    Netatmo module will not shown
    40 Posts 5 Posters 11.6k Views 5 Watching
      @kusselin so with the script I get a container starting to be built, but it has no network
      I see it in the list, can start/stop. but no network.
      this is proxmox in a VM, not native on the hardware…
      I did get a vmware warning that proxmox was trying to set promiscuous mode, but that is not allowed
      kusselinK 1 Reply Last reply Reply Quote 0
      • kusselinK
        kusselin @rkorell
        @rkorell said in Netatmo module will not shown:
        @kusselin
        Sorry I‘m out here because I do not have any experience with proxmox containers.
        But in general, what Sam means is that your last log-output indicates that you had tried to start a seond instance of MagicMirror -which fails.
        So I guess it is necessary to identify the primary instance and look for logs there .
        What I have seen in addition but cannot justify: Your above output looks like you‘re working with root permission.
        root@magicmirror-live:/opt/magicmirror# npm run server
        As far as I remember correctly, this may causes difficulties as well - at least I remember to read something like this - context was different and it‘s possible that this doesn‘t apply to container-environments …
        Good luck!
        Regards,
        Ralf
        One question: Do you have Netatmo installed and running at home as hardware and searching in MM…?
        • kusselinK
          kusselin @sdetweil
          @sdetweil said in Netatmo module will not shown:
          Ok du hast dir die mühe gemacht einen proxmox container zu installieren und den MM dort zu installieren…danke erstmal für das machen und testen…
          Heisst im Container läuft der NM nicht so wie er auf einem Raspberry läuft…richtig?
          Heisdt am besten man installiert den MM auf einem Raspi, dann hat man nicht den Ärger…richtig?
          Ich kann halt nicht verdtehen das hier keiner im Forum ist der auch netatmo als Modul installiert hat :-(
          Englisch:
          Ok you made the effort to install a proxmox container and install the MM there…thanks for doing and testing…
          That means the NM does not run in the container the way it runs on a raspberry…right?
          It’s best to install the MM on a Raspi, then you don’t have the trouble…right?
          I just can’t understand that there is no one here in the forum who has also installed netatmo as a module :-(
          What do you mean by “no network”?
          I have a connection and other modules are displayed correctly, so I don’t understand this
            rkorell Module Developer @kusselin
            Nope, Netatmo not used by me …
            Regards,
            Ralf
              sdetweil @kusselin
              @kusselin no network
              the script says there is no network card for the container so it cannot talk to anything
              from the script output see <---- below
                  __  ___            _      __  ____
                 /  |/  /___ _____ _(_)____/  |/  (_)_____________  _____
                / /|_/ / __ `/ __ `/ / ___/ /|_/ / / ___/ ___/ __ \/ ___/
               / /  / / /_/ / /_/ / / /__/ /  / / / /  / /  / /_/ / /
              /_/  /_/\__,_/\__, /_/\___/_/  /_/_/_/  /_/   \____/_/
                           /____/
                🧩  Using Advanced Settings on node pve
                🖥️  Operating System: debian
                🌟  Version: 12
                📦  Container Type: Unprivileged
                🔐  Root Password: ********
                🆔  Container ID: 101
                🏠  Hostname: magicmirror
                💾  Disk Size: 3 GB
                🧠  CPU Cores: 1
                🛠️  RAM Size: 512 MiB
                🌉  Bridge: vmbr0
                📡  IP Address: dhcp
                🌐  Gateway IP Address: Default
                📡  APT-Cacher IP Address: Default
                🚫  Disable IPv6: yes
                ⚙️  Interface MTU Size: Default
                🔍  DNS Search Domain: Host
                📡  DNS Server IP Address: Host
                🏷️  Vlan: Default
                📡  Tags: community-script;magicmirror
                🔑  Root SSH Access: yes
              Warning: No SSH key provided.
                🔍  Verbose Mode: yes
                🚀  Creating a MagicMirror LXC using the above advanced settings
                ✔️  Using local for Template Storage.
                ✔️  Using local-lvm for Container Storage.
                ✔️  Updated LXC Template List
                ✔️  LXC Template is ready to use.
                ✔️  LXC Container 101 was successfully created.
