    MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs
    43 Posts 7 Posters 16.3k Views 7 Watching
    • KristjanESPERANTOK
      KristjanESPERANTO Module Developer @p1lspeda
      @p1lspeda said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
      ### VERSIONS: electron: 32.2.7; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
      You still need to upgrade MagicMirror. I recommend the official upgrade process.
      P 1 Reply Last reply
      • V
        Volkae
        I used the update script again and now MM is 2.31.0
        MMM-PublicTransportHafas works again, that`s fine, but now MMM-SmartWebDisplay is gone…
        Not fine…
          sdetweil @Volkae
          @Volkae any errors listed in MagicMirror startup?
          V 1 Reply Last reply
          • V
            Volkae @sdetweil
            Sorry, I don`t know how to show the errors during startup :-(
              sdetweil @Volkae
              @Volkae where does npm start output
              if using pm2 tge
              pm2 logs --lines=xxx
              xxx is the number of most recent lines
              default 15
              probably 100 good start
              note the output comes in 2 parts
              error and output
              • V
                Volkae @sdetweil
                Not using pm2
                using cronjob to start MM
                  sdetweil @Volkae
                  @Volkae i forgot to mention that the full calendar url
                  is shown
                  i have deleted the other message
                  • V
                    Volkae @sdetweil
                    Upps,
                    thank you!!!
                      p1lspeda @KristjanESPERANTO
                      @KristjanESPERANTO
                      I’ve upgraded to the latest MM Version
                      pi@magicmirror:~/MagicMirror $ grep version package.json
                              "version": "2.31.0-develop",
                      [2025-05-07 09:57:22.742] [INFO]  System information:
                      ### SYSTEM:   manufacturer: ; model: ; virtual: false
                      ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-v8
                      ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                      And I still get this error
                      [2025-05-07 09:57:19.297] [ERROR] Error when loading MMM-PublicTransportHafas: require() of ES Module /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs not supported.
                      Instead change the require of /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs to a dynamic import() which is available in all CommonJS modules.
                      My module version:
                      pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ grep version package.json
                        "version": "3.1.11",
                      pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ git pull
                      Already up to date.
                      I do not know what else I can do or what I have missed
                      mumblebajM karsten13K 2 Replies Last reply
                      • mumblebajM
                        mumblebaj Module Developer @p1lspeda
                        @p1lspeda
                        I just done a fresh install of the module and it works fine for me.
                        Just out of curiosity, did you do the following steps?
                        • cd MMM-PublicTransportHafas
                        • npm ci --omit=dev
                        @KristjanESPERANTO ) saw the below in the log, I am assuming it is nothing to be concerned about?
                        • karsten13K
                          karsten13 @p1lspeda
                          not really, 2.31.0-develop <> 2.31.0
                          KristjanESPERANTOK 1 Reply Last reply
                            KristjanESPERANTO Module Developer @karsten13
                            @p1lspeda How did you perform the MagicMirror update? Please show us the output of git branch when you are in the MagicMirror root directory.
                            S P 2 Replies Last reply
                              sdetweil @KristjanESPERANTO
                              @KristjanESPERANTO looks like he was on the dev branch for a fix and didn’t use my script to update or follow the instructions I posted
                              https://forum.magicmirror.builders/topic/19561/version-2.31.0-april-1-2025-upgrade-reminder
                                @KristjanESPERANTO
                                Thanks for your patience,
                                Edit: did a complete reinstall and now it works. I must have misconfigured something and could not remember what or how.
                                This is what I have done:
                                • I switched to the master branch yesterday and ran @sdetweil 's update script no change
                                • I’ve done a fresh module install - no change
                                • I’ve ran @sdetweil 's upgrade script - no change
                                pi@magicmirror:~/MagicMirror $ git branch
                                  _fix_clipping
                                * master
                                pi@magicmirror:~/MagicMirror $ cd modules/MMM-PublicTransportHafas/
                                pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ npm ci --omit=dev
                                > mmm-publictransporthafas@3.1.11 prepare
                                > [ -f node_modules/.bin/husky ] && husky || echo husky is not installed.
                                added 63 packages, and audited 64 packages in 20s
                                19 packages are looking for funding
                                  run `npm fund` for details
                                found 0 vulnerabilities
                                        "version": "2.31.0",
                                Here’s my config.js
                                                        module: "MMM-PublicTransportHafas",
        stationID: "000405041",                   // Replace with your stationID!
        stationName: "Höfchen/Listmann",   // Replace with your station name!
        direction: "",                    // Show only departures heading to this station. (A station ID.)
        ignoredLines: [],                 // Which lines should be ignored? (comma-separated list of line names)
        excludedTransportationTypes: [],  // Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: StN for >
        timeToStation: 10,                // How long do you need to walk to the next Station?
        showColoredLineSymbols: true,     // Want colored line symbols?
        useColorForRealtimeInfo: true,    // Want colored real time information (timeToStation, early)?
        showTableHeadersAsSymbols: true,  // Table Headers as symbols or text?
        maxUnreachableDepartures: 0,      // How many unreachable departures should be shown?
        maxReachableDepartures: 10,        // How many reachable departures should be shown?
        customLineStyles: "",             // Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitive)
        showOnlyLineNumbers: false        // Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
                                The error still occurs.
                                At this point I’m completely clueless
                                • V
                                  Vulan12354
                                  Hello together,
                                  i tried your instruction and updated MM and node.
                                  My node Version is 23.7.0
                                  My MM Version is 2.31.0
                                  git branch shows me master (highlighted)
                                  I also updated the module Version to: “3.1.11”
                                  Still got the error message.
                                    sdetweil @Vulan12354
                                    @Vulan12354 how did you upgrade MagicMirror?
                                      sdetweil @p1lspeda
                                      @p1lspeda on my upgrade script, can you show me the ~/MagicMirror/installers/upgrade.log
                                      or tell me the command you used
                                        p1lspeda @sdetweil
                                        I removed the entire MagicMirror directory before reinstalling MM.
                                        I didn’t make a backup, so I cannot provide the log. Sorry.
                                        For updating I tried
                                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                        and
                                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                                        and the fresh install was achieved by using
                                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                          sdetweil @p1lspeda
                                          @p1lspeda great thanks…
                                          only THIS one DOES the upgrade
                                          BUT, if you did a git pull manually then the local code would be at the new/current version
                                          and I would abort, as you are ALREADY at the current level…
                                          THEN you have to do
                                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                          cause I won’t let you upgrade OVER the same release accidentally
                                          ~/MagicMirror/installers/upgrade.log is created and updated in all cases.
                                          so we can tell what happened
                                          if it didn’t seem to work, I want to know… and get the log,
                                          even if you decide to abort and start over
                                          these scripts are very conservative… I do NOT want to destroy your running MM system
                                          P V 2 Replies Last reply
                                            p1lspeda @sdetweil
                                            good to know for the future. Thanks.
                                            I was unaware of the “force” parameter, that’s why I never tried it.
                                            • 2 / 3
