    Netatmo module will not shown
    40 Posts 5 Posters 6.9k Views 5 Watching
    • kusselinK Offline
      kusselin
      so I’ll contact you again…es is displayed…perfekr…I took the template from SAM here and then adapted it again accordingly…now it works…thanks to everyone and especially once again to SAM …;-)
      • LusbuebL Offline
        Lusbueb @kusselin
        @kusselin
        In your configuration, I’m missing the entry modulOrder. This entry was essential for me! I initially used the default name until I realized that it only works if the module name is stored exactly as you configured it in the web-app (https://auth.netatmo.com/de-de/access/login):
        my config:
        		module: 'netatmo',
        		position: 'middle_center', // the location where the module should be displayed
        			clientId: '*myID*', // your app id
        			clientSecret: '*mysecret*', // your app secret
        			refresh_token: *'mytoken*', // your generated refresh token
        			moduleOrder: ["Outdoor","Regen","Wind","Schlafzimmer","Wohnzimmer"], //take same names from web-app!
        			updateInterval: 6, // every 3 minutes, refresh interval on netatmo is 10 minutes
        			animationSpeed: 1000,
        			design: 'bubbles', // classic or bubbles
        			horizontal: false,
        			lastMessageThreshold: 600, // in seconds (10 minutes)
        			showLastMessage: true,
        			showBattery: true,
        			showRadio: true,
        			showWiFi: true,
        			showTrend: true,
        			showMeasurementIcon: true,
        			showMeasurementLabel: true,
        			showStationName: false,
        			showModuleNameOnTop: true,
        			fontClassModuleName: 'small', // xsmall, small, medium, large, xlarge
        			fontClassPrimary: 'large',
        			fontClassSecondary: 'xsmall',
        			fontClassMeasurement: 'xsmall',
        			thresholdCO2Average: 800,
        			thresholdCO2Bad: 1800,
        			mockData: false,
        https://home.netatmo.com/control/dashboard
        MM:
        kusselinK 1 Reply Last reply Reply Quote 1
          sdetweil @kusselin
          @kusselin congratulations!!! i’m glad you got it working
          • kusselinK Offline
            kusselin @Lusbueb
            @Lusbueb said in Netatmo module will not shown:
            @kusselin
            my config:
            		module: 'netatmo',
            			horizontal: false,
            			showBattery: true,
            			showRadio: true,
            			showWiFi: true,
            			showTrend: true,
            			mockData: false,
            MM:
            Thanks s lot for your config…i changed it and now ist good and the netatmo Modul is running very well
            • kusselinK Offline
              kusselin
              Hello everyone, netatmo is no longer working today :-(
              I haven’t changed anything
                sdetweil @kusselin
                @kusselin need to see the logs again
                always 1st place to look
                kusselinK 1 Reply Last reply Reply Quote 0
                • kusselinK Offline
                  kusselin @sdetweil
                  Hi sam, look here again…
                  verbose cli /usr/bin/node /usr/bin/npm
                  1 info using npm@10.9.2
                  2 info using node@v22.15.0
                  3 silly config load:file:/usr/lib/node_modules/npm/npmrc
                  4 silly config load:file:/opt/magicmirror/.npmrc
                  5 silly config load:file:/root/.npmrc
                  6 silly config load:file:/usr/etc/npmrc
                  7 verbose title npm run seerver
                  8 verbose argv "run" "seerver"
                  9 verbose logfile logs-max:10 dir:/root/.npm/_logs/2025-05-03T14_24_21_403Z-
                  10 verbose logfile /root/.npm/_logs/2025-05-03T14_24_21_403Z-debug-0.log
                  11 silly logfile start cleaning logs, removing 1 files
                  12 silly logfile done cleaning log files
                  13 verbose stack Error: Missing script: "seerver"
                  13 verbose stack
                  13 verbose stack Did you mean this?
                  13 verbose stack   npm run server # run the "server" package script
                  13 verbose stack
                  13 verbose stack To see a list of scripts, run:
                  13 verbose stack     at #run (/usr/lib/node_modules/npm/lib/commands/run-script.js:111:13)
                  13 verbose stack     at async RunScript.exec (/usr/lib/node_modules/npm/lib/commands/run-script.js:40:7)
                  13 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
                  13 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5)
                  14 error Missing script: "seerver"
                  14 error
                  14 error Did you mean this?
