    Netatmo module will not shown
    40 Posts 5 Posters 7.3k Views 5 Watching
      sdetweil @kusselin
      @kusselin need to see the logs again
      always 1st place to look
      kusselinK 1 Reply Last reply Reply Quote 0
      • kusselinK Offline
        kusselin @sdetweil
        Hi sam, look here again…
        verbose cli /usr/bin/node /usr/bin/npm
        1 info using npm@10.9.2
        2 info using node@v22.15.0
        3 silly config load:file:/usr/lib/node_modules/npm/npmrc
        4 silly config load:file:/opt/magicmirror/.npmrc
        5 silly config load:file:/root/.npmrc
        6 silly config load:file:/usr/etc/npmrc
        7 verbose title npm run seerver
        8 verbose argv "run" "seerver"
        9 verbose logfile logs-max:10 dir:/root/.npm/_logs/2025-05-03T14_24_21_403Z-
        10 verbose logfile /root/.npm/_logs/2025-05-03T14_24_21_403Z-debug-0.log
        11 silly logfile start cleaning logs, removing 1 files
        12 silly logfile done cleaning log files
        13 verbose stack Error: Missing script: "seerver"
        13 verbose stack
        13 verbose stack Did you mean this?
        13 verbose stack   npm run server # run the "server" package script
        13 verbose stack
        13 verbose stack To see a list of scripts, run:
        13 verbose stack     at #run (/usr/lib/node_modules/npm/lib/commands/run-script.js:111:13)
        13 verbose stack     at async RunScript.exec (/usr/lib/node_modules/npm/lib/commands/run-script.js:40:7)
        13 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
        13 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5)
        14 error Missing script: "seerver"
        14 error
        14 error Did you mean this?
        14 error   npm run server # run the "server" package script
        14 error
        14 error To see a list of scripts, run:
        14 error   npm run
        15 verbose cwd /opt/magicmirror
        16 verbose os Linux 6.8.12-8-pve
        17 verbose node v22.15.0
        18 verbose npm  v10.9.2
        19 verbose exit 1
        20 verbose code 1
        21 error A complete log of this run can be found in: /root/.npm/_logs/2025-05-03T14_24_21_403Z-debug-0.log
        and the latest Log:
        0 verbose cli /usr/bin/node /usr/bin/npm
        7 verbose title npm run server
        8 verbose argv "run" "server"
        9 verbose logfile logs-max:10 dir:/root/.npm/_logs/2025-05-03T14_24_50_844Z-
        10 verbose logfile /root/.npm/_logs/2025-05-03T14_24_50_844Z-debug-0.log
        13 verbose cwd /opt/magicmirror
        14 verbose os Linux 6.8.12-8-pve
        15 verbose node v22.15.0
        16 verbose npm  v10.9.2
        17 verbose exit 0
        18 info ok
        here is the info wenn i go into /opt/magicmirror/ and “npm run server”:
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Sat May  3 16:23:40 2025 from 192.168.200.219
        MagicMirror LXC Container
            🌐   Provided by: community-scripts ORG | GitHub: https://github.com/community-scripts/ProxmoxVE
            🖥️   OS: Debian GNU/Linux - Version: 12
            🏠   Hostname: magicmirror-live
            💡   IP Address: 192.168.200.74
        root@magicmirror-live:~# cd /opt/magicmirror
        root@magicmirror-live:/opt/magicmirror# npm run server
        > magicmirror@2.31.0 server
        > node ./serveronly
        [2025-05-03 16:40:49.450] [LOG]   Starting MagicMirror: v2.31.0
        [2025-05-03 16:40:49.469] [LOG]   Loading config ...
        [2025-05-03 16:40:49.470] [LOG]   config template file not exists, no envsubst
        [2025-05-03 16:40:49.876] [INFO]  Checking config file /opt/magicmirror/config/config.js ...
        [2025-05-03 16:40:49.930] [INFO]  Your configuration file doesn't contain syntax errors :)
        [2025-05-03 16:40:49.931] [INFO]  Checking modules structure configuration ...
        [2025-05-03 16:40:50.003] [INFO]  Your modules structure configuration doesn't contain errors :)
        [2025-05-03 16:40:50.519] [LOG]   Loading module helpers ...
        [2025-05-03 16:40:50.528] [LOG]   No helper found for module: alert.
