    MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs
    43 Posts 7 Posters 8.5k Views 7 Watching
    • V Offline
      Vulan12354
      Hello together,
      i am new to MagicMirror and the coding.
      After i updated the module MMM-PublicTransportHafas i get the following error message when starting the mirror.
      The modules is not loading anymore.
      [ERROR] Error when loading MMM-PublicTransportHafas: require() of ES Module /home/Fred/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs not supported.
      Instead change the require of /home/Fred/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs to a dynamic import() which is available in all CommonJS modules.
      Maybe someone can help me.
      S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
        sdetweil @Vulan12354
        @KristjanESPERANTO can you help here?
        • KristjanESPERANTOK Offline
          KristjanESPERANTO Module Developer @Vulan12354
          @Vulan12354 I think it is probably because of the node version. Which version are you using? Run node -v to find out. And it would also be interesting to know which MagicMirror version you are using.
          • V Offline
            Volkae @KristjanESPERANTO
            @KristjanESPERANTO
            The same problem on my MM. I did all the updates without any problems but since the last update the module does not work.
            node is v20.19.1
            MM is 2.30.0
              KristjanESPERANTO Module Developer @Volkae
              @Volkae said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
              MM is 2.30.0
              Okay, I can see this when I downgrade to 2.30.0. With 2.31.0 the issue doesn’t appear. That was not the plan, but I’ll adjust requiresVersion accordingly.
              Please update MM and check whether this solves the issue for you 🙂
              S mumblebajM 2 Replies Last reply Reply Quote 0
                sdetweil @KristjanESPERANTO
                @Volkae note that you have to update nodejs again this release
                use my upgrade script it does all the work
                same place as the install script
                • mumblebajM Offline
                  mumblebaj Module Developer @KristjanESPERANTO
                  @KristjanESPERANTO Not sure if it is advisable to update the modules requiresVersion to the latest MM version. With the issue of older PI’s not able to run the latest version of MM you run the risk of the modules no longer working even if they can still work on older versions of MM. I prefer to keep my version 2 versions behind as they worked on those. Unless your module has specifically been updated with dependencies of the latest MM.
                    p1lspeda
                    I can confirm: I have the same issue.
                    Updated to latest node and MM version.
                    Did a npm -install after updating MM and node. Unfortunately it did not have an effect.
                    Any tips ?
                    Error message:
                    [2025-05-04 20:17:43.557] [ERROR] Error when loading MMM-PublicTransportHafas: require() of ES Module /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs not supported. Instead change the require of /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs to a dynamic import() which is available in all CommonJS modules.
                    • V Offline
                      Volkae @sdetweil
                      I used your upgrade script, update is completed, made an new install from MMM-PublicTransportHafas but it does not work
                        sdetweil @Volkae
                        @Volkae ok, did you do the apply ?
                        do
                        node -v
                        grep version package.json
                        MagicMirror version should be 2.31.0
                        V 1 Reply Last reply Reply Quote 1
                        • 1 / 5