                  14 error   npm run server # run the "server" package script
                  14 error
                  14 error To see a list of scripts, run:
                  14 error   npm run
                  15 verbose cwd /opt/magicmirror
                  16 verbose os Linux 6.8.12-8-pve
                  17 verbose node v22.15.0
                  18 verbose npm  v10.9.2
                  19 verbose exit 1
                  20 verbose code 1
                  21 error A complete log of this run can be found in: /root/.npm/_logs/2025-05-03T14_24_21_403Z-debug-0.log
                  and the latest Log:
                  0 verbose cli /usr/bin/node /usr/bin/npm
                  7 verbose title npm run server
                  8 verbose argv "run" "server"
                  9 verbose logfile logs-max:10 dir:/root/.npm/_logs/2025-05-03T14_24_50_844Z-
                  10 verbose logfile /root/.npm/_logs/2025-05-03T14_24_50_844Z-debug-0.log
                  13 verbose cwd /opt/magicmirror
                  14 verbose os Linux 6.8.12-8-pve
                  15 verbose node v22.15.0
                  16 verbose npm  v10.9.2
                  17 verbose exit 0
                  18 info ok
                  here is the info wenn i go into /opt/magicmirror/ and “npm run server”:
                  The programs included with the Debian GNU/Linux system are free software;
                  the exact distribution terms for each program are described in the
                  individual files in /usr/share/doc/*/copyright.
                  Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                  permitted by applicable law.
                  Last login: Sat May  3 16:23:40 2025 from 192.168.200.219
                  MagicMirror LXC Container
                      🌐   Provided by: community-scripts ORG | GitHub: https://github.com/community-scripts/ProxmoxVE
                      🖥️   OS: Debian GNU/Linux - Version: 12
                      🏠   Hostname: magicmirror-live
                      💡   IP Address: 192.168.200.74
                  root@magicmirror-live:~# cd /opt/magicmirror
                  root@magicmirror-live:/opt/magicmirror# npm run server
                  > magicmirror@2.31.0 server
                  > node ./serveronly
                  [2025-05-03 16:40:49.450] [LOG]   Starting MagicMirror: v2.31.0
                  [2025-05-03 16:40:49.469] [LOG]   Loading config ...
                  [2025-05-03 16:40:49.470] [LOG]   config template file not exists, no envsubst
                  [2025-05-03 16:40:49.876] [INFO]  Checking config file /opt/magicmirror/config/config.js ...
                  [2025-05-03 16:40:49.930] [INFO]  Your configuration file doesn't contain syntax errors :)
                  [2025-05-03 16:40:49.931] [INFO]  Checking modules structure configuration ...
                  [2025-05-03 16:40:50.003] [INFO]  Your modules structure configuration doesn't contain errors :)
                  [2025-05-03 16:40:50.519] [LOG]   Loading module helpers ...
                  [2025-05-03 16:40:50.528] [LOG]   No helper found for module: alert.
                  [2025-05-03 16:40:50.551] [LOG]   Initializing new module helper ...
                  [2025-05-03 16:40:50.555] [LOG]   Module helper loaded: updatenotification
                  [2025-05-03 16:40:50.557] [LOG]   No helper found for module: clock.
                  [2025-05-03 16:40:50.934] [LOG]   Initializing new module helper ...
                  [2025-05-03 16:40:50.936] [LOG]   Module helper loaded: calendar
                  [2025-05-03 16:40:50.941] [LOG]   No helper found for module: compliments.
                  [2025-05-03 16:40:50.943] [LOG]   No helper found for module: MMM-OpenmapWeather.
                  [2025-05-03 16:40:50.950] [LOG]   Initializing new module helper ...
                  [2025-05-03 16:40:50.952] [LOG]   Module helper loaded: netatmo
                  [2025-05-03 16:40:50.954] [WARN]  No /opt/magicmirror/modules/MMM-OpenWeatherForecast/MMM-OpenWeatherForecast.js found for module: MMM-OpenWeatherForecast.
                  [2025-05-03 16:40:50.955] [LOG]   No helper found for module: MMM-OpenWeatherForecast.
                  [2025-05-03 16:40:50.955] [LOG]   No helper found for module: MMM-Blitzer.
                  [2025-05-03 16:40:50.958] [LOG]   Initializing new module helper ...
                  [2025-05-03 16:40:50.960] [LOG]   Module helper loaded: MMM-ApothekenNotdienst
                  [2025-05-03 16:40:50.962] [LOG]   Initializing new module helper ...
                  [2025-05-03 16:40:50.965] [LOG]   Module helper loaded: MMM-ioBroker
                  [2025-05-03 16:40:50.965] [LOG]   No helper found for module: MMM-Carousel.
                  [2025-05-03 16:40:51.040] [LOG]   Initializing new module helper ...
                  [2025-05-03 16:40:51.040] [LOG]   Module helper loaded: MMM-PublicTransportHafas
                  [2025-05-03 16:40:51.480] [LOG]   Initializing new module helper ...
                  [2025-05-03 16:40:51.480] [LOG]   Module helper loaded: MMM-RNV
                  [2025-05-03 16:40:51.482] [LOG]   Initializing new module helper ...
