    Netatmo module will not shown
    40 Posts 5 Posters 6.9k Views 5 Watching
      sdetweil @kusselin
      @kusselin SOOOO much fun!! i do not know. and cannot debug it here
      kusselinK 1 Reply Last reply Reply Quote 0
      • kusselinK Offline
        kusselin @sdetweil
        Ok, but it looks good now, doesn’t it?
        That means it’s the module again.
        Maybe someone here with Netatmo running will see this?
        Thanks and greetings
          sdetweil @kusselin
          @kusselin yes, dont see anything indicating the problem. all looks good
          • kusselinK Offline
            kusselin @sdetweil
            @sdetweil said in Netatmo module will not shown:
            module: “netatmo”,
            position: “bottom_left”,
            order: “*”,
            animateIn: “None”,
            animateOut: “None”,
            clientId: ‘1234567’, // your app id
            clientSecret: ‘1212123’, // your app secret
            refresh_token: ‘3223232’, // your generated refresh token
            mockData: true
            disabled: false,
            hiddenOnStartup: false,
            configDeepMerge: false
            I have now copied your config from here into the config again and it no longer works… can you please try it again with the mockData: true and take a picture
            thanks
              sdetweil @kusselin
              @kusselin will do, it took a few minutes , i had given up and came back and it was displaying
              • kusselinK Offline
                kusselin @det
                @det said in Netatmo module will not shown:
                @kusselin
                Also check that your registration is correct. Make sure you have a current “token.js”.
                Hi, Where can i find the token.js?
                  sdetweil @kusselin
                  @kusselin this version doesn’t use token.js
                  https://github.com/CFenner/MMM-Netatmo,
                  uses info in config.js for this module
                  • kusselinK Offline
                    kusselin
                    Hi sam, where can i adjust the intervall time in MM when i have the module „Carousel“?
                      sdetweil @kusselin
                      @kusselin in the mmm-carousel readme
                      https://github.com/shbatm/MMM-Carousel
                      transitionInterval
                      • kusselinK Offline
                        kusselin @sdetweil
                        @sdetweil thanks a lot sam…i found it self …best man sam :-)
                        • 4 / 4
