ✓
                        │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                        │ 0  │ MagicMirror    │ default     │ 2.31.0… │ fork    │ 87731    │ 0s     │ 1    │ online    │ 0%       │ 2.6mb    │ pi       │ enabled  │
                        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ curl --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                        <!DOCTYPE html>
                        <html lang="en">
                        <head>
                        </head>
                        <body>
                        </body>
                        </html>
                        Any additional idea?
                        regards,
                        Ralf
                          sdetweil @rkorell
                          @rkorell do curl -v
                          • R
                            curl --v --header "Content-Type: application/json"   --request POST   --data '{"notification":"SHOW_ALERT","payload":{"message":"fribble"}}' http://localhost:8080/doorbell
                            curl: option --v: is ambiguous
                            curl: try 'curl --help' or 'curl --manual' for more information
                              sdetweil @rkorell
                              @rkorell not double dash
                              just trying to figure out what the problem is
                              maybe curl version
                              • R
                                @sdetweil OK
                                this is curl --version :-) (just successfully trial&errored)
                                curl --version
                                curl 7.88.1 (aarch64-unknown-linux-gnu) libcurl/7.88.1 OpenSSL/3.0.15 zlib/1.2.13 brotli/1.0.9 zstd/1.5.4 libidn2/2.3.3 libpsl/0.21.2 (+libidn2/2.3.3) libssh2/1.10.0 nghttp2/1.52.0 librtmp/2.3 OpenLDAP/2.5.13
                                Release-Date: 2023-02-20, security patched: 7.88.1-10+deb12u12
                                Protocols: dict file ftp ftps gopher gophers http https imap imaps ldap ldaps mqtt pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
                                Features: alt-svc AsynchDNS brotli GSS-API HSTS HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL threadsafe TLS-SRP UnixSockets zstd
                                • R
                                  @sdetweil because it doesn’t work on windows either this is most likely not a version but a command or URL thing …
                                  • R
                                    Dear Sam,
                                    I caught it …
                                    The Windows command is not working for other reasons - doesn’t matter…
                                    The curl on MY Pi doesn’t work because - for some strange reason the resolving of “localhost” doesn’t work ???
                                    Figured this out by using another linux client (Macbook) and therefor using IP address of pi remotely - which worked instantly.
                                    And trying this locally on Pi with IP adreees does the job as well.
                                    Thanks again for your help!
                                    Regards,
                                    Ralf
                                      sdetweil @rkorell
                                      @rkorell weird, it works on windows for me
                                      i just copy/pasted from the repo and
                                      changed the address and port at the end
                                      i can do it on the same machine or across the network to other machines
                                        sdetweil @rkorell
                                        @rkorell localhost is(always) mapped to 127.0.0.1 on the same system
                                        which is called the loopback adapter, cause the packets never leave the system
                                        ping localhost
                                        should work
                                        • R
                                          Yes. I’m aware of this, thanks.
                                          ping localhost
                                          should work
                                          Yes, do work:
                                          pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CurlToNotification $ ping localhost
                                          PING localhost(localhost (::1)) 56 data bytes
                                          64 bytes from localhost (::1): icmp_seq=1 ttl=64 time=0.027 ms
                                          64 bytes from localhost (::1): icmp_seq=2 ttl=64 time=0.035 ms
                                          64 bytes from localhost (::1): icmp_seq=3 ttl=64 time=0.035 ms
                                          64 bytes from localhost (::1): icmp_seq=4 ttl=64 time=0.036 ms
                                          64 bytes from localhost (::1): icmp_seq=5 ttl=64 time=0.031 ms
                                          64 bytes from localhost (::1): icmp_seq=6 ttl=64 time=0.039 ms
                                          ^Z
                                          [1]+  Stopped                 ping localhost
                                          thanks anyway,
                                          Regards,
                                          Ralf
                                            sdetweil @rkorell
                                            @rkorell so, its a curl problem… weird…
                                            but its using ipv6 (::1 is the ipv6 version of 127.0.0.1)
                                            • 3 / 4