                  [2025-05-03 16:40:51.482] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.31.0
                  [2025-05-03 16:40:51.482] [LOG]   Version is ok!
                  [2025-05-03 16:40:51.483] [LOG]   Module helper loaded: MMM-Fuel
                  [2025-05-03 16:40:51.591] [LOG]   Initializing new module helper ...
                  [2025-05-03 16:40:51.591] [LOG]   Module helper loaded: MMM-Remote-Control
                  [2025-05-03 16:40:51.658] [LOG]   Initializing new module helper ...
                  [2025-05-03 16:40:51.659] [LOG]   Module helper loaded: newsfeed
                  [2025-05-03 16:40:51.659] [LOG]   All module helpers loaded.
                  [2025-05-03 16:40:51.663] [LOG]   Starting server on port 8080 ...
                  [2025-05-03 16:40:51.664] [WARN]  You're using a full whitelist configuration to allow for all IPs
                  [2025-05-03 16:40:51.673] [ERROR] Whoops! There was an uncaught exception...
                  [2025-05-03 16:40:51.673] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                      at Server.setupListenHandle [as _listen2] (node:net:1939:16)
                      at listenInCluster (node:net:1996:12)
                      at node:net:2205:7
                      at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
                    code: 'EADDRINUSE',
                    errno: -98,
                    syscall: 'listen',
                    address: '0.0.0.0',
                    port: 8080
                  [2025-05-03 16:40:51.673] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2025-05-03 16:40:51.673] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                  [2025-05-03 16:40:51.783] [INFO]  System information:
                  ### SYSTEM:   manufacturer: ; model: ; virtual: false
                  ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: x64; kernel: 6.8.12-8-pve
                  ### VERSIONS: electron: undefined; used node: 22.15.0; installed node: 22.15.0; npm: 10.9.2; pm2: 5.4.3
                  ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                  her my Config from MM:
                  /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                        module: 'netatmo',
                        position: 'bottom_left',
                          clientId: '123456,
                          clientSecret: '1234',
                          refresh_token: '1234',
                          moduleOrder: [
                            'Aussenmodul',
                            'Regenmesser',
                            'Windmesser',
                            'Wohnen'
                          updateInterval: 6,
                          design: 'bubbles',
                          horizontal: false,
                  what I don’t understand either…because of the remote control module the config looks completely different than normal…but I think that has nothing to do with Netatmo…right?
                  I would be really grateful for your help…
                  Greetings
                    sdetweil @kusselin
                    @kusselin the ‘already in use’ is because the container is running MagicMirror as a system service
                    you could use a different port for the test
                    export MM_PORT=8090
                    npm run server
                    now you have two instances running
                    one on 8080 and one on 8090
                    ctrl-c to stop the one on 8090
                      sdetweil @kusselin
                      @kusselin config format, yes RemoteControl, like my MMM-Config rewrites the config file and doesnt see the comments
                      • kusselinK Offline
                        kusselin @sdetweil
                        @sdetweil said in Netatmo module will not shown:
                        Hello Sam,
                        If I enter this via putty in the path /opt/magicmirror, it will be there:
                        export MM_PORT=8090
                        npm run server
                        root@magicmirror-live:/opt/magicmirror# export MM_PORT=8090
                        > node ./serveronly
                        [2025-05-03 17:00:10.347] [LOG]   Starting MagicMirror: v2.31.0
                        [2025-05-03 17:00:10.361] [LOG]   Loading config ...
                        [2025-05-03 17:00:10.362] [LOG]   config template file not exists, no envsubst
                        [2025-05-03 17:00:10.643] [INFO]  Checking config file /opt/magicmirror/config/config.js ...
                        [2025-05-03 17:00:10.698] [INFO]  Your configuration file doesn't contain syntax errors :)
                        [2025-05-03 17:00:10.698] [INFO]  Checking modules structure configuration ...
                        [2025-05-03 17:00:10.755] [INFO]  Your modules structure configuration doesn't contain errors :)
                        [2025-05-03 17:00:11.073] [LOG]   Loading module helpers ...
                        [2025-05-03 17:00:11.076] [LOG]   No helper found for module: alert.
                        [2025-05-03 17:00:11.094] [LOG]   Initializing new module helper ...
                        [2025-05-03 17:00:11.094] [LOG]   Module helper loaded: updatenotification
                        [2025-05-03 17:00:11.094] [LOG]   No helper found for module: clock.
                        [2025-05-03 17:00:11.267] [LOG]   Initializing new module helper ...
                        [2025-05-03 17:00:11.269] [LOG]   Module helper loaded: calendar
                        [2025-05-03 17:00:11.271] [LOG]   No helper found for module: compliments.
                        [2025-05-03 17:00:11.271] [LOG]   No helper found for module: MMM-OpenmapWeather.