        [2025-05-03 16:40:50.551] [LOG]   Initializing new module helper ...
        [2025-05-03 16:40:50.555] [LOG]   Module helper loaded: updatenotification
        [2025-05-03 16:40:50.557] [LOG]   No helper found for module: clock.
        [2025-05-03 16:40:50.934] [LOG]   Initializing new module helper ...
        [2025-05-03 16:40:50.936] [LOG]   Module helper loaded: calendar
        [2025-05-03 16:40:50.941] [LOG]   No helper found for module: compliments.
        [2025-05-03 16:40:50.943] [LOG]   No helper found for module: MMM-OpenmapWeather.
        [2025-05-03 16:40:50.950] [LOG]   Initializing new module helper ...
        [2025-05-03 16:40:50.952] [LOG]   Module helper loaded: netatmo
        [2025-05-03 16:40:50.954] [WARN]  No /opt/magicmirror/modules/MMM-OpenWeatherForecast/MMM-OpenWeatherForecast.js found for module: MMM-OpenWeatherForecast.
        [2025-05-03 16:40:50.955] [LOG]   No helper found for module: MMM-OpenWeatherForecast.
        [2025-05-03 16:40:50.955] [LOG]   No helper found for module: MMM-Blitzer.
        [2025-05-03 16:40:50.958] [LOG]   Initializing new module helper ...
        [2025-05-03 16:40:50.960] [LOG]   Module helper loaded: MMM-ApothekenNotdienst
        [2025-05-03 16:40:50.962] [LOG]   Initializing new module helper ...
        [2025-05-03 16:40:50.965] [LOG]   Module helper loaded: MMM-ioBroker
        [2025-05-03 16:40:50.965] [LOG]   No helper found for module: MMM-Carousel.
        [2025-05-03 16:40:51.040] [LOG]   Initializing new module helper ...
        [2025-05-03 16:40:51.040] [LOG]   Module helper loaded: MMM-PublicTransportHafas
        [2025-05-03 16:40:51.480] [LOG]   Initializing new module helper ...
        [2025-05-03 16:40:51.480] [LOG]   Module helper loaded: MMM-RNV
        [2025-05-03 16:40:51.482] [LOG]   Initializing new module helper ...
        [2025-05-03 16:40:51.482] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.31.0
        [2025-05-03 16:40:51.482] [LOG]   Version is ok!
        [2025-05-03 16:40:51.483] [LOG]   Module helper loaded: MMM-Fuel
        [2025-05-03 16:40:51.591] [LOG]   Initializing new module helper ...
        [2025-05-03 16:40:51.591] [LOG]   Module helper loaded: MMM-Remote-Control
        [2025-05-03 16:40:51.658] [LOG]   Initializing new module helper ...
        [2025-05-03 16:40:51.659] [LOG]   Module helper loaded: newsfeed
        [2025-05-03 16:40:51.659] [LOG]   All module helpers loaded.
        [2025-05-03 16:40:51.663] [LOG]   Starting server on port 8080 ...
        [2025-05-03 16:40:51.664] [WARN]  You're using a full whitelist configuration to allow for all IPs
        [2025-05-03 16:40:51.673] [ERROR] Whoops! There was an uncaught exception...
        [2025-05-03 16:40:51.673] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
            at Server.setupListenHandle [as _listen2] (node:net:1939:16)
            at listenInCluster (node:net:1996:12)
            at node:net:2205:7
            at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
          code: 'EADDRINUSE',
          errno: -98,
          syscall: 'listen',
          address: '0.0.0.0',
          port: 8080
        [2025-05-03 16:40:51.673] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2025-05-03 16:40:51.673] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
        [2025-05-03 16:40:51.783] [INFO]  System information:
        ### SYSTEM:   manufacturer: ; model: ; virtual: false
        ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: x64; kernel: 6.8.12-8-pve
        ### VERSIONS: electron: undefined; used node: 22.15.0; installed node: 22.15.0; npm: 10.9.2; pm2: 5.4.3
        ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
        her my Config from MM:
        /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
              module: 'netatmo',
              position: 'bottom_left',
                clientId: '123456,
                clientSecret: '1234',
                refresh_token: '1234',
                moduleOrder: [
                  'Aussenmodul',
                  'Regenmesser',
                  'Windmesser',
                  'Wohnen'
                updateInterval: 6,
                design: 'bubbles',
                horizontal: false,
                showStationName: false,
                showModuleNameOnTop: true,
                fontClassModuleName: 'small'
        what I don’t understand either…because of the remote control module the config looks completely different than normal…but I think that has nothing to do with Netatmo…right?
