    Netatmo module will not shown
    40 Posts 5 Posters 11.6k Views 5 Watching
    • kusselinK
      kusselin @sdetweil
      And what does that tell me now? Does that mean I can’t change anything…netatmo won’t work?
      R S 2 Replies Last reply Reply Quote 0
        rkorell Module Developer @kusselin
        @kusselin
        Sorry I‘m out here because I do not have any experience with proxmox containers.
        But in general, what Sam means is that your last log-output indicates that you had tried to start a seond instance of MagicMirror -which fails.
        So I guess it is necessary to identify the primary instance and look for logs there .
        What I have seen in addition but cannot justify: Your above output looks like you‘re working with root permission.
        root@magicmirror-live:/opt/magicmirror# npm run server
        As far as I remember correctly, this may causes difficulties as well - at least I remember to read something like this - context was different and it‘s possible that this doesn‘t apply to container-environments …
        Good luck!
        Regards,
        Ralf
        kusselinK 1 Reply Last reply Reply Quote 0
          sdetweil @kusselin
          @kusselin no, just have to restart the container…
          I am installing proxmox on a vmware VM now,
            @kusselin so with the script I get a container starting to be built, but it has no network
            I see it in the list, can start/stop. but no network.
            this is proxmox in a VM, not native on the hardware…
            I did get a vmware warning that proxmox was trying to set promiscuous mode, but that is not allowed
            • kusselinK
              kusselin @rkorell
              @rkorell said in Netatmo module will not shown:
              @kusselin
              Good luck!
              Regards,
              Ralf
              One question: Do you have Netatmo installed and running at home as hardware and searching in MM…?
              • kusselinK
                kusselin @sdetweil
                @sdetweil said in Netatmo module will not shown:
                Ok du hast dir die mühe gemacht einen proxmox container zu installieren und den MM dort zu installieren…danke erstmal für das machen und testen…
                Heisst im Container läuft der NM nicht so wie er auf einem Raspberry läuft…richtig?
                Heisdt am besten man installiert den MM auf einem Raspi, dann hat man nicht den Ärger…richtig?
                Ich kann halt nicht verdtehen das hier keiner im Forum ist der auch netatmo als Modul installiert hat :-(
                Englisch:
                Ok you made the effort to install a proxmox container and install the MM there…thanks for doing and testing…
                That means the NM does not run in the container the way it runs on a raspberry…right?
                It’s best to install the MM on a Raspi, then you don’t have the trouble…right?
                I just can’t understand that there is no one here in the forum who has also installed netatmo as a module :-(
                What do you mean by “no network”?
                I have a connection and other modules are displayed correctly, so I don’t understand this
                  Nope, Netatmo not used by me …
                  Regards,
                  Ralf
                    sdetweil @kusselin
                    @kusselin no network
                    the script says there is no network card for the container so it cannot talk to anything
                    from the script output see <---- below
                        __  ___            _      __  ____
                       /  |/  /___ _____ _(_)____/  |/  (_)_____________  _____
                      / /|_/ / __ `/ __ `/ / ___/ /|_/ / / ___/ ___/ __ \/ ___/
                     / /  / / /_/ / /_/ / / /__/ /  / / / /  / /  / /_/ / /
                    /_/  /_/\__,_/\__, /_/\___/_/  /_/_/_/  /_/   \____/_/
                                 /____/
                      🧩  Using Advanced Settings on node pve
                      🖥️  Operating System: debian
                      🌟  Version: 12
                      📦  Container Type: Unprivileged
                      🔐  Root Password: ********
                      🆔  Container ID: 101
                      🏠  Hostname: magicmirror
                      💾  Disk Size: 3 GB
                      🧠  CPU Cores: 1
                      🛠️  RAM Size: 512 MiB
                      🌉  Bridge: vmbr0
                      📡  IP Address: dhcp
                      🌐  Gateway IP Address: Default
                      📡  APT-Cacher IP Address: Default
                      🚫  Disable IPv6: yes
                      ⚙️  Interface MTU Size: Default
                      🔍  DNS Search Domain: Host
                      📡  DNS Server IP Address: Host
                      🏷️  Vlan: Default
                      📡  Tags: community-script;magicmirror
                      🔑  Root SSH Access: yes
                    Warning: No SSH key provided.