                        [2025-05-03 17:00:11.272] [LOG]   Initializing new module helper ...
                        [2025-05-03 17:00:11.272] [LOG]   Module helper loaded: netatmo
                        [2025-05-03 17:00:11.276] [WARN]  No /opt/magicmirror/modules/MMM-OpenWeatherForecast/MMM-OpenWeatherForecast.js found for module: MMM-OpenWeatherForecast.
                        [2025-05-03 17:00:11.276] [LOG]   No helper found for module: MMM-OpenWeatherForecast.
                        [2025-05-03 17:00:11.276] [LOG]   No helper found for module: MMM-Blitzer.
                        [2025-05-03 17:00:11.277] [LOG]   Initializing new module helper ...
                        [2025-05-03 17:00:11.277] [LOG]   Module helper loaded: MMM-ApothekenNotdienst
                        [2025-05-03 17:00:11.278] [LOG]   Module helper loaded: MMM-ioBroker
                        [2025-05-03 17:00:11.278] [LOG]   No helper found for module: MMM-Carousel.
                        [2025-05-03 17:00:11.322] [LOG]   Initializing new module helper ...
                        [2025-05-03 17:00:11.322] [LOG]   Module helper loaded: MMM-PublicTransportHafas
                        [2025-05-03 17:00:11.518] [LOG]   Initializing new module helper ...
                        [2025-05-03 17:00:11.518] [LOG]   Module helper loaded: MMM-RNV
                        [2025-05-03 17:00:11.519] [LOG]   Initializing new module helper ...
                        [2025-05-03 17:00:11.519] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.31.0
                        [2025-05-03 17:00:11.519] [LOG]   Version is ok!
                        [2025-05-03 17:00:11.519] [LOG]   Module helper loaded: MMM-Fuel
                        [2025-05-03 17:00:11.595] [LOG]   Initializing new module helper ...
                        [2025-05-03 17:00:11.596] [LOG]   Module helper loaded: MMM-Remote-Control
                        [2025-05-03 17:00:11.633] [LOG]   Initializing new module helper ...
                        [2025-05-03 17:00:11.633] [LOG]   Module helper loaded: newsfeed
                        [2025-05-03 17:00:11.633] [LOG]   All module helpers loaded.
                        [2025-05-03 17:00:11.638] [LOG]   Starting server on port 8090 ...
                        [2025-05-03 17:00:11.639] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        [2025-05-03 17:00:11.649] [LOG]   Server started ...
                        [2025-05-03 17:00:11.650] [LOG]   Connecting socket for: updatenotification
                        [2025-05-03 17:00:11.650] [LOG]   Starting module helper: updatenotification
                        [2025-05-03 17:00:11.650] [LOG]   Connecting socket for: calendar
                        [2025-05-03 17:00:11.651] [LOG]   Starting node helper for: calendar
                        [2025-05-03 17:00:11.651] [LOG]   Connecting socket for: netatmo
                        [2025-05-03 17:00:11.651] [LOG]   Netatmo helper started ...
                        [2025-05-03 17:00:11.651] [LOG]   Connecting socket for: MMM-ApothekenNotdienst
                        [2025-05-03 17:00:11.652] [LOG]   Starting module helper: MMM-ApothekenNotdienst
                        [2025-05-03 17:00:11.652] [LOG]   Connecting socket for: MMM-ioBroker
                        [2025-05-03 17:00:11.652] [LOG]   Connecting socket for: MMM-PublicTransportHafas
                        [2025-05-03 17:00:11.652] [LOG]   Connecting socket for: MMM-RNV
                        [2025-05-03 17:00:11.705] [LOG]   Connecting socket for: MMM-Fuel
                        [2025-05-03 17:00:11.705] [LOG]   Starting module helper: MMM-Fuel
                        [2025-05-03 17:00:11.705] [LOG]   Connecting socket for: MMM-Remote-Control
                        [2025-05-03 17:00:11.706] [LOG]   Starting node helper for: MMM-Remote-Control
                        [2025-05-03 17:00:11.708] [LOG]   Connecting socket for: newsfeed
                        [2025-05-03 17:00:11.708] [LOG]   Starting node helper for: newsfeed
                        [2025-05-03 17:00:11.708] [LOG]   Sockets connected & modules started ...
                        [2025-05-03 17:00:11.709] [INFO]
                        >>>   Ready to go! Please point your browser to: http://0.0.0.0:8090   <<<
                        [2025-05-03 17:00:11.808] [INFO]  System information:
                        I have changed it like this under Putty…
                        then press the Ctrl key and C… but then I still have to enter IP:8080 again to display the MM…with IP:8090 it doesn’t work - network overflow
                        All other modules are shown correctly, but Netatmo doesent shown :-( what a f…
                        2 day ist gos good
                        • 3 / 4