                ✔️   Started LXC Container
              net.ipv6.conf.all.disable_ipv6 = 1
               ⠇  ✖️   No Network! ner OS      <----
                ✖️   No Network After 10 Tries  <---
                📡  Check Network Settings
              /dev/fd/63: line 72: SPINNER_PID: unbound variable
                @kusselin problem here was disk and memory too small… 10g disk and 2048g memory and install finished…
                  @kusselin so I had to use the mockdata: true option as I don’t have any server for this
                  I set the clientid… to garbage numbers . module fails if not set
                  and mockdata: true and after a while I see this on the lxc container MM instance
                  (MMM-Config generated config entry)
                          module: "netatmo",
                          position: "bottom_left",
                          order: "*",
                          animateIn: "None",
                          animateOut: "None",
                             clientId: '1234567', // your app id
                             clientSecret: '1212123', // your app secret
                             refresh_token: '3223232', // your generated refresh token
                            mockData: true
                          disabled: false,
                          hiddenOnStartup: false,
                          configDeepMerge: false
                  the system service is setup without logging, so the MM app logging is lost…
                  for me lxc container looks and acts like a Virtual machine, (restricted to OS structure proxmox is running on)
                  kusselinK 2 Replies Last reply Reply Quote 0
                  • kusselinK
                    kusselin @sdetweil
                    Hello sam, first of all thank you for your support and your testing!
                    Then why create MM for Proxmox? If it can’t find a network?
                    But in your screenshot I see Netatmo, it is displayed, or are you missing the values?
                    What does your testing and your statements tell me as a layman from MM?
                    Can I now not use Netatmo in the LXC container with Proxmox?
                    Other modules such as calender, clock public transfer hafas and RNV work perfectly.
                    Thank you for any clarification so that I can understand it.
                    EDIT:
                    Hello Sam, if I use your config posted here and copy it in exactly the same way, netatmo is displayed but only with Hamburg and not my station…but it works…
                    I have used my code stored in the developer account as ID and secret key.
                    Shouldn’t MM then also show my location?
                    as soon as I set “MockData” to false, netatmo is no longer displayed…so you can say that the module itself works but not with the real data…think it’s the secret token…I read something here on the board
                    look:
                    https://forum.magicmirror.builders/topic/18690/mmm-netatmothermostat/2
                    • kusselinK
                      kusselin
                      so I’ll contact you again…es is displayed…perfekr…I took the template from SAM here and then adapted it again accordingly…now it works…thanks to everyone and especially once again to SAM …;-)
                      • LusbuebL
                        Lusbueb @kusselin
                        @kusselin
                        In your configuration, I’m missing the entry modulOrder. This entry was essential for me! I initially used the default name until I realized that it only works if the module name is stored exactly as you configured it in the web-app (https://auth.netatmo.com/de-de/access/login):
                        my config:
                        		module: 'netatmo',
                        		position: 'middle_center', // the location where the module should be displayed
                        			clientId: '*myID*', // your app id
                        			clientSecret: '*mysecret*', // your app secret
                        			refresh_token: *'mytoken*', // your generated refresh token
                        			moduleOrder: ["Outdoor","Regen","Wind","Schlafzimmer","Wohnzimmer"], //take same names from web-app!
                        			updateInterval: 6, // every 3 minutes, refresh interval on netatmo is 10 minutes
                        			animationSpeed: 1000,
                        			design: 'bubbles', // classic or bubbles
                        			horizontal: false,
                        			lastMessageThreshold: 600, // in seconds (10 minutes)
                        			showLastMessage: true,
                        			showBattery: true,
                        			showRadio: true,
                        			showWiFi: true,
                        			showTrend: true,
                        			showMeasurementIcon: true,
                        			showMeasurementLabel: true,
                        			showStationName: false,
                        			showModuleNameOnTop: true,
                        			fontClassModuleName: 'small', // xsmall, small, medium, large, xlarge
                        			fontClassPrimary: 'large',
                        			fontClassSecondary: 'xsmall',
                        			fontClassMeasurement: 'xsmall',
                        			thresholdCO2Average: 800,
                        			thresholdCO2Bad: 1800,
                        			mockData: false,
                        https://home.netatmo.com/control/dashboard
                        MM:
                        kusselinK 1 Reply Last reply Reply Quote 1
                          sdetweil @kusselin
                          @kusselin congratulations!!! i’m glad you got it working
                          • kusselinK
                            kusselin @Lusbueb
                            @Lusbueb said in Netatmo module will not shown:
                            @kusselin
                            my config:
                            		module: 'netatmo',
