    MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs
    43 Posts 7 Posters 16.3k Views 7 Watching
      sdetweil @Volkae
      @Volkae @p1lspeda @KristjanESPERANTO will have to advise next steps
      KristjanESPERANTOK 1 Reply Last reply
      • KristjanESPERANTOK
        @sdetweil said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
        I need the system information part from the logs. Like this:
        [2025-01-14 20:05:03.529] [INFO]  System information:
        ### SYSTEM:    manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
        ### OS:        platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.1.21-v8+
        ### VERSIONS:  electron: 31.2.1; used node: 20.15.0; installed node: 22.4.1; npm: 10.8.1; pm2:
        ### OTHER:     timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
        P V 2 Replies Last reply
          @KristjanESPERANTO said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
          Here you go
          [2025-05-06 06:46:30.229] [INFO]  System information:
          ### SYSTEM:   manufacturer: ; model: ; virtual: false
          ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-v8
          ### VERSIONS: electron: 32.2.7; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
          P 1 Reply Last reply
          • V
            Volkae @sdetweil
            node -v
            grep version package.json
            22.14.0
            “version”: “2.30.0”,
            KristjanESPERANTOK S 2 Replies Last reply
            • V
              Volkae @KristjanESPERANTO
              Sorry, but I am not sure how to see this informations
                KristjanESPERANTO Module Developer @Volkae
                @Volkae said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                You need to update MagicMirror. The module doesn’t work anymore with MagicMirror version 2.30.0.
                  sdetweil @Volkae
                  @Volkae that means the upgrade didn’t execute
                  copy/paste and execute this in a terminal window on the MagicMirror system
                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"  apply
                    p1lspeda @p1lspeda
                    @p1lspeda said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                    Here you go
                    Although it is not listed, I am running a Raspberry Pi 4
                    pi@magicmirror:~ $ lscpu
                    Architecture:             aarch64
                      CPU op-mode(s):         32-bit, 64-bit
                      Byte Order:             Little Endian
                    CPU(s):                   4
                      On-line CPU(s) list:    0-3
                    Vendor ID:                ARM
                      Model name:             Cortex-A72
                        Model:                3
                        Thread(s) per core:   1
                        Core(s) per cluster:  4
                        Socket(s):            -
                        Cluster(s):           1
                        Stepping:             r0p3
                        CPU(s) scaling MHz:   50%
                        CPU max MHz:          1800.0000
                        CPU min MHz:          600.0000
                        BogoMIPS:             108.00
                        Flags:                fp asimd evtstrm crc32 cpuid
                    Caches (sum of all):
                      L1d:                    128 KiB (4 instances)
                      L1i:                    192 KiB (4 instances)
                      L2:                     1 MiB (1 instance)
                    NUMA:
                      NUMA node(s):           1
                      NUMA node0 CPU(s):      0-3
                    Vulnerabilities:
                      Gather data sampling:   Not affected
                      Itlb multihit:          Not affected
                      L1tf:                   Not affected
                      Mds:                    Not affected
                      Meltdown:               Not affected
                      Mmio stale data:        Not affected
                      Reg file data sampling: Not affected
                      Retbleed:               Not affected
                      Spec rstack overflow:   Not affected
                      Spec store bypass:      Vulnerable
                      Spectre v1:             Mitigation; __user pointer sanitization
                      Spectre v2:             Vulnerable
                      Srbds:                  Not affected
                      Tsx async abort:        Not affected
                    S KristjanESPERANTOK 2 Replies Last reply
                      sdetweil @p1lspeda
                      @p1lspeda have you tried the upgrade script?
                      I believe the module requires 2.31.0 as a minimum MM version now
                        KristjanESPERANTO Module Developer @p1lspeda
                        You still need to upgrade MagicMirror. I recommend the official upgrade process.
                        • V
                          Volkae
                          I used the update script again and now MM is 2.31.0
                          MMM-PublicTransportHafas works again, that`s fine, but now MMM-SmartWebDisplay is gone…
                          Not fine…
                            sdetweil @Volkae
                            @Volkae any errors listed in MagicMirror startup?
                            V 1 Reply Last reply
                            • V
                              Volkae @sdetweil
                              Sorry, I don`t know how to show the errors during startup :-(
                                sdetweil @Volkae
                                @Volkae where does npm start output
                                if using pm2 tge
                                pm2 logs --lines=xxx
                                xxx is the number of most recent lines
                                default 15
                                probably 100 good start
                                note the output comes in 2 parts
                                error and output
                                • V
                                  Volkae @sdetweil
                                  Not using pm2
                                  using cronjob to start MM
                                    sdetweil @Volkae
                                    @Volkae i forgot to mention that the full calendar url
                                    is shown
                                    i have deleted the other message
                                    • V
                                      Volkae @sdetweil
                                      Upps,
                                      thank you!!!
                                        @KristjanESPERANTO
                                        I’ve upgraded to the latest MM Version
                                        pi@magicmirror:~/MagicMirror $ grep version package.json
                                                "version": "2.31.0-develop",
                                        [2025-05-07 09:57:22.742] [INFO]  System information:
                                        And I still get this error
                                        [2025-05-07 09:57:19.297] [ERROR] Error when loading MMM-PublicTransportHafas: require() of ES Module /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs not supported.
                                        Instead change the require of /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs to a dynamic import() which is available in all CommonJS modules.
                                        My module version:
                                        pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ grep version package.json
                                          "version": "3.1.11",
                                        pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ git pull
                                        Already up to date.
                                        I do not know what else I can do or what I have missed
                                        mumblebajM karsten13K 2 Replies Last reply
                                        • mumblebajM
                                          mumblebaj Module Developer @p1lspeda
                                          @p1lspeda
                                          I just done a fresh install of the module and it works fine for me.
                                          Just out of curiosity, did you do the following steps?
                                          • cd MMM-PublicTransportHafas
                                          • npm ci --omit=dev
                                          @KristjanESPERANTO ) saw the below in the log, I am assuming it is nothing to be concerned about?
                                          • karsten13K
                                            karsten13 @p1lspeda
                                            not really, 2.31.0-develop <> 2.31.0
                                            • 2 / 3
