    Netatmo module will not shown
    40 Posts 5 Posters 11.6k Views 5 Watching
      sdetweil @kusselin
      @kusselin congratulations!!! i’m glad you got it working
      • kusselinK
        kusselin @Lusbueb
        @Lusbueb said in Netatmo module will not shown:
        @kusselin
        In your configuration, I’m missing the entry modulOrder. This entry was essential for me! I initially used the default name until I realized that it only works if the module name is stored exactly as you configured it in the web-app (https://auth.netatmo.com/de-de/access/login):
        my config:
        		module: 'netatmo',
        		position: 'middle_center', // the location where the module should be displayed
        			clientId: '*myID*', // your app id
        			clientSecret: '*mysecret*', // your app secret
        			refresh_token: *'mytoken*', // your generated refresh token
        			moduleOrder: ["Outdoor","Regen","Wind","Schlafzimmer","Wohnzimmer"], //take same names from web-app!
        			updateInterval: 6, // every 3 minutes, refresh interval on netatmo is 10 minutes
        			animationSpeed: 1000,
        			design: 'bubbles', // classic or bubbles
        			horizontal: false,
        			lastMessageThreshold: 600, // in seconds (10 minutes)
        			showLastMessage: true,
        			showBattery: true,
        			showRadio: true,
        			showWiFi: true,
        			showTrend: true,
        			showMeasurementIcon: true,
        			showMeasurementLabel: true,
        			showStationName: false,
        			showModuleNameOnTop: true,
        			fontClassModuleName: 'small', // xsmall, small, medium, large, xlarge
        			fontClassPrimary: 'large',
        			fontClassSecondary: 'xsmall',
        			fontClassMeasurement: 'xsmall',
        			thresholdCO2Average: 800,
        			thresholdCO2Bad: 1800,
        			mockData: false,
        https://home.netatmo.com/control/dashboard
        MM:
        Thanks s lot for your config…i changed it and now ist good and the netatmo Modul is running very well
        • kusselinK
          kusselin
          Hello everyone, netatmo is no longer working today :-(
          I haven’t changed anything
            sdetweil @kusselin
            @kusselin need to see the logs again
            always 1st place to look
            kusselinK 1 Reply Last reply Reply Quote 0
            • kusselinK
              kusselin @sdetweil
              Hi sam, look here again…
              verbose cli /usr/bin/node /usr/bin/npm
              1 info using npm@10.9.2
              2 info using node@v22.15.0
              3 silly config load:file:/usr/lib/node_modules/npm/npmrc
              4 silly config load:file:/opt/magicmirror/.npmrc
              5 silly config load:file:/root/.npmrc
              6 silly config load:file:/usr/etc/npmrc
              7 verbose title npm run seerver
              8 verbose argv "run" "seerver"
              9 verbose logfile logs-max:10 dir:/root/.npm/_logs/2025-05-03T14_24_21_403Z-
              10 verbose logfile /root/.npm/_logs/2025-05-03T14_24_21_403Z-debug-0.log
              11 silly logfile start cleaning logs, removing 1 files
              12 silly logfile done cleaning log files
              13 verbose stack Error: Missing script: "seerver"
              13 verbose stack
              13 verbose stack Did you mean this?
              13 verbose stack   npm run server # run the "server" package script
              13 verbose stack
              13 verbose stack To see a list of scripts, run:
              13 verbose stack     at #run (/usr/lib/node_modules/npm/lib/commands/run-script.js:111:13)
              13 verbose stack     at async RunScript.exec (/usr/lib/node_modules/npm/lib/commands/run-script.js:40:7)
              13 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
              13 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5)
              14 error Missing script: "seerver"
              14 error
              14 error Did you mean this?