                      🔍  Verbose Mode: yes
                      🚀  Creating a MagicMirror LXC using the above advanced settings
                      ✔️  Using local for Template Storage.
                      ✔️  Using local-lvm for Container Storage.
                      ✔️  Updated LXC Template List
                      ✔️  LXC Template is ready to use.
                      ✔️  LXC Container 101 was successfully created.
                      ✔️   Started LXC Container
                    net.ipv6.conf.all.disable_ipv6 = 1
                     ⠇  ✖️   No Network! ner OS      <----
                      ✖️   No Network After 10 Tries  <---
                      📡  Check Network Settings
                    /dev/fd/63: line 72: SPINNER_PID: unbound variable
                      @kusselin problem here was disk and memory too small… 10g disk and 2048g memory and install finished…
                        @kusselin so I had to use the mockdata: true option as I don’t have any server for this
                        I set the clientid… to garbage numbers . module fails if not set
                        and mockdata: true and after a while I see this on the lxc container MM instance
                        (MMM-Config generated config entry)
                                module: "netatmo",
                                position: "bottom_left",
                                order: "*",
                                animateIn: "None",
                                animateOut: "None",
                                   clientId: '1234567', // your app id
                                   clientSecret: '1212123', // your app secret
                                   refresh_token: '3223232', // your generated refresh token
                                  mockData: true
                                disabled: false,
                                hiddenOnStartup: false,
                                configDeepMerge: false
                        the system service is setup without logging, so the MM app logging is lost…
                        for me lxc container looks and acts like a Virtual machine, (restricted to OS structure proxmox is running on)
                        kusselinK 2 Replies Last reply Reply Quote 0
                        • kusselinK
                          kusselin @sdetweil
                          Hello sam, first of all thank you for your support and your testing!
                          Then why create MM for Proxmox? If it can’t find a network?
                          But in your screenshot I see Netatmo, it is displayed, or are you missing the values?
                          What does your testing and your statements tell me as a layman from MM?
                          Can I now not use Netatmo in the LXC container with Proxmox?
                          Other modules such as calender, clock public transfer hafas and RNV work perfectly.
                          Thank you for any clarification so that I can understand it.
                          EDIT:
                          Hello Sam, if I use your config posted here and copy it in exactly the same way, netatmo is displayed but only with Hamburg and not my station…but it works…
                          I have used my code stored in the developer account as ID and secret key.
                          Shouldn’t MM then also show my location?
                          as soon as I set “MockData” to false, netatmo is no longer displayed…so you can say that the module itself works but not with the real data…think it’s the secret token…I read something here on the board
                          look:
                          https://forum.magicmirror.builders/topic/18690/mmm-netatmothermostat/2
                          • kusselinK
                            kusselin
                            so I’ll contact you again…es is displayed…perfekr…I took the template from SAM here and then adapted it again accordingly…now it works…thanks to everyone and especially once again to SAM …;-)
                            • LusbuebL
                              Lusbueb @kusselin
                              @kusselin
                              In your configuration, I’m missing the entry modulOrder. This entry was essential for me! I initially used the default name until I realized that it only works if the module name is stored exactly as you configured it in the web-app (https://auth.netatmo.com/de-de/access/login):
                              my config:
                              		module: 'netatmo',
                              		position: 'middle_center', // the location where the module should be displayed
                              			clientId: '*myID*', // your app id
                              			clientSecret: '*mysecret*', // your app secret
                              			refresh_token: *'mytoken*', // your generated refresh token
                              			moduleOrder: ["Outdoor","Regen","Wind","Schlafzimmer","Wohnzimmer"], //take same names from web-app!