                            			horizontal: false,
                            			showBattery: true,
                            			showRadio: true,
                            			showWiFi: true,
                            			showTrend: true,
                            			mockData: false,
                            MM:
                            Thanks s lot for your config…i changed it and now ist good and the netatmo Modul is running very well
                            • kusselinK
                              kusselin
                              Hello everyone, netatmo is no longer working today :-(
                              I haven’t changed anything
                                sdetweil @kusselin
                                @kusselin need to see the logs again
                                always 1st place to look
                                • kusselinK
                                  kusselin @sdetweil
                                  Hi sam, look here again…
                                  verbose cli /usr/bin/node /usr/bin/npm
                                  1 info using npm@10.9.2
                                  2 info using node@v22.15.0
                                  3 silly config load:file:/usr/lib/node_modules/npm/npmrc
                                  4 silly config load:file:/opt/magicmirror/.npmrc
                                  5 silly config load:file:/root/.npmrc
                                  6 silly config load:file:/usr/etc/npmrc
                                  7 verbose title npm run seerver
                                  8 verbose argv "run" "seerver"
                                  9 verbose logfile logs-max:10 dir:/root/.npm/_logs/2025-05-03T14_24_21_403Z-
                                  10 verbose logfile /root/.npm/_logs/2025-05-03T14_24_21_403Z-debug-0.log
                                  11 silly logfile start cleaning logs, removing 1 files
                                  12 silly logfile done cleaning log files
                                  13 verbose stack Error: Missing script: "seerver"
                                  13 verbose stack
                                  13 verbose stack Did you mean this?
                                  13 verbose stack   npm run server # run the "server" package script
                                  13 verbose stack
                                  13 verbose stack To see a list of scripts, run:
                                  13 verbose stack     at #run (/usr/lib/node_modules/npm/lib/commands/run-script.js:111:13)
                                  13 verbose stack     at async RunScript.exec (/usr/lib/node_modules/npm/lib/commands/run-script.js:40:7)
                                  13 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
                                  13 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5)
                                  14 error Missing script: "seerver"
                                  14 error
                                  14 error Did you mean this?
                                  14 error   npm run server # run the "server" package script
                                  14 error
                                  14 error To see a list of scripts, run:
                                  14 error   npm run
                                  15 verbose cwd /opt/magicmirror
                                  16 verbose os Linux 6.8.12-8-pve
                                  17 verbose node v22.15.0
                                  18 verbose npm  v10.9.2
                                  19 verbose exit 1
                                  20 verbose code 1
                                  21 error A complete log of this run can be found in: /root/.npm/_logs/2025-05-03T14_24_21_403Z-debug-0.log
                                  and the latest Log:
                                  0 verbose cli /usr/bin/node /usr/bin/npm
                                  7 verbose title npm run server
                                  8 verbose argv "run" "server"
                                  9 verbose logfile logs-max:10 dir:/root/.npm/_logs/2025-05-03T14_24_50_844Z-
                                  10 verbose logfile /root/.npm/_logs/2025-05-03T14_24_50_844Z-debug-0.log
                                  13 verbose cwd /opt/magicmirror
                                  14 verbose os Linux 6.8.12-8-pve
                                  15 verbose node v22.15.0
                                  16 verbose npm  v10.9.2
                                  17 verbose exit 0
                                  18 info ok
                                  here is the info wenn i go into /opt/magicmirror/ and “npm run server”:
                                  The programs included with the Debian GNU/Linux system are free software;
                                  the exact distribution terms for each program are described in the
                                  individual files in /usr/share/doc/*/copyright.
                                  Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                  permitted by applicable law.
                                  Last login: Sat May  3 16:23:40 2025 from 192.168.200.219
                                  MagicMirror LXC Container
                                      🌐   Provided by: community-scripts ORG | GitHub: https://github.com/community-scripts/ProxmoxVE
                                      🖥️   OS: Debian GNU/Linux - Version: 12
                                      🏠   Hostname: magicmirror-live
                                      💡   IP Address: 192.168.200.74
                                  root@magicmirror-live:~# cd /opt/magicmirror
                                  > magicmirror@2.31.0 server
                                  > node ./serveronly
                                  [2025-05-03 16:40:49.450] [LOG]   Starting MagicMirror: v2.31.0
                                  [2025-05-03 16:40:49.469] [LOG]   Loading config ...