              14 error   npm run server # run the "server" package script
              14 error
              14 error To see a list of scripts, run:
              14 error   npm run
              15 verbose cwd /opt/magicmirror
              16 verbose os Linux 6.8.12-8-pve
              17 verbose node v22.15.0
              18 verbose npm  v10.9.2
              19 verbose exit 1
              20 verbose code 1
              21 error A complete log of this run can be found in: /root/.npm/_logs/2025-05-03T14_24_21_403Z-debug-0.log
              and the latest Log:
              0 verbose cli /usr/bin/node /usr/bin/npm
              7 verbose title npm run server
              8 verbose argv "run" "server"
              9 verbose logfile logs-max:10 dir:/root/.npm/_logs/2025-05-03T14_24_50_844Z-
              10 verbose logfile /root/.npm/_logs/2025-05-03T14_24_50_844Z-debug-0.log
              13 verbose cwd /opt/magicmirror
              14 verbose os Linux 6.8.12-8-pve
              15 verbose node v22.15.0
              16 verbose npm  v10.9.2
              17 verbose exit 0
              18 info ok
              here is the info wenn i go into /opt/magicmirror/ and “npm run server”:
              The programs included with the Debian GNU/Linux system are free software;
              the exact distribution terms for each program are described in the
              individual files in /usr/share/doc/*/copyright.
              Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
              permitted by applicable law.
              Last login: Sat May  3 16:23:40 2025 from 192.168.200.219
              MagicMirror LXC Container
                  🌐   Provided by: community-scripts ORG | GitHub: https://github.com/community-scripts/ProxmoxVE
                  🖥️   OS: Debian GNU/Linux - Version: 12
                  🏠   Hostname: magicmirror-live
                  💡   IP Address: 192.168.200.74
              root@magicmirror-live:~# cd /opt/magicmirror
              root@magicmirror-live:/opt/magicmirror# npm run server
              > magicmirror@2.31.0 server
              > node ./serveronly
              [2025-05-03 16:40:49.450] [LOG]   Starting MagicMirror: v2.31.0
              [2025-05-03 16:40:49.469] [LOG]   Loading config ...
              [2025-05-03 16:40:49.470] [LOG]   config template file not exists, no envsubst
              [2025-05-03 16:40:49.876] [INFO]  Checking config file /opt/magicmirror/config/config.js ...
              [2025-05-03 16:40:49.930] [INFO]  Your configuration file doesn't contain syntax errors :)
              [2025-05-03 16:40:49.931] [INFO]  Checking modules structure configuration ...
              [2025-05-03 16:40:50.003] [INFO]  Your modules structure configuration doesn't contain errors :)
              [2025-05-03 16:40:50.519] [LOG]   Loading module helpers ...
              [2025-05-03 16:40:50.528] [LOG]   No helper found for module: alert.
              [2025-05-03 16:40:50.551] [LOG]   Initializing new module helper ...
              [2025-05-03 16:40:50.555] [LOG]   Module helper loaded: updatenotification
              [2025-05-03 16:40:50.557] [LOG]   No helper found for module: clock.
              [2025-05-03 16:40:50.934] [LOG]   Initializing new module helper ...
              [2025-05-03 16:40:50.936] [LOG]   Module helper loaded: calendar
              [2025-05-03 16:40:50.941] [LOG]   No helper found for module: compliments.
              [2025-05-03 16:40:50.943] [LOG]   No helper found for module: MMM-OpenmapWeather.
              [2025-05-03 16:40:50.950] [LOG]   Initializing new module helper ...
              [2025-05-03 16:40:50.952] [LOG]   Module helper loaded: netatmo
              [2025-05-03 16:40:50.954] [WARN]  No /opt/magicmirror/modules/MMM-OpenWeatherForecast/MMM-OpenWeatherForecast.js found for module: MMM-OpenWeatherForecast.
              [2025-05-03 16:40:50.955] [LOG]   No helper found for module: MMM-OpenWeatherForecast.
              [2025-05-03 16:40:50.955] [LOG]   No helper found for module: MMM-Blitzer.
              [2025-05-03 16:40:50.958] [LOG]   Initializing new module helper ...
              [2025-05-03 16:40:50.960] [LOG]   Module helper loaded: MMM-ApothekenNotdienst
              [2025-05-03 16:40:50.962] [LOG]   Initializing new module helper ...
