    MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs
    43 Posts 7 Posters 16.3k Views 7 Watching
      sdetweil @Volkae
      @Volkae ok, did you do the apply ?
      do
      node -v
      grep version package.json
      MagicMirror version should be 2.31.0
      V 1 Reply Last reply
        sdetweil @p1lspeda
        @p1lspeda just fyi, if you use the upgrade script it will npm install all the modules that have a package.json with dependencies after completing the MagicMirror upgrade
          sdetweil @Volkae
          @Volkae @p1lspeda @KristjanESPERANTO will have to advise next steps
          KristjanESPERANTOK 1 Reply Last reply
          • KristjanESPERANTOK
            @sdetweil said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
            I need the system information part from the logs. Like this:
            [2025-01-14 20:05:03.529] [INFO]  System information:
            ### SYSTEM:    manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
            ### OS:        platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.1.21-v8+
            ### VERSIONS:  electron: 31.2.1; used node: 20.15.0; installed node: 22.4.1; npm: 10.8.1; pm2:
            ### OTHER:     timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
            P V 2 Replies Last reply
              @KristjanESPERANTO said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
              Here you go
              [2025-05-06 06:46:30.229] [INFO]  System information:
              ### SYSTEM:   manufacturer: ; model: ; virtual: false
              ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-v8
              ### VERSIONS: electron: 32.2.7; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
              P 1 Reply Last reply
              • V
                Volkae @sdetweil
                node -v
                22.14.0
                “version”: “2.30.0”,
                KristjanESPERANTOK S 2 Replies Last reply
                • V
                  Volkae @KristjanESPERANTO
                  Sorry, but I am not sure how to see this informations
                    KristjanESPERANTO Module Developer @Volkae
                    @Volkae said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                    You need to update MagicMirror. The module doesn’t work anymore with MagicMirror version 2.30.0.
                      sdetweil @Volkae
                      @Volkae that means the upgrade didn’t execute
                      copy/paste and execute this in a terminal window on the MagicMirror system
                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"  apply
                        p1lspeda @p1lspeda
                        @p1lspeda said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                        Here you go
                        Although it is not listed, I am running a Raspberry Pi 4
                        pi@magicmirror:~ $ lscpu
                        Architecture:             aarch64
                          CPU op-mode(s):         32-bit, 64-bit
                          Byte Order:             Little Endian
                        CPU(s):                   4
                          On-line CPU(s) list:    0-3
                        Vendor ID:                ARM
                          Model name:             Cortex-A72
                            Model:                3
                            Thread(s) per core:   1
                            Core(s) per cluster:  4
                            Socket(s):            -
                            Cluster(s):           1
                            Stepping:             r0p3
                            CPU(s) scaling MHz:   50%
                            CPU max MHz:          1800.0000
                            CPU min MHz:          600.0000
                            BogoMIPS:             108.00
                            Flags:                fp asimd evtstrm crc32 cpuid
                        Caches (sum of all):
                          L1d:                    128 KiB (4 instances)
                          L1i:                    192 KiB (4 instances)
                          L2:                     1 MiB (1 instance)
                        NUMA:
                          NUMA node(s):           1
                          NUMA node0 CPU(s):      0-3
                        Vulnerabilities:
                          Gather data sampling:   Not affected
                          Itlb multihit:          Not affected
                          L1tf:                   Not affected
                          Mds:                    Not affected
                          Meltdown:               Not affected
                          Mmio stale data:        Not affected
                          Reg file data sampling: Not affected
                          Retbleed:               Not affected
                          Spec rstack overflow:   Not affected
                          Spec store bypass:      Vulnerable
                          Spectre v1:             Mitigation; __user pointer sanitization
                          Spectre v2:             Vulnerable
                          Srbds:                  Not affected
                          Tsx async abort:        Not affected
                        S KristjanESPERANTOK 2 Replies Last reply
                          sdetweil @p1lspeda
                          @p1lspeda have you tried the upgrade script?
                          I believe the module requires 2.31.0 as a minimum MM version now
                            KristjanESPERANTO Module Developer @p1lspeda
                            You still need to upgrade MagicMirror. I recommend the official upgrade process.
                            • V
                              Volkae
                              I used the update script again and now MM is 2.31.0
                              MMM-PublicTransportHafas works again, that`s fine, but now MMM-SmartWebDisplay is gone…
                              Not fine…
                                sdetweil @Volkae
                                @Volkae any errors listed in MagicMirror startup?
                                • V
                                  Volkae @sdetweil
                                  Sorry, I don`t know how to show the errors during startup :-(
                                    sdetweil @Volkae
                                    @Volkae where does npm start output
                                    if using pm2 tge
                                    pm2 logs --lines=xxx
                                    xxx is the number of most recent lines
                                    default 15
                                    probably 100 good start
                                    note the output comes in 2 parts
                                    error and output
                                    • V
                                      Volkae @sdetweil
                                      Not using pm2
                                      using cronjob to start MM
                                        sdetweil @Volkae
                                        @Volkae i forgot to mention that the full calendar url
                                        is shown
                                        i have deleted the other message
                                        • V
                                          Volkae @sdetweil
                                          Upps,
                                          thank you!!!
                                            @KristjanESPERANTO
                                            I’ve upgraded to the latest MM Version
                                            pi@magicmirror:~/MagicMirror $ grep version package.json
                                                    "version": "2.31.0-develop",
                                            [2025-05-07 09:57:22.742] [INFO]  System information:
                                            And I still get this error
                                            [2025-05-07 09:57:19.297] [ERROR] Error when loading MMM-PublicTransportHafas: require() of ES Module /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs not supported.
                                            Instead change the require of /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs to a dynamic import() which is available in all CommonJS modules.
                                            My module version:
                                            pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ grep version package.json
                                              "version": "3.1.11",
                                            pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ git pull
                                            Already up to date.
                                            I do not know what else I can do or what I have missed
                                            mumblebajM karsten13K 2 Replies Last reply