                                  [2025-05-03 16:40:49.470] [LOG]   config template file not exists, no envsubst
                                  [2025-05-03 16:40:49.876] [INFO]  Checking config file /opt/magicmirror/config/config.js ...
                                  [2025-05-03 16:40:49.930] [INFO]  Your configuration file doesn't contain syntax errors :)
                                  [2025-05-03 16:40:49.931] [INFO]  Checking modules structure configuration ...
                                  [2025-05-03 16:40:50.003] [INFO]  Your modules structure configuration doesn't contain errors :)
                                  [2025-05-03 16:40:50.519] [LOG]   Loading module helpers ...
                                  [2025-05-03 16:40:50.528] [LOG]   No helper found for module: alert.
                                  [2025-05-03 16:40:50.551] [LOG]   Initializing new module helper ...
                                  [2025-05-03 16:40:50.555] [LOG]   Module helper loaded: updatenotification
                                  [2025-05-03 16:40:50.557] [LOG]   No helper found for module: clock.
                                  [2025-05-03 16:40:50.934] [LOG]   Initializing new module helper ...
                                  [2025-05-03 16:40:50.936] [LOG]   Module helper loaded: calendar
                                  [2025-05-03 16:40:50.941] [LOG]   No helper found for module: compliments.
                                  [2025-05-03 16:40:50.943] [LOG]   No helper found for module: MMM-OpenmapWeather.
                                  [2025-05-03 16:40:50.950] [LOG]   Initializing new module helper ...
                                  [2025-05-03 16:40:50.952] [LOG]   Module helper loaded: netatmo
                                  [2025-05-03 16:40:50.954] [WARN]  No /opt/magicmirror/modules/MMM-OpenWeatherForecast/MMM-OpenWeatherForecast.js found for module: MMM-OpenWeatherForecast.
                                  [2025-05-03 16:40:50.955] [LOG]   No helper found for module: MMM-OpenWeatherForecast.
                                  [2025-05-03 16:40:50.955] [LOG]   No helper found for module: MMM-Blitzer.
                                  [2025-05-03 16:40:50.958] [LOG]   Initializing new module helper ...
                                  [2025-05-03 16:40:50.960] [LOG]   Module helper loaded: MMM-ApothekenNotdienst
                                  [2025-05-03 16:40:50.962] [LOG]   Initializing new module helper ...
                                  [2025-05-03 16:40:50.965] [LOG]   Module helper loaded: MMM-ioBroker
                                  [2025-05-03 16:40:50.965] [LOG]   No helper found for module: MMM-Carousel.
                                  [2025-05-03 16:40:51.040] [LOG]   Initializing new module helper ...
                                  [2025-05-03 16:40:51.040] [LOG]   Module helper loaded: MMM-PublicTransportHafas
                                  [2025-05-03 16:40:51.480] [LOG]   Initializing new module helper ...
                                  [2025-05-03 16:40:51.480] [LOG]   Module helper loaded: MMM-RNV
                                  [2025-05-03 16:40:51.482] [LOG]   Initializing new module helper ...
                                  [2025-05-03 16:40:51.482] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.31.0
                                  [2025-05-03 16:40:51.482] [LOG]   Version is ok!
                                  [2025-05-03 16:40:51.483] [LOG]   Module helper loaded: MMM-Fuel
                                  [2025-05-03 16:40:51.591] [LOG]   Initializing new module helper ...
                                  [2025-05-03 16:40:51.591] [LOG]   Module helper loaded: MMM-Remote-Control
                                  [2025-05-03 16:40:51.658] [LOG]   Initializing new module helper ...
                                  [2025-05-03 16:40:51.659] [LOG]   Module helper loaded: newsfeed
                                  [2025-05-03 16:40:51.659] [LOG]   All module helpers loaded.
                                  [2025-05-03 16:40:51.663] [LOG]   Starting server on port 8080 ...
                                  [2025-05-03 16:40:51.664] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                  [2025-05-03 16:40:51.673] [ERROR] Whoops! There was an uncaught exception...