        I would be really grateful for your help…
        Greetings
          sdetweil @kusselin
          @kusselin the ‘already in use’ is because the container is running MagicMirror as a system service
          you could use a different port for the test
          export MM_PORT=8090
          npm run server
          now you have two instances running
          one on 8080 and one on 8090
          ctrl-c to stop the one on 8090
            sdetweil @kusselin
            @kusselin config format, yes RemoteControl, like my MMM-Config rewrites the config file and doesnt see the comments
            • kusselinK Offline
              kusselin @sdetweil
              @sdetweil said in Netatmo module will not shown:
              Hello Sam,
              If I enter this via putty in the path /opt/magicmirror, it will be there:
              export MM_PORT=8090
              npm run server
              root@magicmirror-live:/opt/magicmirror# export MM_PORT=8090
              > node ./serveronly
              [2025-05-03 17:00:10.347] [LOG]   Starting MagicMirror: v2.31.0
              [2025-05-03 17:00:10.361] [LOG]   Loading config ...
              [2025-05-03 17:00:10.362] [LOG]   config template file not exists, no envsubst
              [2025-05-03 17:00:10.643] [INFO]  Checking config file /opt/magicmirror/config/config.js ...
              [2025-05-03 17:00:10.698] [INFO]  Your configuration file doesn't contain syntax errors :)
              [2025-05-03 17:00:10.698] [INFO]  Checking modules structure configuration ...
              [2025-05-03 17:00:10.755] [INFO]  Your modules structure configuration doesn't contain errors :)
              [2025-05-03 17:00:11.073] [LOG]   Loading module helpers ...
              [2025-05-03 17:00:11.076] [LOG]   No helper found for module: alert.
              [2025-05-03 17:00:11.094] [LOG]   Initializing new module helper ...
              [2025-05-03 17:00:11.094] [LOG]   Module helper loaded: updatenotification
              [2025-05-03 17:00:11.094] [LOG]   No helper found for module: clock.
              [2025-05-03 17:00:11.267] [LOG]   Initializing new module helper ...
              [2025-05-03 17:00:11.269] [LOG]   Module helper loaded: calendar
              [2025-05-03 17:00:11.271] [LOG]   No helper found for module: compliments.
              [2025-05-03 17:00:11.271] [LOG]   No helper found for module: MMM-OpenmapWeather.
              [2025-05-03 17:00:11.272] [LOG]   Initializing new module helper ...
              [2025-05-03 17:00:11.272] [LOG]   Module helper loaded: netatmo
              [2025-05-03 17:00:11.276] [WARN]  No /opt/magicmirror/modules/MMM-OpenWeatherForecast/MMM-OpenWeatherForecast.js found for module: MMM-OpenWeatherForecast.
              [2025-05-03 17:00:11.276] [LOG]   No helper found for module: MMM-OpenWeatherForecast.
              [2025-05-03 17:00:11.276] [LOG]   No helper found for module: MMM-Blitzer.
              [2025-05-03 17:00:11.277] [LOG]   Initializing new module helper ...
              [2025-05-03 17:00:11.277] [LOG]   Module helper loaded: MMM-ApothekenNotdienst
              [2025-05-03 17:00:11.278] [LOG]   Module helper loaded: MMM-ioBroker
              [2025-05-03 17:00:11.278] [LOG]   No helper found for module: MMM-Carousel.
              [2025-05-03 17:00:11.322] [LOG]   Initializing new module helper ...
              [2025-05-03 17:00:11.322] [LOG]   Module helper loaded: MMM-PublicTransportHafas
              [2025-05-03 17:00:11.518] [LOG]   Initializing new module helper ...
              [2025-05-03 17:00:11.518] [LOG]   Module helper loaded: MMM-RNV
              [2025-05-03 17:00:11.519] [LOG]   Initializing new module helper ...
              [2025-05-03 17:00:11.519] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.31.0
              [2025-05-03 17:00:11.519] [LOG]   Version is ok!
