    MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs
    43 Posts 7 Posters 8.6k Views 7 Watching
    • V Offline
      Volkae @KristjanESPERANTO
      @KristjanESPERANTO
      The same problem on my MM. I did all the updates without any problems but since the last update the module does not work.
      node is v20.19.1
      MM is 2.30.0
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @Volkae
        @Volkae said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
        MM is 2.30.0
        Okay, I can see this when I downgrade to 2.30.0. With 2.31.0 the issue doesn’t appear. That was not the plan, but I’ll adjust requiresVersion accordingly.
        Please update MM and check whether this solves the issue for you 🙂
        S mumblebajM 2 Replies Last reply Reply Quote 0
          sdetweil @KristjanESPERANTO
          @Volkae note that you have to update nodejs again this release
          use my upgrade script it does all the work
          same place as the install script
          • mumblebajM Offline
            mumblebaj Module Developer @KristjanESPERANTO
            @KristjanESPERANTO Not sure if it is advisable to update the modules requiresVersion to the latest MM version. With the issue of older PI’s not able to run the latest version of MM you run the risk of the modules no longer working even if they can still work on older versions of MM. I prefer to keep my version 2 versions behind as they worked on those. Unless your module has specifically been updated with dependencies of the latest MM.
            • P Offline
              p1lspeda
              I can confirm: I have the same issue.
              Updated to latest node and MM version.
              Did a npm -install after updating MM and node. Unfortunately it did not have an effect.
              Any tips ?
              Error message:
              [2025-05-04 20:17:43.557] [ERROR] Error when loading MMM-PublicTransportHafas: require() of ES Module /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs not supported. Instead change the require of /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs to a dynamic import() which is available in all CommonJS modules.
              • V Offline
                Volkae @sdetweil
                I used your upgrade script, update is completed, made an new install from MMM-PublicTransportHafas but it does not work
                  sdetweil @Volkae
                  @Volkae ok, did you do the apply ?
                  do
                  node -v
                  cd ~/MagicMirror
                  grep version package.json
                  MagicMirror version should be 2.31.0
                  V 1 Reply Last reply Reply Quote 1
                    sdetweil @p1lspeda
                    @p1lspeda just fyi, if you use the upgrade script it will npm install all the modules that have a package.json with dependencies after completing the MagicMirror upgrade
                      sdetweil @Volkae
                      @Volkae @p1lspeda @KristjanESPERANTO will have to advise next steps
                        KristjanESPERANTO Module Developer @sdetweil
                        @sdetweil said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                        I need the system information part from the logs. Like this:
                        [2025-01-14 20:05:03.529] [INFO]  System information:
                        ### SYSTEM:    manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
                        ### OS:        platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.1.21-v8+
                        ### VERSIONS:  electron: 31.2.1; used node: 20.15.0; installed node: 22.4.1; npm: 10.8.1; pm2:
                        ### OTHER:     timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                        P V 2 Replies Last reply Reply Quote 0
                        • 2 / 5
