    MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs
    43 Posts 7 Posters 16.3k Views 7 Watching
      sdetweil @KristjanESPERANTO
      @KristjanESPERANTO looks like he was on the dev branch for a fix and didn’t use my script to update or follow the instructions I posted
      https://forum.magicmirror.builders/topic/19561/version-2.31.0-april-1-2025-upgrade-reminder
        p1lspeda @KristjanESPERANTO
        @KristjanESPERANTO
        Thanks for your patience,
        Edit: did a complete reinstall and now it works. I must have misconfigured something and could not remember what or how.
        This is what I have done:
        • I switched to the master branch yesterday and ran @sdetweil 's update script no change
        • I’ve done a fresh module install - no change
        • I’ve ran @sdetweil 's upgrade script - no change
        pi@magicmirror:~/MagicMirror $ git branch
          _fix_clipping
        * master
        pi@magicmirror:~/MagicMirror $ cd modules/MMM-PublicTransportHafas/
        pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ npm ci --omit=dev
        > mmm-publictransporthafas@3.1.11 prepare
        > [ -f node_modules/.bin/husky ] && husky || echo husky is not installed.
        added 63 packages, and audited 64 packages in 20s
        19 packages are looking for funding
          run `npm fund` for details
        found 0 vulnerabilities
        pi@magicmirror:~/MagicMirror $ grep version package.json
                "version": "2.31.0",
        Here’s my config.js
                                module: "MMM-PublicTransportHafas",
                                        stationID: "000405041",                   // Replace with your stationID!
                                        stationName: "Höfchen/Listmann",   // Replace with your station name!
                                        direction: "",                    // Show only departures heading to this station. (A station ID.)
                                        ignoredLines: [],                 // Which lines should be ignored? (comma-separated list of line names)
                                        excludedTransportationTypes: [],  // Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: StN for >
                                        timeToStation: 10,                // How long do you need to walk to the next Station?
                                        showColoredLineSymbols: true,     // Want colored line symbols?
                                        useColorForRealtimeInfo: true,    // Want colored real time information (timeToStation, early)?
                                        showTableHeadersAsSymbols: true,  // Table Headers as symbols or text?
                                        maxUnreachableDepartures: 0,      // How many unreachable departures should be shown?
                                        maxReachableDepartures: 10,        // How many reachable departures should be shown?
                                        customLineStyles: "",             // Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitive)
                                        showOnlyLineNumbers: false        // Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
        The error still occurs.
        At this point I’m completely clueless
        • V
          Vulan12354
          Hello together,
          i tried your instruction and updated MM and node.
          My node Version is 23.7.0
          My MM Version is 2.31.0
          git branch shows me master (highlighted)
          I also updated the module Version to: “3.1.11”
          Still got the error message.
            sdetweil @Vulan12354
            @Vulan12354 how did you upgrade MagicMirror?
              sdetweil @p1lspeda
              @p1lspeda on my upgrade script, can you show me the ~/MagicMirror/installers/upgrade.log
              or tell me the command you used
              P 1 Reply Last reply
                p1lspeda @sdetweil
                I removed the entire MagicMirror directory before reinstalling MM.
                I didn’t make a backup, so I cannot provide the log. Sorry.
                For updating I tried
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                and
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                and the fresh install was achieved by using
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                  sdetweil @p1lspeda
                  @p1lspeda great thanks…
                  only THIS one DOES the upgrade
                  BUT, if you did a git pull manually then the local code would be at the new/current version
                  and I would abort, as you are ALREADY at the current level…
                  THEN you have to do
                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                  cause I won’t let you upgrade OVER the same release accidentally
                  ~/MagicMirror/installers/upgrade.log is created and updated in all cases.
                  so we can tell what happened
                  if it didn’t seem to work, I want to know… and get the log,
                  even if you decide to abort and start over
                  these scripts are very conservative… I do NOT want to destroy your running MM system
                  P V 2 Replies Last reply
                    p1lspeda @sdetweil
                    good to know for the future. Thanks.
                    I was unaware of the “force” parameter, that’s why I never tried it.
                      sdetweil @p1lspeda
                      @p1lspeda i do not publish force, as i do not want people to use it willy nilly.
                      danger…
                      • V
                        Vulan12354 @sdetweil
                        It looks like it is working now, but at the moment the module cant get any information about the bus schedule. But the MagicMirror is starting without any error message.
                        Thank you for your patience.
                        I will wait till monday, and tell you all if its working now or not.
                        • V
                          Vulan12354
                          Hey together,
                          it is working now.
                          The last bug was a known issue.
                          link Issue 193
                          Thanks all for helping to fix my problem!
                          Reply Quote 2
                          • 3 / 3