                                  [2025-05-03 16:40:51.673] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                      at Server.setupListenHandle [as _listen2] (node:net:1939:16)
                                      at listenInCluster (node:net:1996:12)
                                      at node:net:2205:7
                                      at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
                                    code: 'EADDRINUSE',
                                    errno: -98,
                                    syscall: 'listen',
                                    address: '0.0.0.0',
                                    port: 8080
                                  [2025-05-03 16:40:51.673] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  [2025-05-03 16:40:51.673] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                                  [2025-05-03 16:40:51.783] [INFO]  System information:
                                  ### SYSTEM:   manufacturer: ; model: ; virtual: false
                                  ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: x64; kernel: 6.8.12-8-pve
                                  ### VERSIONS: electron: undefined; used node: 22.15.0; installed node: 22.15.0; npm: 10.9.2; pm2: 5.4.3
                                  ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                                  her my Config from MM:
                                  /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                                        module: 'netatmo',
                                        position: 'bottom_left',
                                          clientId: '123456,
                                          clientSecret: '1234',
                                          refresh_token: '1234',
                                          moduleOrder: [
                                            'Aussenmodul',
                                            'Regenmesser',
                                            'Windmesser',
                                            'Wohnen'
                                          updateInterval: 6,
                                          design: 'bubbles',
                                          horizontal: false,
                                  what I don’t understand either…because of the remote control module the config looks completely different than normal…but I think that has nothing to do with Netatmo…right?
                                  I would be really grateful for your help…
                                  Greetings
                                    sdetweil @kusselin
                                    @kusselin the ‘already in use’ is because the container is running MagicMirror as a system service
                                    you could use a different port for the test
                                    export MM_PORT=8090
                                    npm run server
                                    now you have two instances running
                                    one on 8080 and one on 8090
                                    ctrl-c to stop the one on 8090
                                      sdetweil @kusselin
                                      @kusselin config format, yes RemoteControl, like my MMM-Config rewrites the config file and doesnt see the comments
                                      • kusselinK
                                        kusselin @sdetweil
                                        Hello Sam,
                                        If I enter this via putty in the path /opt/magicmirror, it will be there:
                                        export MM_PORT=8090
                                        npm run server
                                        root@magicmirror-live:/opt/magicmirror# export MM_PORT=8090
                                        > node ./serveronly
                                        [2025-05-03 17:00:10.347] [LOG]   Starting MagicMirror: v2.31.0
                                        [2025-05-03 17:00:10.361] [LOG]   Loading config ...
                                        [2025-05-03 17:00:10.362] [LOG]   config template file not exists, no envsubst
                                        [2025-05-03 17:00:10.643] [INFO]  Checking config file /opt/magicmirror/config/config.js ...
                                        [2025-05-03 17:00:10.698] [INFO]  Your configuration file doesn't contain syntax errors :)
                                        [2025-05-03 17:00:10.698] [INFO]  Checking modules structure configuration ...
                                        [2025-05-03 17:00:10.755] [INFO]  Your modules structure configuration doesn't contain errors :)
                                        [2025-05-03 17:00:11.073] [LOG]   Loading module helpers ...
                                        [2025-05-03 17:00:11.076] [LOG]   No helper found for module: alert.
                                        [2025-05-03 17:00:11.094] [LOG]   Initializing new module helper ...
                                        [2025-05-03 17:00:11.094] [LOG]   Module helper loaded: updatenotification
                                        [2025-05-03 17:00:11.094] [LOG]   No helper found for module: clock.
                                        [2025-05-03 17:00:11.267] [LOG]   Initializing new module helper ...
                                        [2025-05-03 17:00:11.269] [LOG]   Module helper loaded: calendar
                                        [2025-05-03 17:00:11.271] [LOG]   No helper found for module: compliments.
                                        [2025-05-03 17:00:11.271] [LOG]   No helper found for module: MMM-OpenmapWeather.
                                        [2025-05-03 17:00:11.272] [LOG]   Initializing new module helper ...
                                        [2025-05-03 17:00:11.272] [LOG]   Module helper loaded: netatmo
                                        [2025-05-03 17:00:11.276] [WARN]  No /opt/magicmirror/modules/MMM-OpenWeatherForecast/MMM-OpenWeatherForecast.js found for module: MMM-OpenWeatherForecast.
                                        [2025-05-03 17:00:11.276] [LOG]   No helper found for module: MMM-OpenWeatherForecast.
                                        [2025-05-03 17:00:11.276] [LOG]   No helper found for module: MMM-Blitzer.
                                        [2025-05-03 17:00:11.277] [LOG]   Initializing new module helper ...