              [2025-05-03 16:40:50.965] [LOG]   Module helper loaded: MMM-ioBroker
              [2025-05-03 16:40:50.965] [LOG]   No helper found for module: MMM-Carousel.
              [2025-05-03 16:40:51.040] [LOG]   Initializing new module helper ...
              [2025-05-03 16:40:51.040] [LOG]   Module helper loaded: MMM-PublicTransportHafas
              [2025-05-03 16:40:51.480] [LOG]   Initializing new module helper ...
              [2025-05-03 16:40:51.480] [LOG]   Module helper loaded: MMM-RNV
              [2025-05-03 16:40:51.482] [LOG]   Initializing new module helper ...
              [2025-05-03 16:40:51.482] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.31.0
              [2025-05-03 16:40:51.482] [LOG]   Version is ok!
              [2025-05-03 16:40:51.483] [LOG]   Module helper loaded: MMM-Fuel
              [2025-05-03 16:40:51.591] [LOG]   Initializing new module helper ...
              [2025-05-03 16:40:51.591] [LOG]   Module helper loaded: MMM-Remote-Control
              [2025-05-03 16:40:51.658] [LOG]   Initializing new module helper ...
              [2025-05-03 16:40:51.659] [LOG]   Module helper loaded: newsfeed
              [2025-05-03 16:40:51.659] [LOG]   All module helpers loaded.
              [2025-05-03 16:40:51.663] [LOG]   Starting server on port 8080 ...
              [2025-05-03 16:40:51.664] [WARN]  You're using a full whitelist configuration to allow for all IPs
              [2025-05-03 16:40:51.673] [ERROR] Whoops! There was an uncaught exception...
              [2025-05-03 16:40:51.673] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                  at Server.setupListenHandle [as _listen2] (node:net:1939:16)
                  at listenInCluster (node:net:1996:12)
                  at node:net:2205:7
                  at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
                code: 'EADDRINUSE',
                errno: -98,
                syscall: 'listen',
                address: '0.0.0.0',
                port: 8080
              [2025-05-03 16:40:51.673] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [2025-05-03 16:40:51.673] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
              [2025-05-03 16:40:51.783] [INFO]  System information:
              ### SYSTEM:   manufacturer: ; model: ; virtual: false
              ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: x64; kernel: 6.8.12-8-pve
              ### VERSIONS: electron: undefined; used node: 22.15.0; installed node: 22.15.0; npm: 10.9.2; pm2: 5.4.3
              ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
              her my Config from MM:
              /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                    module: 'netatmo',
                    position: 'bottom_left',
                      clientId: '123456,
                      clientSecret: '1234',
                      refresh_token: '1234',
                      moduleOrder: [
                        'Aussenmodul',
                        'Regenmesser',
                        'Windmesser',
                        'Wohnen'
                      updateInterval: 6,
                      design: 'bubbles',
                      horizontal: false,
              what I don’t understand either…because of the remote control module the config looks completely different than normal…but I think that has nothing to do with Netatmo…right?
              I would be really grateful for your help…
              Greetings
                sdetweil @kusselin
                @kusselin the ‘already in use’ is because the container is running MagicMirror as a system service
                you could use a different port for the test
                export MM_PORT=8090
                npm run server
                now you have two instances running
                one on 8080 and one on 8090
                ctrl-c to stop the one on 8090
                  sdetweil @kusselin
                  @kusselin config format, yes RemoteControl, like my MMM-Config rewrites the config file and doesnt see the comments
                  • kusselinK
                    kusselin @sdetweil
                    @sdetweil said in Netatmo module will not shown:
                    Hello Sam,
                    If I enter this via putty in the path /opt/magicmirror, it will be there:
                    export MM_PORT=8090
                    npm run server
                    root@magicmirror-live:/opt/magicmirror# export MM_PORT=8090
                    > node ./serveronly
                    [2025-05-03 17:00:10.347] [LOG]   Starting MagicMirror: v2.31.0
                    [2025-05-03 17:00:10.361] [LOG]   Loading config ...