                              			updateInterval: 6, // every 3 minutes, refresh interval on netatmo is 10 minutes
                              			animationSpeed: 1000,
                              			design: 'bubbles', // classic or bubbles
                              			horizontal: false,
                              			lastMessageThreshold: 600, // in seconds (10 minutes)
                              			showLastMessage: true,
                              			showBattery: true,
                              			showRadio: true,
                              			showWiFi: true,
                              			showTrend: true,
                              			showMeasurementIcon: true,
                              			showMeasurementLabel: true,
                              			showStationName: false,
                              			showModuleNameOnTop: true,
                              			fontClassModuleName: 'small', // xsmall, small, medium, large, xlarge
                              			fontClassPrimary: 'large',
                              			fontClassSecondary: 'xsmall',
                              			fontClassMeasurement: 'xsmall',
                              			thresholdCO2Average: 800,
                              			thresholdCO2Bad: 1800,
                              			mockData: false,
                              https://home.netatmo.com/control/dashboard
                              MM:
                              kusselinK 1 Reply Last reply Reply Quote 1
                                sdetweil @kusselin
                                @kusselin congratulations!!! i’m glad you got it working
                                • kusselinK
                                  kusselin @Lusbueb
                                  @Lusbueb said in Netatmo module will not shown:
                                  @kusselin
                                  my config:
                                  		module: 'netatmo',
                                  			horizontal: false,
                                  			showBattery: true,
                                  			showRadio: true,
                                  			showWiFi: true,
                                  			showTrend: true,
                                  			mockData: false,
                                  MM:
                                  Thanks s lot for your config…i changed it and now ist good and the netatmo Modul is running very well
                                  • kusselinK
                                    kusselin
                                    Hello everyone, netatmo is no longer working today :-(
                                    I haven’t changed anything
                                      sdetweil @kusselin
                                      @kusselin need to see the logs again
                                      always 1st place to look
                                      • kusselinK
                                        kusselin @sdetweil
                                        Hi sam, look here again…
                                        verbose cli /usr/bin/node /usr/bin/npm
                                        1 info using npm@10.9.2
                                        2 info using node@v22.15.0
                                        3 silly config load:file:/usr/lib/node_modules/npm/npmrc
                                        4 silly config load:file:/opt/magicmirror/.npmrc
                                        5 silly config load:file:/root/.npmrc
                                        6 silly config load:file:/usr/etc/npmrc
                                        7 verbose title npm run seerver
                                        8 verbose argv "run" "seerver"
                                        9 verbose logfile logs-max:10 dir:/root/.npm/_logs/2025-05-03T14_24_21_403Z-
                                        10 verbose logfile /root/.npm/_logs/2025-05-03T14_24_21_403Z-debug-0.log
                                        11 silly logfile start cleaning logs, removing 1 files
                                        12 silly logfile done cleaning log files
                                        13 verbose stack Error: Missing script: "seerver"
                                        13 verbose stack
                                        13 verbose stack Did you mean this?
                                        13 verbose stack   npm run server # run the "server" package script
                                        13 verbose stack
                                        13 verbose stack To see a list of scripts, run:
                                        13 verbose stack     at #run (/usr/lib/node_modules/npm/lib/commands/run-script.js:111:13)
                                        13 verbose stack     at async RunScript.exec (/usr/lib/node_modules/npm/lib/commands/run-script.js:40:7)
                                        13 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
                                        13 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5)
                                        14 error Missing script: "seerver"
                                        14 error
                                        14 error Did you mean this?