              [2025-05-03 17:00:11.519] [LOG]   Module helper loaded: MMM-Fuel
              [2025-05-03 17:00:11.595] [LOG]   Initializing new module helper ...
              [2025-05-03 17:00:11.596] [LOG]   Module helper loaded: MMM-Remote-Control
              [2025-05-03 17:00:11.633] [LOG]   Initializing new module helper ...
              [2025-05-03 17:00:11.633] [LOG]   Module helper loaded: newsfeed
              [2025-05-03 17:00:11.633] [LOG]   All module helpers loaded.
              [2025-05-03 17:00:11.638] [LOG]   Starting server on port 8090 ...
              [2025-05-03 17:00:11.639] [WARN]  You're using a full whitelist configuration to allow for all IPs
              [2025-05-03 17:00:11.649] [LOG]   Server started ...
              [2025-05-03 17:00:11.650] [LOG]   Connecting socket for: updatenotification
              [2025-05-03 17:00:11.650] [LOG]   Starting module helper: updatenotification
              [2025-05-03 17:00:11.650] [LOG]   Connecting socket for: calendar
              [2025-05-03 17:00:11.651] [LOG]   Starting node helper for: calendar
              [2025-05-03 17:00:11.651] [LOG]   Connecting socket for: netatmo
              [2025-05-03 17:00:11.651] [LOG]   Netatmo helper started ...
              [2025-05-03 17:00:11.651] [LOG]   Connecting socket for: MMM-ApothekenNotdienst
              [2025-05-03 17:00:11.652] [LOG]   Starting module helper: MMM-ApothekenNotdienst
              [2025-05-03 17:00:11.652] [LOG]   Connecting socket for: MMM-ioBroker
              [2025-05-03 17:00:11.652] [LOG]   Connecting socket for: MMM-PublicTransportHafas
              [2025-05-03 17:00:11.652] [LOG]   Connecting socket for: MMM-RNV
              [2025-05-03 17:00:11.705] [LOG]   Connecting socket for: MMM-Fuel
              [2025-05-03 17:00:11.705] [LOG]   Starting module helper: MMM-Fuel
              [2025-05-03 17:00:11.705] [LOG]   Connecting socket for: MMM-Remote-Control
              [2025-05-03 17:00:11.706] [LOG]   Starting node helper for: MMM-Remote-Control
              [2025-05-03 17:00:11.708] [LOG]   Connecting socket for: newsfeed
              [2025-05-03 17:00:11.708] [LOG]   Starting node helper for: newsfeed
              [2025-05-03 17:00:11.708] [LOG]   Sockets connected & modules started ...
              [2025-05-03 17:00:11.709] [INFO]
              >>>   Ready to go! Please point your browser to: http://0.0.0.0:8090   <<<
              [2025-05-03 17:00:11.808] [INFO]  System information:
              I have changed it like this under Putty…
              then press the Ctrl key and C… but then I still have to enter IP:8080 again to display the MM…with IP:8090 it doesn’t work - network overflow
              All other modules are shown correctly, but Netatmo doesent shown :-( what a f…
              2 day ist gos good
                sdetweil @kusselin
                @kusselin SOOOO much fun!! i do not know. and cannot debug it here
                • kusselinK Offline
                  kusselin @sdetweil
                  Ok, but it looks good now, doesn’t it?
                  That means it’s the module again.
                  Maybe someone here with Netatmo running will see this?
                  Thanks and greetings
                    sdetweil @kusselin
                    @kusselin yes, dont see anything indicating the problem. all looks good
                    • kusselinK Offline
                      kusselin @sdetweil
                      module: “netatmo”,
                      position: “bottom_left”,
                      order: “*”,
                      animateIn: “None”,
                      animateOut: “None”,
                      clientId: ‘1234567’, // your app id
                      clientSecret: ‘1212123’, // your app secret
                      refresh_token: ‘3223232’, // your generated refresh token
                      mockData: true
                      disabled: false,
                      hiddenOnStartup: false,
                      configDeepMerge: false
                      I have now copied your config from here into the config again and it no longer works… can you please try it again with the mockData: true and take a picture
                      thanks
                        sdetweil @kusselin
                        @kusselin will do, it took a few minutes , i had given up and came back and it was displaying
                        • 3 / 4