                    [2025-05-03 17:00:10.362] [LOG]   config template file not exists, no envsubst
                    [2025-05-03 17:00:10.643] [INFO]  Checking config file /opt/magicmirror/config/config.js ...
                    [2025-05-03 17:00:10.698] [INFO]  Your configuration file doesn't contain syntax errors :)
                    [2025-05-03 17:00:10.698] [INFO]  Checking modules structure configuration ...
                    [2025-05-03 17:00:10.755] [INFO]  Your modules structure configuration doesn't contain errors :)
                    [2025-05-03 17:00:11.073] [LOG]   Loading module helpers ...
                    [2025-05-03 17:00:11.076] [LOG]   No helper found for module: alert.
                    [2025-05-03 17:00:11.094] [LOG]   Initializing new module helper ...
                    [2025-05-03 17:00:11.094] [LOG]   Module helper loaded: updatenotification
                    [2025-05-03 17:00:11.094] [LOG]   No helper found for module: clock.
                    [2025-05-03 17:00:11.267] [LOG]   Initializing new module helper ...
                    [2025-05-03 17:00:11.269] [LOG]   Module helper loaded: calendar
                    [2025-05-03 17:00:11.271] [LOG]   No helper found for module: compliments.
                    [2025-05-03 17:00:11.271] [LOG]   No helper found for module: MMM-OpenmapWeather.
                    [2025-05-03 17:00:11.272] [LOG]   Initializing new module helper ...
                    [2025-05-03 17:00:11.272] [LOG]   Module helper loaded: netatmo
                    [2025-05-03 17:00:11.276] [WARN]  No /opt/magicmirror/modules/MMM-OpenWeatherForecast/MMM-OpenWeatherForecast.js found for module: MMM-OpenWeatherForecast.
                    [2025-05-03 17:00:11.276] [LOG]   No helper found for module: MMM-OpenWeatherForecast.
                    [2025-05-03 17:00:11.276] [LOG]   No helper found for module: MMM-Blitzer.
                    [2025-05-03 17:00:11.277] [LOG]   Initializing new module helper ...
                    [2025-05-03 17:00:11.277] [LOG]   Module helper loaded: MMM-ApothekenNotdienst
                    [2025-05-03 17:00:11.278] [LOG]   Module helper loaded: MMM-ioBroker
                    [2025-05-03 17:00:11.278] [LOG]   No helper found for module: MMM-Carousel.
                    [2025-05-03 17:00:11.322] [LOG]   Initializing new module helper ...
                    [2025-05-03 17:00:11.322] [LOG]   Module helper loaded: MMM-PublicTransportHafas
                    [2025-05-03 17:00:11.518] [LOG]   Initializing new module helper ...
                    [2025-05-03 17:00:11.518] [LOG]   Module helper loaded: MMM-RNV
                    [2025-05-03 17:00:11.519] [LOG]   Initializing new module helper ...
                    [2025-05-03 17:00:11.519] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.31.0
                    [2025-05-03 17:00:11.519] [LOG]   Version is ok!
                    [2025-05-03 17:00:11.519] [LOG]   Module helper loaded: MMM-Fuel
                    [2025-05-03 17:00:11.595] [LOG]   Initializing new module helper ...
                    [2025-05-03 17:00:11.596] [LOG]   Module helper loaded: MMM-Remote-Control
                    [2025-05-03 17:00:11.633] [LOG]   Initializing new module helper ...
                    [2025-05-03 17:00:11.633] [LOG]   Module helper loaded: newsfeed
                    [2025-05-03 17:00:11.633] [LOG]   All module helpers loaded.
                    [2025-05-03 17:00:11.638] [LOG]   Starting server on port 8090 ...
                    [2025-05-03 17:00:11.639] [WARN]  You're using a full whitelist configuration to allow for all IPs
                    [2025-05-03 17:00:11.649] [LOG]   Server started ...