                                        14 error   npm run server # run the "server" package script
                                        14 error
                                        14 error To see a list of scripts, run:
                                        14 error   npm run
                                        15 verbose cwd /opt/magicmirror
                                        16 verbose os Linux 6.8.12-8-pve
                                        17 verbose node v22.15.0
                                        18 verbose npm  v10.9.2
                                        19 verbose exit 1
                                        20 verbose code 1
                                        21 error A complete log of this run can be found in: /root/.npm/_logs/2025-05-03T14_24_21_403Z-debug-0.log
                                        and the latest Log:
                                        0 verbose cli /usr/bin/node /usr/bin/npm
                                        7 verbose title npm run server
                                        8 verbose argv "run" "server"
                                        9 verbose logfile logs-max:10 dir:/root/.npm/_logs/2025-05-03T14_24_50_844Z-
                                        10 verbose logfile /root/.npm/_logs/2025-05-03T14_24_50_844Z-debug-0.log
                                        13 verbose cwd /opt/magicmirror
                                        14 verbose os Linux 6.8.12-8-pve
                                        15 verbose node v22.15.0
                                        16 verbose npm  v10.9.2
                                        17 verbose exit 0
                                        18 info ok
                                        here is the info wenn i go into /opt/magicmirror/ and “npm run server”:
                                        The programs included with the Debian GNU/Linux system are free software;
                                        the exact distribution terms for each program are described in the
                                        individual files in /usr/share/doc/*/copyright.
                                        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                        permitted by applicable law.
                                        Last login: Sat May  3 16:23:40 2025 from 192.168.200.219
                                        MagicMirror LXC Container
                                            🌐   Provided by: community-scripts ORG | GitHub: https://github.com/community-scripts/ProxmoxVE
                                            🖥️   OS: Debian GNU/Linux - Version: 12
                                            🏠   Hostname: magicmirror-live
                                            💡   IP Address: 192.168.200.74
                                        root@magicmirror-live:~# cd /opt/magicmirror
                                        > magicmirror@2.31.0 server
                                        > node ./serveronly
                                        [2025-05-03 16:40:49.450] [LOG]   Starting MagicMirror: v2.31.0
                                        [2025-05-03 16:40:49.469] [LOG]   Loading config ...
                                        [2025-05-03 16:40:49.470] [LOG]   config template file not exists, no envsubst
                                        [2025-05-03 16:40:49.876] [INFO]  Checking config file /opt/magicmirror/config/config.js ...
                                        [2025-05-03 16:40:49.930] [INFO]  Your configuration file doesn't contain syntax errors :)
                                        [2025-05-03 16:40:49.931] [INFO]  Checking modules structure configuration ...
                                        [2025-05-03 16:40:50.003] [INFO]  Your modules structure configuration doesn't contain errors :)
                                        [2025-05-03 16:40:50.519] [LOG]   Loading module helpers ...
                                        [2025-05-03 16:40:50.528] [LOG]   No helper found for module: alert.
                                        [2025-05-03 16:40:50.551] [LOG]   Initializing new module helper ...
                                        [2025-05-03 16:40:50.555] [LOG]   Module helper loaded: updatenotification
                                        [2025-05-03 16:40:50.557] [LOG]   No helper found for module: clock.
                                        [2025-05-03 16:40:50.934] [LOG]   Initializing new module helper ...
                                        [2025-05-03 16:40:50.936] [LOG]   Module helper loaded: calendar
                                        [2025-05-03 16:40:50.941] [LOG]   No helper found for module: compliments.
                                        [2025-05-03 16:40:50.943] [LOG]   No helper found for module: MMM-OpenmapWeather.
                                        [2025-05-03 16:40:50.950] [LOG]   Initializing new module helper ...
                                        [2025-05-03 16:40:50.952] [LOG]   Module helper loaded: netatmo
                                        [2025-05-03 16:40:50.954] [WARN]  No /opt/magicmirror/modules/MMM-OpenWeatherForecast/MMM-OpenWeatherForecast.js found for module: MMM-OpenWeatherForecast.
                                        [2025-05-03 16:40:50.955] [LOG]   No helper found for module: MMM-OpenWeatherForecast.
                                        [2025-05-03 16:40:50.955] [LOG]   No helper found for module: MMM-Blitzer.
