    MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs
    43 Posts 7 Posters 16.3k Views 7 Watching
    • V
      Volkae @sdetweil
      Sorry, I don`t know how to show the errors during startup :-(
        sdetweil @Volkae
        @Volkae where does npm start output
        if using pm2 tge
        pm2 logs --lines=xxx
        xxx is the number of most recent lines
        default 15
        probably 100 good start
        note the output comes in 2 parts
        error and output
        V 1 Reply Last reply
        • V
          Volkae @sdetweil
          Not using pm2
          using cronjob to start MM
            sdetweil @Volkae
            @Volkae i forgot to mention that the full calendar url
            is shown
            i have deleted the other message
            • V
              Volkae @sdetweil
              Upps,
              thank you!!!
                p1lspeda @KristjanESPERANTO
                @KristjanESPERANTO
                I’ve upgraded to the latest MM Version
                pi@magicmirror:~/MagicMirror $ grep version package.json
                        "version": "2.31.0-develop",
                [2025-05-07 09:57:22.742] [INFO]  System information:
                ### SYSTEM:   manufacturer: ; model: ; virtual: false
                ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-v8
                ### VERSIONS: electron: 32.2.7; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
                ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                And I still get this error
                [2025-05-07 09:57:19.297] [ERROR] Error when loading MMM-PublicTransportHafas: require() of ES Module /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs not supported.
                Instead change the require of /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs to a dynamic import() which is available in all CommonJS modules.
                My module version:
                pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ grep version package.json
                  "version": "3.1.11",
                pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ git pull
                Already up to date.
                I do not know what else I can do or what I have missed
                mumblebajM karsten13K 2 Replies Last reply
                • mumblebajM
                  mumblebaj Module Developer @p1lspeda
                  @p1lspeda
                  I just done a fresh install of the module and it works fine for me.
                  Just out of curiosity, did you do the following steps?
                  • cd MMM-PublicTransportHafas
                  • npm ci --omit=dev
                  @KristjanESPERANTO ) saw the below in the log, I am assuming it is nothing to be concerned about?
                  • karsten13K
                    karsten13 @p1lspeda
                    @p1lspeda said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                    not really, 2.31.0-develop <> 2.31.0
                    KristjanESPERANTOK 1 Reply Last reply
                    • KristjanESPERANTOK
                      KristjanESPERANTO Module Developer @karsten13
                      @p1lspeda How did you perform the MagicMirror update? Please show us the output of git branch when you are in the MagicMirror root directory.
                      S P 2 Replies Last reply
                        sdetweil @KristjanESPERANTO
                        @KristjanESPERANTO looks like he was on the dev branch for a fix and didn’t use my script to update or follow the instructions I posted
                        https://forum.magicmirror.builders/topic/19561/version-2.31.0-april-1-2025-upgrade-reminder
                          @KristjanESPERANTO
                          Thanks for your patience,
                          Edit: did a complete reinstall and now it works. I must have misconfigured something and could not remember what or how.
                          This is what I have done:
                          • I switched to the master branch yesterday and ran @sdetweil 's update script no change
                          • I’ve done a fresh module install - no change
                          • I’ve ran @sdetweil 's upgrade script - no change
                          pi@magicmirror:~/MagicMirror $ git branch
                            _fix_clipping
                          * master
                          pi@magicmirror:~/MagicMirror $ cd modules/MMM-PublicTransportHafas/
                          pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ npm ci --omit=dev
                          > mmm-publictransporthafas@3.1.11 prepare
                          > [ -f node_modules/.bin/husky ] && husky || echo husky is not installed.
                          added 63 packages, and audited 64 packages in 20s
                          19 packages are looking for funding
                            run `npm fund` for details
                          found 0 vulnerabilities
                                  "version": "2.31.0",
                          Here’s my config.js
                                                  module: "MMM-PublicTransportHafas",
                                                          stationID: "000405041",                   // Replace with your stationID!
                                                          stationName: "Höfchen/Listmann",   // Replace with your station name!
                                                          direction: "",                    // Show only departures heading to this station. (A station ID.)
                                                          ignoredLines: [],                 // Which lines should be ignored? (comma-separated list of line names)
                                                          excludedTransportationTypes: [],  // Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: StN for >
                                                          timeToStation: 10,                // How long do you need to walk to the next Station?
                                                          showColoredLineSymbols: true,     // Want colored line symbols?
                                                          useColorForRealtimeInfo: true,    // Want colored real time information (timeToStation, early)?
                                                          showTableHeadersAsSymbols: true,  // Table Headers as symbols or text?
                                                          maxUnreachableDepartures: 0,      // How many unreachable departures should be shown?
                                                          maxReachableDepartures: 10,        // How many reachable departures should be shown?
                                                          customLineStyles: "",             // Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitive)
                                                          showOnlyLineNumbers: false        // Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
                          The error still occurs.
                          At this point I’m completely clueless
                          • V
                            Vulan12354
                            Hello together,
                            i tried your instruction and updated MM and node.
                            My node Version is 23.7.0
                            My MM Version is 2.31.0
                            git branch shows me master (highlighted)
                            I also updated the module Version to: “3.1.11”
                            Still got the error message.
                              sdetweil @Vulan12354
                              @Vulan12354 how did you upgrade MagicMirror?
                                sdetweil @p1lspeda
                                @p1lspeda on my upgrade script, can you show me the ~/MagicMirror/installers/upgrade.log
                                or tell me the command you used
                                P 1 Reply Last reply
                                  p1lspeda @sdetweil
                                  I removed the entire MagicMirror directory before reinstalling MM.
                                  I didn’t make a backup, so I cannot provide the log. Sorry.
                                  For updating I tried
                                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                  and
                                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                                  and the fresh install was achieved by using
                                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                    sdetweil @p1lspeda
                                    @p1lspeda great thanks…
                                    only THIS one DOES the upgrade
                                    BUT, if you did a git pull manually then the local code would be at the new/current version
                                    and I would abort, as you are ALREADY at the current level…
                                    THEN you have to do
                                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                    cause I won’t let you upgrade OVER the same release accidentally
                                    ~/MagicMirror/installers/upgrade.log is created and updated in all cases.
                                    so we can tell what happened
                                    if it didn’t seem to work, I want to know… and get the log,
                                    even if you decide to abort and start over
                                    these scripts are very conservative… I do NOT want to destroy your running MM system
                                    P V 2 Replies Last reply
                                      p1lspeda @sdetweil
                                      good to know for the future. Thanks.
                                      I was unaware of the “force” parameter, that’s why I never tried it.
                                        sdetweil @p1lspeda
                                        @p1lspeda i do not publish force, as i do not want people to use it willy nilly.
                                        danger…
                                        • V
                                          Vulan12354 @sdetweil
                                          It looks like it is working now, but at the moment the module cant get any information about the bus schedule. But the MagicMirror is starting without any error message.
                                          Thank you for your patience.
                                          I will wait till monday, and tell you all if its working now or not.
                                          • V
                                            Vulan12354
                                            Hey together,
                                            it is working now.
                                            The last bug was a known issue.
                                            link Issue 193
                                            Thanks all for helping to fix my problem!
                                            Reply Quote 2
                                            • 2 / 3