                    [2025-05-03 17:00:11.650] [LOG]   Connecting socket for: updatenotification
                    [2025-05-03 17:00:11.650] [LOG]   Starting module helper: updatenotification
                    [2025-05-03 17:00:11.650] [LOG]   Connecting socket for: calendar
                    [2025-05-03 17:00:11.651] [LOG]   Starting node helper for: calendar
                    [2025-05-03 17:00:11.651] [LOG]   Connecting socket for: netatmo
                    [2025-05-03 17:00:11.651] [LOG]   Netatmo helper started ...
                    [2025-05-03 17:00:11.651] [LOG]   Connecting socket for: MMM-ApothekenNotdienst
                    [2025-05-03 17:00:11.652] [LOG]   Starting module helper: MMM-ApothekenNotdienst
                    [2025-05-03 17:00:11.652] [LOG]   Connecting socket for: MMM-ioBroker
                    [2025-05-03 17:00:11.652] [LOG]   Connecting socket for: MMM-PublicTransportHafas
                    [2025-05-03 17:00:11.652] [LOG]   Connecting socket for: MMM-RNV
                    [2025-05-03 17:00:11.705] [LOG]   Connecting socket for: MMM-Fuel
                    [2025-05-03 17:00:11.705] [LOG]   Starting module helper: MMM-Fuel
                    [2025-05-03 17:00:11.705] [LOG]   Connecting socket for: MMM-Remote-Control
                    [2025-05-03 17:00:11.706] [LOG]   Starting node helper for: MMM-Remote-Control
                    [2025-05-03 17:00:11.708] [LOG]   Connecting socket for: newsfeed
                    [2025-05-03 17:00:11.708] [LOG]   Starting node helper for: newsfeed
                    [2025-05-03 17:00:11.708] [LOG]   Sockets connected & modules started ...
                    [2025-05-03 17:00:11.709] [INFO]
                    >>>   Ready to go! Please point your browser to: http://0.0.0.0:8090   <<<
                    [2025-05-03 17:00:11.808] [INFO]  System information:
                    I have changed it like this under Putty…
                    then press the Ctrl key and C… but then I still have to enter IP:8080 again to display the MM…with IP:8090 it doesn’t work - network overflow
                    All other modules are shown correctly, but Netatmo doesent shown :-( what a f…
                    2 day ist gos good
                      sdetweil @kusselin
                      @kusselin SOOOO much fun!! i do not know. and cannot debug it here
                      • kusselinK
                        kusselin @sdetweil
                        Ok, but it looks good now, doesn’t it?
                        That means it’s the module again.
                        Maybe someone here with Netatmo running will see this?
                        Thanks and greetings
                          sdetweil @kusselin
                          @kusselin yes, dont see anything indicating the problem. all looks good
                          • kusselinK
                            kusselin @sdetweil
                            module: “netatmo”,
                            position: “bottom_left”,
                            order: “*”,
                            animateIn: “None”,
                            animateOut: “None”,
                            clientId: ‘1234567’, // your app id
                            clientSecret: ‘1212123’, // your app secret
                            refresh_token: ‘3223232’, // your generated refresh token
                            mockData: true
                            disabled: false,
                            hiddenOnStartup: false,
                            configDeepMerge: false
                            I have now copied your config from here into the config again and it no longer works… can you please try it again with the mockData: true and take a picture
                            thanks
                              sdetweil @kusselin
                              @kusselin will do, it took a few minutes , i had given up and came back and it was displaying
                              • kusselinK
                                kusselin @det
                                @det said in Netatmo module will not shown:
                                @kusselin
                                Also check that your registration is correct. Make sure you have a current “token.js”.
                                Hi, Where can i find the token.js?
                                  sdetweil @kusselin
                                  @kusselin this version doesn’t use token.js
                                  https://github.com/CFenner/MMM-Netatmo,
                                  uses info in config.js for this module
                                  • kusselinK
                                    kusselin
                                    Hi sam, where can i adjust the intervall time in MM when i have the module „Carousel“?
                                      sdetweil @kusselin
                                      @kusselin in the mmm-carousel readme
                                      https://github.com/shbatm/MMM-Carousel
                                      transitionInterval
                                      • kusselinK
                                        kusselin @sdetweil
                                        @sdetweil thanks a lot sam…i found it self …best man sam :-)