                                        [2025-05-03 17:00:11.277] [LOG]   Module helper loaded: MMM-ApothekenNotdienst
                                        [2025-05-03 17:00:11.278] [LOG]   Module helper loaded: MMM-ioBroker
                                        [2025-05-03 17:00:11.278] [LOG]   No helper found for module: MMM-Carousel.
                                        [2025-05-03 17:00:11.322] [LOG]   Initializing new module helper ...
                                        [2025-05-03 17:00:11.322] [LOG]   Module helper loaded: MMM-PublicTransportHafas
                                        [2025-05-03 17:00:11.518] [LOG]   Initializing new module helper ...
                                        [2025-05-03 17:00:11.518] [LOG]   Module helper loaded: MMM-RNV
                                        [2025-05-03 17:00:11.519] [LOG]   Initializing new module helper ...
                                        [2025-05-03 17:00:11.519] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.31.0
                                        [2025-05-03 17:00:11.519] [LOG]   Version is ok!
                                        [2025-05-03 17:00:11.519] [LOG]   Module helper loaded: MMM-Fuel
                                        [2025-05-03 17:00:11.595] [LOG]   Initializing new module helper ...
                                        [2025-05-03 17:00:11.596] [LOG]   Module helper loaded: MMM-Remote-Control
                                        [2025-05-03 17:00:11.633] [LOG]   Initializing new module helper ...
                                        [2025-05-03 17:00:11.633] [LOG]   Module helper loaded: newsfeed
                                        [2025-05-03 17:00:11.633] [LOG]   All module helpers loaded.
                                        [2025-05-03 17:00:11.638] [LOG]   Starting server on port 8090 ...
                                        [2025-05-03 17:00:11.639] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                        [2025-05-03 17:00:11.649] [LOG]   Server started ...
                                        [2025-05-03 17:00:11.650] [LOG]   Connecting socket for: updatenotification
                                        [2025-05-03 17:00:11.650] [LOG]   Starting module helper: updatenotification
                                        [2025-05-03 17:00:11.650] [LOG]   Connecting socket for: calendar
                                        [2025-05-03 17:00:11.651] [LOG]   Starting node helper for: calendar
                                        [2025-05-03 17:00:11.651] [LOG]   Connecting socket for: netatmo
                                        [2025-05-03 17:00:11.651] [LOG]   Netatmo helper started ...
                                        [2025-05-03 17:00:11.651] [LOG]   Connecting socket for: MMM-ApothekenNotdienst
                                        [2025-05-03 17:00:11.652] [LOG]   Starting module helper: MMM-ApothekenNotdienst
                                        [2025-05-03 17:00:11.652] [LOG]   Connecting socket for: MMM-ioBroker
                                        [2025-05-03 17:00:11.652] [LOG]   Connecting socket for: MMM-PublicTransportHafas
                                        [2025-05-03 17:00:11.652] [LOG]   Connecting socket for: MMM-RNV
                                        [2025-05-03 17:00:11.705] [LOG]   Connecting socket for: MMM-Fuel
                                        [2025-05-03 17:00:11.705] [LOG]   Starting module helper: MMM-Fuel
                                        [2025-05-03 17:00:11.705] [LOG]   Connecting socket for: MMM-Remote-Control
                                        [2025-05-03 17:00:11.706] [LOG]   Starting node helper for: MMM-Remote-Control
                                        [2025-05-03 17:00:11.708] [LOG]   Connecting socket for: newsfeed
                                        [2025-05-03 17:00:11.708] [LOG]   Starting node helper for: newsfeed
                                        [2025-05-03 17:00:11.708] [LOG]   Sockets connected & modules started ...
                                        [2025-05-03 17:00:11.709] [INFO]
                                        >>>   Ready to go! Please point your browser to: http://0.0.0.0:8090   <<<
                                        [2025-05-03 17:00:11.808] [INFO]  System information:
                                        I have changed it like this under Putty…
                                        then press the Ctrl key and C… but then I still have to enter IP:8080 again to display the MM…with IP:8090 it doesn’t work - network overflow
                                        All other modules are shown correctly, but Netatmo doesent shown :-( what a f…
                                        2 day ist gos good
                                          sdetweil @kusselin
                                          @kusselin SOOOO much fun!! i do not know. and cannot debug it here
                                          • kusselinK
                                            kusselin @sdetweil
                                            Ok, but it looks good now, doesn’t it?
                                            That means it’s the module again.
                                            Maybe someone here with Netatmo running will see this?
                                            Thanks and greetings