                                        [2025-05-03 16:40:50.958] [LOG]   Initializing new module helper ...
                                        [2025-05-03 16:40:50.960] [LOG]   Module helper loaded: MMM-ApothekenNotdienst
                                        [2025-05-03 16:40:50.962] [LOG]   Initializing new module helper ...
                                        [2025-05-03 16:40:50.965] [LOG]   Module helper loaded: MMM-ioBroker
                                        [2025-05-03 16:40:50.965] [LOG]   No helper found for module: MMM-Carousel.
                                        [2025-05-03 16:40:51.040] [LOG]   Initializing new module helper ...
                                        [2025-05-03 16:40:51.040] [LOG]   Module helper loaded: MMM-PublicTransportHafas
                                        [2025-05-03 16:40:51.480] [LOG]   Initializing new module helper ...
                                        [2025-05-03 16:40:51.480] [LOG]   Module helper loaded: MMM-RNV
                                        [2025-05-03 16:40:51.482] [LOG]   Initializing new module helper ...
                                        [2025-05-03 16:40:51.482] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.31.0
                                        [2025-05-03 16:40:51.482] [LOG]   Version is ok!
                                        [2025-05-03 16:40:51.483] [LOG]   Module helper loaded: MMM-Fuel
                                        [2025-05-03 16:40:51.591] [LOG]   Initializing new module helper ...
                                        [2025-05-03 16:40:51.591] [LOG]   Module helper loaded: MMM-Remote-Control
                                        [2025-05-03 16:40:51.658] [LOG]   Initializing new module helper ...
                                        [2025-05-03 16:40:51.659] [LOG]   Module helper loaded: newsfeed
                                        [2025-05-03 16:40:51.659] [LOG]   All module helpers loaded.
                                        [2025-05-03 16:40:51.663] [LOG]   Starting server on port 8080 ...
                                        [2025-05-03 16:40:51.664] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                        [2025-05-03 16:40:51.673] [ERROR] Whoops! There was an uncaught exception...
                                        [2025-05-03 16:40:51.673] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                            at Server.setupListenHandle [as _listen2] (node:net:1939:16)
                                            at listenInCluster (node:net:1996:12)
                                            at node:net:2205:7
                                            at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
                                          code: 'EADDRINUSE',
                                          errno: -98,
                                          syscall: 'listen',
                                          address: '0.0.0.0',
                                          port: 8080
                                        [2025-05-03 16:40:51.673] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        [2025-05-03 16:40:51.673] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                                        [2025-05-03 16:40:51.783] [INFO]  System information:
                                        ### SYSTEM:   manufacturer: ; model: ; virtual: false
                                        ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: x64; kernel: 6.8.12-8-pve
                                        ### VERSIONS: electron: undefined; used node: 22.15.0; installed node: 22.15.0; npm: 10.9.2; pm2: 5.4.3
                                        ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                                        her my Config from MM:
                                        /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                                              module: 'netatmo',
                                              position: 'bottom_left',
                                                clientId: '123456,
                                                clientSecret: '1234',
                                                refresh_token: '1234',
                                                moduleOrder: [
                                                  'Aussenmodul',
                                                  'Regenmesser',
                                                  'Windmesser',
                                                  'Wohnen'
                                                updateInterval: 6,
                                                design: 'bubbles',
                                                horizontal: false,
                                        what I don’t understand either…because of the remote control module the config looks completely different than normal…but I think that has nothing to do with Netatmo…right?
                                        I would be really grateful for your help…
                                        Greetings
                                          sdetweil @kusselin
                                          @kusselin the ‘already in use’ is because the container is running MagicMirror as a system service
                                          you could use a different port for the test
                                          export MM_PORT=8090
                                          npm run server
                                          now you have two instances running
                                          one on 8080 and one on 8090
                                          ctrl-c to stop the one on 8090
                                            sdetweil @kusselin
                                            @kusselin config format, yes RemoteControl, like my MMM-Config rewrites the config file and doesnt see the comments
